a question about PetscSectionCreate
Hi, Dave: I want to store a PetscInt tag for every cell of the dmplex with the struct. Thanks, leejearl
/Hi, Dave: />/ > Thank you for your kind reply. If I want to store a mixture of />/PetscReal and PetscInt, how can I do it? /
What operations do you need to perform with your struct?
//>/ > Thanks, />/ > leejearl />>//>>
You probably want to use a DMLabel to store these ids. Unless you have a different I'd for every cell. Lawrence
On Sun, May 28, 2017 at 6:02 AM, Lawrence Mitchell < [email protected]> wrote:
Several things to think about: 1) If you want to store a tag for EVERY cell, then just use an IS. Cell numberings are guaranteed to be contiguous and start from 0. 2) If you want to tag only SOME cells, then use a DMLabel as Lawrence suggests. This uses hash tables for fast construction, and sorted lists for fast search and retrieval. 3) If you want to store a VARIABLE number of data items per cell, then use a Section and an array that you allocate. Matt
Lawrence
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener http://www.caam.rice.edu/~mk51/
Hi, all: I have create a IS for every cell in dmplex by the following steps: 1. Creating a integer array which size is matched to the number of cells. 2. Use the routine "ISCreateGeneral" to create a corresponding IS. Is there any routine which can create a IS for every cell in the dmplex directly?, and what is the difference between ISCopy() and ISDuplicate()? Thanks, leejearl On 2017年05月28日 19:35, Matthew Knepley wrote:
On Sun, May 28, 2017 at 6:02 AM, Lawrence Mitchell <[email protected] <mailto:[email protected]>> wrote:
> On 28 May 2017, at 09:16, leejearl <[email protected] <mailto:[email protected]>> wrote: > > Hi, Dave: I want to store a PetscInt tag for every cell of the dmplex with the struct. Thanks,
Matt
Lawrence
http://www.caam.rice.edu/~mk51/ <http://www.caam.rice.edu/%7Emk51/>
-- 李季 西北工业大学航空学院流体力学系 Phone: 17792092487 QQ: 188524324
I don't think so as Plex would have to somehow know what geom quantity to use to define the size of IS (e.g. vertex, cell, face, edge) and what is the difference between ISCopy() and ISDuplicate()?
ISDuplicate allocates memory for a new with the same comm and layout as the original IS AND copies values from the original IS into the new one. (Note that this is slightly different from other duplicate functions like VecDuplicate which only allocate memory and does not copy values from the orig vec.) ISCopy does not allocate memory for the IS (passed as the second arg), it only performs the copy of values. Thanks Dave
Thanks, leejearl
Matt
Lawrence
Thanks for your kind reply. It helps me very much. leejearl On 2017年05月29日 15:47, Dave May wrote:
On Mon, 29 May 2017 at 08:39, leejearl <[email protected] <mailto:[email protected]>> wrote:
Thanks Dave
Thanks, leejearl
Matt
Lawrence
participants (4)
Dave May -
Lawrence Mitchell -
leejearl -
Matthew Knepley
