Hi, When using -mat_partitioning_view flag, PETSc reports number of edge cuts. Is this the number of edge cuts in the graph for the new partitioning (i.e. using new global numbering)? Also, does the partitioning favors minimizing the edge cuts over having equal number of points per processor? If so, how can this be altered? Thanks, Mohammad
yes
Metis and ParMetis balance the partitions "equally" (within 1 vertex), then tries to minimize the edge cut. Assuming that is the partitioner you are using, that is what you will get.
Thanks Jed. Then I should be doing something wrong. I'm trying a simple graph and counting the number of edge cuts manually but the numbers don't match. I'll keep looking into it. Mohammad On Mon, Feb 13, 2012 at 4:22 PM, Jed Brown <[email protected]> wrote:
yes
participants (2)
Jed Brown -
Mohammad Mirzadeh
