Doubt about mesh size distribution in DMDACreate3d using periodic boundary conditions
Dear all: It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size. I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed: 210 420 366 732 420 840 732 1464 Am I missing something? Thanks, Miguel [cid:534265d3-3f18-41cd-8006-539cb06751f9@eurprd01.prod.exchangelabs.com]
I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC Can you please send a reproducible example? Thanks Barry
On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote:
Dear all:
Thanks, Miguel
<Screenshot 2024-11-19 at 10.56.36.png>
Hi Bary: I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP. Thanks, Miguel On 19 Nov 2024, at 18:55, Barry Smith <[email protected]> wrote: I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC Can you please send a reproducible example? Thanks Barry On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear all: It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size. I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed: 210 420 366 732 420 840 732 1464 Am I missing something? Thanks, Miguel <Screenshot 2024-11-19 at 10.56.36.png>
Dear Barry, Please, find attached to this email a minimal example of the problem. Run it using 8 MPI processes. Thanks, Miguel On 20 Nov 2024, at 11:48, Miguel Molinos <[email protected]> wrote: Hi Bary: I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP. Thanks, Miguel On 19 Nov 2024, at 18:55, Barry Smith <[email protected]> wrote: I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC Can you please send a reproducible example? Thanks Barry On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear all: It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size. I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed: 210 420 366 732 420 840 732 1464 Am I missing something? Thanks, Miguel <Screenshot 2024-11-19 at 10.56.36.png>
I am sorry, I don't understand the problem. When I run by default with -da_view I get Processor [0] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 0 2 Processor [3] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 0 2 Processor [4] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 3 Processor [5] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 2 3 Processor [6] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 2 3 Processor [7] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 2 3 which seems right because you are trying to have three cells in each direction. The distribution has to be uneven, hence 0 2 and 2 3 When I change the code to use ndiv_mesh_* = 4 and run with periodic or not I get $ PETSC_OPTIONS="" mpiexec -n 8 ./atoms-3D -dm_view DM Object: 8 MPI processes type: da Processor [0] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 0 2 Processor [3] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 0 2 Processor [4] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 4 Processor [5] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 2 4 Processor [6] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 2 4 Processor [7] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 2 4 so it is splitting as expected each rank gets a 2 by 2 by 2 set of indices. Could you please let me know what the problem is that I should be seeing. Barry
On Nov 20, 2024, at 7:06 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote:
Dear Barry,
Thanks, Miguel
Hi Bary:
Thanks, Miguel
Thanks
Barry
Dear all:
Thanks, Miguel
<atoms-3D.cpp><Mg-hcp-cube-x17-x10-x10.dump>
Sorry, I meant that the discretisation size is not constant across the edges of the cube. Miguel On 20 Nov 2024, at 18:36, Barry Smith <[email protected]> wrote: I am sorry, I don't understand the problem. When I run by default with -da_view I get Processor [0] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 0 2 Processor [3] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 0 2 Processor [4] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 3 Processor [5] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 2 3 Processor [6] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 2 3 Processor [7] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 2 3 which seems right because you are trying to have three cells in each direction. The distribution has to be uneven, hence 0 2 and 2 3 When I change the code to use ndiv_mesh_* = 4 and run with periodic or not I get $ PETSC_OPTIONS="" mpiexec -n 8 ./atoms-3D -dm_view DM Object: 8 MPI processes type: da Processor [0] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 0 2 Processor [3] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 0 2 Processor [4] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 4 Processor [5] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 2 4 Processor [6] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 2 4 Processor [7] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 2 4 so it is splitting as expected each rank gets a 2 by 2 by 2 set of indices. Could you please let me know what the problem is that I should be seeing. Barry On Nov 20, 2024, at 7:06 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear Barry, Please, find attached to this email a minimal example of the problem. Run it using 8 MPI processes. Thanks, Miguel On 20 Nov 2024, at 11:48, Miguel Molinos <[email protected]> wrote: Hi Bary: I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP. Thanks, Miguel On 19 Nov 2024, at 18:55, Barry Smith <[email protected]> wrote: I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC Can you please send a reproducible example? Thanks Barry On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear all: It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size. I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed: 210 420 366 732 420 840 732 1464 Am I missing something? Thanks, Miguel <Screenshot 2024-11-19 at 10.56.36.png> <atoms-3D.cpp><Mg-hcp-cube-x17-x10-x10.dump>
What do you mean by discretization size, and how do I see it in the code? Barry
On Nov 20, 2024, at 12:48 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote:
Miguel
Barry
Dear Barry,
Thanks, Miguel
Hi Bary:
Thanks, Miguel
Thanks
Barry
Dear all:
Thanks, Miguel
I mean that if the dimensions of the cube are 1x1x1 (for example). And I want 10 elements per edge, the discretization size must be 0.1 constant over the whole cube edge. This is not in the code, I just impose the number of elements per edge. Thank you, Miguel On 20 Nov 2024, at 18:52, Barry Smith <[email protected]> wrote: What do you mean by discretization size, and how do I see it in the code? Barry On Nov 20, 2024, at 12:48 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Sorry, I meant that the discretisation size is not constant across the edges of the cube. Miguel On 20 Nov 2024, at 18:36, Barry Smith <[email protected]> wrote: I am sorry, I don't understand the problem. When I run by default with -da_view I get Processor [0] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 0 2 Processor [3] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 0 2 Processor [4] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 3 Processor [5] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 2 3 Processor [6] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 2 3 Processor [7] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 2 3 which seems right because you are trying to have three cells in each direction. The distribution has to be uneven, hence 0 2 and 2 3 When I change the code to use ndiv_mesh_* = 4 and run with periodic or not I get $ PETSC_OPTIONS="" mpiexec -n 8 ./atoms-3D -dm_view DM Object: 8 MPI processes type: da Processor [0] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 0 2 Processor [3] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 0 2 Processor [4] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 4 Processor [5] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 2 4 Processor [6] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 2 4 Processor [7] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 2 4 so it is splitting as expected each rank gets a 2 by 2 by 2 set of indices. Could you please let me know what the problem is that I should be seeing. Barry On Nov 20, 2024, at 7:06 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear Barry, Please, find attached to this email a minimal example of the problem. Run it using 8 MPI processes. Thanks, Miguel On 20 Nov 2024, at 11:48, Miguel Molinos <[email protected]> wrote: Hi Bary: I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP. Thanks, Miguel On 19 Nov 2024, at 18:55, Barry Smith <[email protected]> wrote: I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC Can you please send a reproducible example? Thanks Barry On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear all: It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size. I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed: 210 420 366 732 420 840 732 1464 Am I missing something? Thanks, Miguel <Screenshot 2024-11-19 at 10.56.36.png> <atoms-3D.cpp><Mg-hcp-cube-x17-x10-x10.dump>
Are you considering your degrees of freedom as vertex or cell-centered? Say three "elements" per edge. If vertex centered then discretization size is 1/3 if periodic and 1/2 if not periodic If cell-centered then each cell has width 1/3 for both periodic and not periodic but in both cases you can think of the discretization size as constant along the whole cube edge. Is this related to DMSWARM in particular?
On Nov 20, 2024, at 12:56 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote:
Thank you, Miguel
Barry
Miguel
Barry
Dear Barry,
Thanks, Miguel
Hi Bary:
Thanks, Miguel
Thanks
Barry
Dear all:
Thanks, Miguel
Yes, I use the vertex (nodes) of the elements. I am using the DMDA as an auxiliar mesh to do the domain partitioning in the DMSWARM. Thanks, Miguel On 20 Nov 2024, at 19:54, Barry Smith <[email protected]> wrote: Are you considering your degrees of freedom as vertex or cell-centered? Say three "elements" per edge. If vertex centered then discretization size is 1/3 if periodic and 1/2 if not periodic If cell-centered then each cell has width 1/3 for both periodic and not periodic but in both cases you can think of the discretization size as constant along the whole cube edge. Is this related to DMSWARM in particular? On Nov 20, 2024, at 12:56 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: I mean that if the dimensions of the cube are 1x1x1 (for example). And I want 10 elements per edge, the discretization size must be 0.1 constant over the whole cube edge. This is not in the code, I just impose the number of elements per edge. Thank you, Miguel On 20 Nov 2024, at 18:52, Barry Smith <[email protected]> wrote: What do you mean by discretization size, and how do I see it in the code? Barry On Nov 20, 2024, at 12:48 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Sorry, I meant that the discretisation size is not constant across the edges of the cube. Miguel On 20 Nov 2024, at 18:36, Barry Smith <[email protected]> wrote: I am sorry, I don't understand the problem. When I run by default with -da_view I get Processor [0] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 0 2 Processor [3] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 0 2 Processor [4] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 3 Processor [5] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 2 3 Processor [6] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 2 3 Processor [7] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 2 3 which seems right because you are trying to have three cells in each direction. The distribution has to be uneven, hence 0 2 and 2 3 When I change the code to use ndiv_mesh_* = 4 and run with periodic or not I get $ PETSC_OPTIONS="" mpiexec -n 8 ./atoms-3D -dm_view DM Object: 8 MPI processes type: da Processor [0] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 0 2 Processor [3] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 0 2 Processor [4] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 4 Processor [5] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 2 4 Processor [6] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 2 4 Processor [7] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 2 4 so it is splitting as expected each rank gets a 2 by 2 by 2 set of indices. Could you please let me know what the problem is that I should be seeing. Barry On Nov 20, 2024, at 7:06 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear Barry, Please, find attached to this email a minimal example of the problem. Run it using 8 MPI processes. Thanks, Miguel On 20 Nov 2024, at 11:48, Miguel Molinos <[email protected]> wrote: Hi Bary: I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP. Thanks, Miguel On 19 Nov 2024, at 18:55, Barry Smith <[email protected]> wrote: I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC Can you please send a reproducible example? Thanks Barry On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear all: It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size. I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed: 210 420 366 732 420 840 732 1464 Am I missing something? Thanks, Miguel <Screenshot 2024-11-19 at 10.56.36.png> <atoms-3D.cpp><Mg-hcp-cube-x17-x10-x10.dump>
Then the length between each vertex will be different between periodic and non-periodic case. With 10 points and non-periodic, it will be 1/9, and with periodic it will be 1/10th. Is this what you are asking about?
Thanks, Miguel
Thank you, Miguel
Barry
Miguel
Barry
Dear Barry,
Thanks, Miguel
Hi Bary:
Thanks, Miguel
Thanks
Barry
Dear all:
Thanks, Miguel
I see… that might be the problem. I’ll check it tomorrow. Thank you! Miguel On 20 Nov 2024, at 22:57, Barry Smith <[email protected]> wrote: On Nov 20, 2024, at 2:38 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Yes, I use the vertex (nodes) of the elements. Then the length between each vertex will be different between periodic and non-periodic case. With 10 points and non-periodic, it will be 1/9, and with periodic it will be 1/10th. Is this what you are asking about? I am using the DMDA as an auxiliar mesh to do the domain partitioning in the DMSWARM. Thanks, Miguel On 20 Nov 2024, at 19:54, Barry Smith <[email protected]> wrote: Are you considering your degrees of freedom as vertex or cell-centered? Say three "elements" per edge. If vertex centered then discretization size is 1/3 if periodic and 1/2 if not periodic If cell-centered then each cell has width 1/3 for both periodic and not periodic but in both cases you can think of the discretization size as constant along the whole cube edge. Is this related to DMSWARM in particular? On Nov 20, 2024, at 12:56 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: I mean that if the dimensions of the cube are 1x1x1 (for example). And I want 10 elements per edge, the discretization size must be 0.1 constant over the whole cube edge. This is not in the code, I just impose the number of elements per edge. Thank you, Miguel On 20 Nov 2024, at 18:52, Barry Smith <[email protected]> wrote: What do you mean by discretization size, and how do I see it in the code? Barry On Nov 20, 2024, at 12:48 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Sorry, I meant that the discretisation size is not constant across the edges of the cube. Miguel On 20 Nov 2024, at 18:36, Barry Smith <[email protected]> wrote: I am sorry, I don't understand the problem. When I run by default with -da_view I get Processor [0] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 0 2 Processor [3] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 0 2 Processor [4] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 3 Processor [5] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 2 3 Processor [6] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 2 3 Processor [7] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 2 3 which seems right because you are trying to have three cells in each direction. The distribution has to be uneven, hence 0 2 and 2 3 When I change the code to use ndiv_mesh_* = 4 and run with periodic or not I get $ PETSC_OPTIONS="" mpiexec -n 8 ./atoms-3D -dm_view DM Object: 8 MPI processes type: da Processor [0] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 0 2 Processor [3] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 0 2 Processor [4] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 4 Processor [5] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 2 4 Processor [6] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 2 4 Processor [7] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 2 4 so it is splitting as expected each rank gets a 2 by 2 by 2 set of indices. Could you please let me know what the problem is that I should be seeing. Barry On Nov 20, 2024, at 7:06 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear Barry, Please, find attached to this email a minimal example of the problem. Run it using 8 MPI processes. Thanks, Miguel On 20 Nov 2024, at 11:48, Miguel Molinos <[email protected]> wrote: Hi Bary: I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP. Thanks, Miguel On 19 Nov 2024, at 18:55, Barry Smith <[email protected]> wrote: I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC Can you please send a reproducible example? Thanks Barry On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear all: It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size. I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed: 210 420 366 732 420 840 732 1464 Am I missing something? Thanks, Miguel <Screenshot 2024-11-19 at 10.56.36.png> <atoms-3D.cpp><Mg-hcp-cube-x17-x10-x10.dump>
Dear Barry: You were right!! The problem is I am using the background DMDA mesh for the domain partitioning of the DMSWarm as in “dm/tutorials/swarm_ex3.c”. And then “DMGetNeighbors” to locate the neighbour ranks, including those in the other side of the domain when I am using periodic bcc. Therefore, if I define the background DMDA to use periodic bcc the particle domain partitioning is uneven but I can locate precisely the periodic ranks. Thanks, Miguel On 20 Nov 2024, at 23:40, MIGUEL MOLINOS PEREZ <[email protected]> wrote: I see… that might be the problem. I’ll check it tomorrow. Thank you! Miguel On 20 Nov 2024, at 22:57, Barry Smith <[email protected]> wrote: On Nov 20, 2024, at 2:38 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Yes, I use the vertex (nodes) of the elements. Then the length between each vertex will be different between periodic and non-periodic case. With 10 points and non-periodic, it will be 1/9, and with periodic it will be 1/10th. Is this what you are asking about? I am using the DMDA as an auxiliar mesh to do the domain partitioning in the DMSWARM. Thanks, Miguel On 20 Nov 2024, at 19:54, Barry Smith <[email protected]> wrote: Are you considering your degrees of freedom as vertex or cell-centered? Say three "elements" per edge. If vertex centered then discretization size is 1/3 if periodic and 1/2 if not periodic If cell-centered then each cell has width 1/3 for both periodic and not periodic but in both cases you can think of the discretization size as constant along the whole cube edge. Is this related to DMSWARM in particular? On Nov 20, 2024, at 12:56 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: I mean that if the dimensions of the cube are 1x1x1 (for example). And I want 10 elements per edge, the discretization size must be 0.1 constant over the whole cube edge. This is not in the code, I just impose the number of elements per edge. Thank you, Miguel On 20 Nov 2024, at 18:52, Barry Smith <[email protected]> wrote: What do you mean by discretization size, and how do I see it in the code? Barry On Nov 20, 2024, at 12:48 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Sorry, I meant that the discretisation size is not constant across the edges of the cube. Miguel On 20 Nov 2024, at 18:36, Barry Smith <[email protected]> wrote: I am sorry, I don't understand the problem. When I run by default with -da_view I get Processor [0] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 0 2 Processor [3] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 0 2 Processor [4] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 3 Processor [5] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 2 3 Processor [6] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 2 3 Processor [7] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 2 3 which seems right because you are trying to have three cells in each direction. The distribution has to be uneven, hence 0 2 and 2 3 When I change the code to use ndiv_mesh_* = 4 and run with periodic or not I get $ PETSC_OPTIONS="" mpiexec -n 8 ./atoms-3D -dm_view DM Object: 8 MPI processes type: da Processor [0] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 0 2 Processor [3] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 0 2 Processor [4] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 4 Processor [5] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 2 4 Processor [6] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 2 4 Processor [7] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 2 4 so it is splitting as expected each rank gets a 2 by 2 by 2 set of indices. Could you please let me know what the problem is that I should be seeing. Barry On Nov 20, 2024, at 7:06 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear Barry, Please, find attached to this email a minimal example of the problem. Run it using 8 MPI processes. Thanks, Miguel On 20 Nov 2024, at 11:48, Miguel Molinos <[email protected]> wrote: Hi Bary: I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP. Thanks, Miguel On 19 Nov 2024, at 18:55, Barry Smith <[email protected]> wrote: I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC Can you please send a reproducible example? Thanks Barry On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear all: It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size. I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed: 210 420 366 732 420 840 732 1464 Am I missing something? Thanks, Miguel <Screenshot 2024-11-19 at 10.56.36.png> <atoms-3D.cpp><Mg-hcp-cube-x17-x10-x10.dump>
I forgot to mention that the solution to the problem is to increase the number of divisions while keeping constant the number of processes. Sorry for the silly question! Thanks, Miguel On 27 Nov 2024, at 15:47, Miguel Molinos <[email protected]> wrote: Dear Barry: You were right!! The problem is I am using the background DMDA mesh for the domain partitioning of the DMSWarm as in “dm/tutorials/swarm_ex3.c”. And then “DMGetNeighbors” to locate the neighbour ranks, including those in the other side of the domain when I am using periodic bcc. Therefore, if I define the background DMDA to use periodic bcc the particle domain partitioning is uneven but I can locate precisely the periodic ranks. Thanks, Miguel On 20 Nov 2024, at 23:40, MIGUEL MOLINOS PEREZ <[email protected]> wrote: I see… that might be the problem. I’ll check it tomorrow. Thank you! Miguel On 20 Nov 2024, at 22:57, Barry Smith <[email protected]> wrote: On Nov 20, 2024, at 2:38 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Yes, I use the vertex (nodes) of the elements. Then the length between each vertex will be different between periodic and non-periodic case. With 10 points and non-periodic, it will be 1/9, and with periodic it will be 1/10th. Is this what you are asking about? I am using the DMDA as an auxiliar mesh to do the domain partitioning in the DMSWARM. Thanks, Miguel On 20 Nov 2024, at 19:54, Barry Smith <[email protected]> wrote: Are you considering your degrees of freedom as vertex or cell-centered? Say three "elements" per edge. If vertex centered then discretization size is 1/3 if periodic and 1/2 if not periodic If cell-centered then each cell has width 1/3 for both periodic and not periodic but in both cases you can think of the discretization size as constant along the whole cube edge. Is this related to DMSWARM in particular? On Nov 20, 2024, at 12:56 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: I mean that if the dimensions of the cube are 1x1x1 (for example). And I want 10 elements per edge, the discretization size must be 0.1 constant over the whole cube edge. This is not in the code, I just impose the number of elements per edge. Thank you, Miguel On 20 Nov 2024, at 18:52, Barry Smith <[email protected]> wrote: What do you mean by discretization size, and how do I see it in the code? Barry On Nov 20, 2024, at 12:48 PM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Sorry, I meant that the discretisation size is not constant across the edges of the cube. Miguel On 20 Nov 2024, at 18:36, Barry Smith <[email protected]> wrote: I am sorry, I don't understand the problem. When I run by default with -da_view I get Processor [0] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 0 2 Processor [3] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 0 2 Processor [4] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 3 Processor [5] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 2 3 Processor [6] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 2 3 Processor [7] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 2 3 which seems right because you are trying to have three cells in each direction. The distribution has to be uneven, hence 0 2 and 2 3 When I change the code to use ndiv_mesh_* = 4 and run with periodic or not I get $ PETSC_OPTIONS="" mpiexec -n 8 ./atoms-3D -dm_view DM Object: 8 MPI processes type: da Processor [0] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2 Processor [1] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 0 2 Processor [2] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 0 2 Processor [3] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 0 2 Processor [4] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 4 Processor [5] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 2 4 Processor [6] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 2 4 Processor [7] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1 X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 2 4 so it is splitting as expected each rank gets a 2 by 2 by 2 set of indices. Could you please let me know what the problem is that I should be seeing. Barry On Nov 20, 2024, at 7:06 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear Barry, Please, find attached to this email a minimal example of the problem. Run it using 8 MPI processes. Thanks, Miguel On 20 Nov 2024, at 11:48, Miguel Molinos <[email protected]> wrote: Hi Bary: I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP. Thanks, Miguel On 19 Nov 2024, at 18:55, Barry Smith <[email protected]> wrote: I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC Can you please send a reproducible example? Thanks Barry On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <[email protected]> wrote: Dear all: It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size. I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed: 210 420 366 732 420 840 732 1464 Am I missing something? Thanks, Miguel <Screenshot 2024-11-19 at 10.56.36.png> <atoms-3D.cpp><Mg-hcp-cube-x17-x10-x10.dump>
participants (2)
Barry Smith -
