Re: [petsc-users] Copy dense matrix into half part of another dense matrix
Please always keep the list in copy. The way you create A is not correct, I’ve attached a fixed code. If you want to keep your own distribution for A (and not the one associated to R_part), you’ll need to first call https://urldefense.us/v3/__https://petsc.org/main/manualpages/Mat/MatCreateS... to redistribute A and then do a MatCopy() of the resulting Mat into R_part Thanks, Pierre $ /Volumes/Data/repositories/petsc/arch-darwin-c-debug-real/bin/mpirun -n 4 ./ex1234 Mat Object: 4 MPI processes type: mpidense 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 Mat Object: 4 MPI processes type: mpidense 2.6219599187040323e+00 1.9661197867318445e+00 1.5218640363910978e+00 3.5202261875977947e+00 3.6311893358251384e+00 2.2279492868785069e+00 2.7505403755038014e+00 3.1546072728892756e+00 1.8416294994524489e+00 2.4676055638467314e+00 2.3185625557889602e+00 2.0401666986599833e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00
On 27 Jan 2025, at 6:53 PM, [email protected] wrote:
Re:
This is a small reproductible example using MatDenseGetSubMatrix
Command: petscmpiexec -n 4 ./example
PetscInt nlines = 8; // lines PetscInt ncolumns = 3; // columns PetscInt random_size = 12; PetscInt rank; PetscInt size;
// Initialize PETSc PetscInitialize(&argc, &args, NULL, NULL);
MPI_Comm_rank(MPI_COMM_WORLD, &rank); MPI_Comm_size(MPI_COMM_WORLD, &size);
// R_full with all values to zero Mat R_full; MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, nlines, ncolumns, NULL, &R_full); MatZeroEntries(R_full); MatView(R_full, PETSC_VIEWER_STDOUT_WORLD);
// Creating and setting A and S to rand values Mat A, S; MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, nlines / 2, random_size, NULL, &A); MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, random_size, ncolumns, NULL, &S); MatSetRandom(A, NULL); MatSetRandom(S, NULL);
// Computing R_part Mat R_part; MatDenseGetSubMatrix(R_full, PETSC_DECIDE, nlines / 2, PETSC_DECIDE, PETSC_DECIDE, &R_part); MatMatMult(A, S, MAT_REUSE_MATRIX, PETSC_DECIDE, &R_part);
// Visualizing R_full MatDenseRestoreSubMatrix(R_full, &R_part); MatView(R_full, PETSC_VIEWER_STDOUT_WORLD);
// Destroying matrices MatDestroy(&R_part); MatDestroy(&R_full);
PetscFinalize(); return 0;
Part of the error output contains….:
"Cannot change/reset row sizes to 1 local 4 global after previously setting them to 2 local 4 global ….”
// Computing R_part Mat R_part; MatMatMult(A, S, MAT_INITIAL_MATRIX, PETSC_DECIDE, &R_part); MatView(R_part, PETSC_VIEWER_STDOUT_WORLD);
Mat R_sub; MatDenseGetSubMatrix(R_full, PETSC_DECIDE, nlines / 2, PETSC_DECIDE, PETSC_DECIDE, &R_sub);
PetscScalar *storage = NULL; MatDenseGetArray(R_part, &storage); PetscScalar *storage_sub = NULL; MatDenseGetArray(R_sub, &storage_sub);
PetscArraycpy(storage_sub, storage, (nlines / 2) * ncolumns);
MatDenseRestoreArray(R_part, &storage); MatDenseRestoreArray(R_sub, &storage_sub);
MatDenseRestoreSubMatrix(R_full, &R_sub);
PetscFinalize(); return 0; ==========================================================
Now Using MatDenseGetArray
Please let me know if I need to clarify something.
Thanks Medane
On 27 Jan 2025, at 16:26, Pierre Jolivet <[email protected]> wrote:
On 27 Jan 2025, at 3:52 PM, Matthew Knepley <[email protected]> wrote:
On Mon, Jan 27, 2025 at 9:23 AM [email protected] <mailto:[email protected]> <[email protected] <mailto:[email protected]>> wrote:
Re:
MatDenseGetSubMatrix in fact could be the best alternative (cleaner code), but as mentioned earlier, I would like to use the smaller matrix R_part to get the result of a MatMatMult operation.
When trying to use MAT_REUSE_MATRIX, this gave an error (expected error I think). On the other side, I mentionned on MatDenseGetSubMatrix page, "The output matrix is not redistributed by PETSc”. So will R_part be a valid output matrix for MatMatMult?
I believe it is, but I am not the expert.
Pierre, can the SubMatrix be used as the output of a MatMatMult()?
It should be, but there may be some limitations due to leading dimensions and what not. By looking at just the single line of code we got from you, I can see at least one issue: it should be MAT_REUSE_MATRIX, not MAT_INITIAL_MATRIX (assuming you got R_part from MatDenseGetSubMatrix). Feel free to share a (minimal) reproducer.
Thanks, Pierre
Matt
Thanks
On 27 Jan 2025, at 14:52, Matthew Knepley <[email protected] <mailto:[email protected]>> wrote:
On Mon, Jan 27, 2025 at 8:42 AM Pierre Jolivet <[email protected] <mailto:[email protected]>> wrote:
On 27 Jan 2025, at 2:23 PM, [email protected] <mailto:[email protected]> wrote:
Dear PETSc users,
I hope this message finds you well. I don’t know If my question is relevant, but I’am currently working with DENSE type matrix, and would like to copy one matrix R_part [ n/2 x m] (resulted from a MatMatMult operation) into another dense matrix R_full [n x m]. Both matrices being on the same communicator, I would like to efficiently copy R_part in the first half of R_full. I have being using MatSetValues, but for large matrices, the subsequent assembling operation is costly.
Could you please share the output of -log_view as well as a single file that will be generated with -info dump (e.g., dump.0, the file associated to process #0)? This shouldn’t be that costly, so there may be an option missing, like MAT_NO_OFF_PROC_ENTRIES. Anyway, if you want to optimize this, the fastest way would be to call MatDenseGetArray[Read,Write]() and then do the necessary PetscArraycpy().
The other alternative (which I think makes cleaner code) is to use
https://urldefense.us/v3/__https://petsc.org/main/manualpages/Mat/MatDenseGe...
to create your R_part matrix. Then you are directly acting on the memory you want when assemble the smaller matrix.
THanks,
Matt
Thanks, Pierre
Please could you suggest me some strategies or functions to do this efficiently.
Thank you for your time and assistance.
Best regards, Tchakorom Medane
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCf... <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfs... >
Re: Thank you Pierre, I really appreciate. I’am testing it right now to access the improvements. BR, Medane
Thanks, Pierre
<ex1234.c>
Re:
Thanks Medane
Re:
Thanks, Pierre
Matt
Thanks
Dear PETSc users,
THanks,
Matt
Thanks, Pierre
participants (2)
medane.tchakorom@univ-fcomte.fr -
Pierre Jolivet
