Hello everyone, I would like to use the PETSc Testing System for testing a package that I am developing. I have read the PETSc developer documentation and have written some tests using the PETSc Test Description Language. I am going through the files in ${PETSC_DIR}/config but I am not able to make the testing system look into the directory tree of my project. Any suggestions? Thanks in advance Daniele
Our testing framework was pretty much tailor-made for the PETSc src tree and as such has many hard-coded paths and decisions. I’m going to go out on a limb and say you probably won’t get this to work... That being said, one of the “base” paths that the testing harness uses to initially find tests is the `TESTSRCDIR` variable in `${PETSC_DIR}/gmakefile.test`. It is currently defined as ``` # TESTSRCDIR is always relative to gmakefile.test # This must be before includes mkfile_path := $(abspath $(lastword $(MAKEFILE_LIST))) TESTSRCDIR := $(dir $(mkfile_path))src ``` You should start by changing this to ``` # TESTSRCDIR is always relative to gmakefile.test # This must be before includes mkfile_path := $(abspath $(lastword $(MAKEFILE_LIST))) TESTSRCDIR ?= $(dir $(mkfile_path))src ``` That way you could run your tests via ``` $ make test TESTSRCDIR=/path/to/your/src/dir ``` I am sure there are many other modifications you will need to make. Best regards, Jacob Faibussowitsch (Jacob Fai - booss - oh - vitch)
On Mar 27, 2023, at 06:14, Daniele Prada <[email protected]> wrote:
Hello everyone,
Any suggestions?
On Mon, Mar 27, 2023 at 10:19 AM Jacob Faibussowitsch <[email protected]> wrote:
I think we can help you get this to work. I have wanted to generalize the test framework for a long time. Everything is build by confg/gmakegentest.py and I think we can get away with just changing paths here and everything will work. Thanks! Matt
Best regards,
Hello everyone,
Any suggestions?
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Dear Matthew, dear Jacob, Thank you very much for your useful remarks. I managed to use the PETSc Testing System by doing as follows: 1. Redefined TESTDIR when running make 2. Used a project tree similar to that of PETSc. For examples, tests for 'package1' are in $MYLIB/src/package1/tests/ 3. cp $PETSC_DIR/gmakefile.test $MYLIB/gmakefile.test Inside gmakefile.test: 4. Right AFTER "-include petscdir.mk" added "-include mylib.mk" to have $MYLIB exported (note: this affects TESTSRCDIR) 5. Redefined variable pkgs as "pkgs := package1" 6. Introduced a few variables to make PETSC_COMPILE.c work: CFLAGS := -I$(MYLIB)/include LDFLAGS = -L$(MYLIB)/lib LDLIBS = -lmylib 7. Changed the call to gmakegentest.py as follows $(PYTHON) $(CONFIGDIR)/gmakegentest.py --petsc-dir=$(PETSC_DIR) --petsc-arch=$(PETSC_ARCH) --testdir=$(TESTDIR) --srcdir=$(MYLIB)/src --pkg-pkgs=$(pkgs) 8. Changed the rule $(testexe.c) as follows: $(call quiet,CLINKER) $(EXEFLAGS) $(LDFLAGS) -o $@ $^ $(PETSC_TEST_LIB) $(LDLIBS) 9. Added the option --srcdir=$(TESTSRCDIR) and set --petsc-dir=$(MYLIB) when calling query_tests.py, for example: TESTTARGETS := $(shell $(PYTHON) $(CONFIGDIR)/query_tests.py --srcdir=$(TESTSRCDIR) --testdir=$(TESTDIR) --petsc-dir=$(MYLIB) --petsc-arch=$(PETSC_ARCH) --searchin=$(searchin) 'name' '$(search)') What do you think? Best, Daniele On Mon, Mar 27, 2023 at 4:38 PM Matthew Knepley <[email protected]> wrote:
Thanks!
Matt
Best regards,
Hello everyone,
Any suggestions?
Great that you got it working. We would accept a merge request that made our infrastructure less PETSc-specific so long as it doesn't push more complexity on the end user. That would likely make it easier for you to pull updates in the future. Daniele Prada <[email protected]> writes:
What do you think?
Best, Daniele
Thanks!
Matt
Best regards,
Hello everyone,
Any suggestions?
Will do, thanks! On Tue, Mar 28, 2023 at 7:28 PM Jed Brown <[email protected]> wrote:
What do you think?
Best, Daniele
On Mon, Mar 27, 2023 at 10:19 AM Jacob Faibussowitsch < [email protected]> wrote:
Thanks!
Matt
Best regards,
Hello everyone,
Any suggestions?
participants (4)
Daniele Prada -
Jacob Faibussowitsch -
Jed Brown -
Matthew Knepley
