Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Hi, I want to use DMPlexDistribute from PETSc for computing overlapping and play with the different partitioners supported. However, after calling DMPlexDistribute, I noticed the elements are renumbered and then the original number is lost. What would be the best way to keep track of the element renumbering? a) Adding an optional parameter to let the user retrieve a vector or "IS" giving the old number? b) Adding a DMLabel (seems a wrong good solution) c) Other idea? Of course, I don't want to loose performances with the need of this "mapping"... Thanks, Eric -- Eric Chamberland, ing., M. Ing Professionnel de recherche GIREF/Université Laval (418) 656-2131 poste 41 22 42
On Wed, Jul 14, 2021 at 1:18 PM Eric Chamberland < [email protected]> wrote:
c) Other idea?
You need to call https://petsc.org/release/docs/manualpages/DM/DMSetUseNatural.html before call DMPlexDistribute(). Then you can call https://petsc.org/release/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin... to map back to the original numbering if you want. This is the same thing that DMDA is doing. Thanks, Matt
Eric
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Hi Matthew, Ok, I did that but it segfault now. Here are the order of the calls: DMPlexCreate DMSetDimension DMPlexBuildFromCellListParallel(...) DMPlexInterpolate PetscPartitioner lPart; DMPlexGetPartitioner(lDMSansOverlap, &lPart); PetscPartitionerSetFromOptions(lPart); DMSetUseNatural(lDMSansOverlap, PETSC_TRUE) DMPlexDistribute DMPlexGlobalToNaturalBegin DMPlexGlobalToNaturalEnd But it gives me the following error: 0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Petsc has generated inconsistent data [0]PETSC ERROR: DM global to natural SF not present. If DMPlexDistribute() was called and a section was defined, report to [email protected]. [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021 [0]PETSC ERROR: MEF++.dev on a named rohan by ericc Wed Jul 14 16:57:48 2021 [0]PETSC ERROR: Configure options --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7 --with-mpi-compilers=1 --with-mpi-dir=/opt/openmpi-4.1.0_gcc7 --with-cxx-dialect=C++14 --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0 --download-ml=yes --download-mumps=yes --download-superlu=yes --download-hpddm=yes --download-slepc=yes --download-superlu_dist=yes --download-parmetis=yes --download-ptscotch=yes --download-metis=yes --download-strumpack=yes --download-suitesparse=yes --download-hypre=yes --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64 --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/.. --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/.. --with-scalapack=1 --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64" [0]PETSC ERROR: #1 DMPlexGlobalToNaturalBegin() at /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:245 What did I missed? Thanks a lot! Eric On 2021-07-14 3:09 p.m., Matthew Knepley wrote:
On Wed, Jul 14, 2021 at 1:18 PM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
c) Other idea?
You need to call
https://petsc.org/release/docs/manualpages/DM/DMSetUseNatural.html <https://petsc.org/release/docs/manualpages/DM/DMSetUseNatural.html>
https://petsc.org/release/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin... <https://petsc.org/release/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html>
Matt
Eric
On Wed, Jul 14, 2021 at 4:58 PM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
DMPlexCreate
DMSetDimension
DMPlexInterpolate
DMPlexDistribute
What did I missed?
Ah, there was a confusion of intent. GlobalToNatural() is for people that want data transformed back into the original order. I thought that was what you wanted. If you just want mesh points in the original order, we give you the transformation as part of the output of DMPlexDistribute(). The migrationSF that is output maps the original point to the distributed point. You run it backwards to get the original ordering.
Thanks, Matt
Thanks a lot!
c) Other idea?
You need to call
Matt
Eric
Matt
Hi, that seems to work better! However, if I understand well the migrationSF is giving information on the originating process where the elements have been migrated from. Is there a PETSc way to either: 1) send back the information to the originating process (somewhat "inverting" the migrationSF) ? So I can retrieve the "partitioning array" (just like the "part" parameter in ParMETIS_V3_PartMeshKway) on the sender process. or 2) Have the pre-migrationSF: I mean I would like to extract the "where are the elements going to be sent?" (again like "part" parameter) If not, I can always build the communication myself... Thanks, Eric
Hi Matthew, we did it with PetscSFCreateInverseSF ! It is working well without overlap, so we can go forward with this and compute the overlap afterward with DMPlexDistributeOverlap. Thanks, Eric On 2021-07-20 10:39 p.m., Eric Chamberland wrote:
Matt
or
Eric
On Wed, Jul 21, 2021 at 2:54 PM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
That works. I think you can also do what you want with
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PetscSF/PetscSF... This is how I usually make the 2-sided information, unless I really need the inverse SF. Thanks, Matt
Eric
Matt
or
Eric
Hi, I come back with _almost_ the original question: I would like to add an integer information (*our* original element number, not petsc one) on each element of the DMPlex I create with DMPlexBuildFromCellListParallel. I would like this interger to be distribruted by or the same way DMPlexDistribute distribute the mesh. Is it possible to do this? Thanks, Eric On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
c) Other idea?
Eric
On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland < [email protected]> wrote:
I think we already have support for what you want. If you call https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html before DMPlexDistribute(), it will compute a PetscSF encoding the global to natural map. You can get it with https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.ht... and use it with https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.ht... Is this sufficient? Thanks, Matt
Eric
c) Other idea?
Eric
Hi Matthew, we tried to use that. Now, we discovered that: 1- even if we "ask" for sfNatural creation with DMSetUseNatural, it is not created because DMPlexCreateGlobalToNaturalSF looks for a "section": this is not documented in DMSetUseNaturalso we are asking ourselfs: "is this a permanent feature or a temporary situation?" 2- We then tried to create a "section" in different manners: we took the code into the example petsc/src/dm/impls/plex/tests/ex15.c. However, we ended up with a segfault: corrupted size vs. prev_size [rohan:07297] *** Process received signal *** [rohan:07297] Signal: Aborted (6) [rohan:07297] Signal code: (-6) [rohan:07297] [ 0] /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80] [rohan:07297] [ 1] /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b] [rohan:07297] [ 2] /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585] [rohan:07297] [ 3] /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7] [rohan:07297] [ 4] /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea] [rohan:07297] [ 5] /lib64/libc.so.6(+0x86036)[0x7f6f10a03036] [rohan:07297] [ 6] /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3] [rohan:07297] [ 7] /lib64/libc.so.6(+0x88740)[0x7f6f10a05740] [rohan:07297] [ 8] /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8] [rohan:07297] [ 9] /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064] [rohan:07297] [10] /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce] [rohan:07297] [11] /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0] [rohan:07297] [12] /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2] [rohan:07297] [13] /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210] [rohan:07297] [14] /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed] [rohan:07297] [15] /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d] [rohan:07297] [16] /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18] [rohan:07297] [17] /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602] [rohan:07297] [18] /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21] If we do not create a section, the call to DMPlexDistribute is successful, but DMPlexGetGlobalToNaturalSF return a null SF pointer... Here are the operations we are calling ( this is almost the code we are using, I just removed verifications and creation of the connectivity which use our parallel structure and code): =========== PetscInt* lCells = 0; PetscInt lNumCorners = 0; PetscInt lDimMail = 0; PetscInt lnumCells = 0; //At this point we create the cells for PETSc expected input for DMPlexBuildFromCellListParallel and set lNumCorners, lDimMail and lnumCells to correct values. ... DM lDMBete = 0 DMPlexCreate(lMPIComm,&lDMBete); DMSetDimension(lDMBete, lDimMail); DMPlexBuildFromCellListParallel(lDMBete, lnumCells, PETSC_DECIDE, pLectureElementsLocaux.reqNbTotalSommets(), lNumCorners, lCells, PETSC_NULL); DM lDMBeteInterp = 0; DMPlexInterpolate(lDMBete, &lDMBeteInterp); DMDestroy(&lDMBete); lDMBete = lDMBeteInterp; DMSetUseNatural(lDMBete,PETSC_TRUE); PetscSF lSFMigrationSansOvl = 0; PetscSF lSFMigrationOvl = 0; DM lDMDistribueSansOvl = 0; DM lDMAvecOverlap = 0; PetscPartitioner lPart; DMPlexGetPartitioner(lDMBete, &lPart); PetscPartitionerSetFromOptions(lPart); PetscSection section; PetscInt numFields = 1; PetscInt numBC = 0; PetscInt numComp[1] = {1}; PetscInt numDof[4] = {1, 0, 0, 0}; PetscInt bcFields[1] = {0}; IS bcPoints[1] = {NULL}; DMSetNumFields(lDMBete, numFields); DMPlexCreateSection(lDMBete, NULL, numComp, numDof, numBC, bcFields, bcPoints, NULL, NULL, §ion); DMSetLocalSection(lDMBete, section); DMPlexDistribute(lDMBete, 0, &lSFMigrationSansOvl, &lDMDistribueSansOvl); // segfault! =========== So we have other question/remarks: 3- Maybe PETSc expect something specific that is missing/not verified: for example, we didn't gave any coordinates since we just want to partition and compute overlap for the mesh... and then recover our element numbers in a "simple way" 4- We are telling ourselves it is somewhat a "big price to pay" to have to build an unused section to have the global to natural ordering set ? Could this requirement be avoided? 5- Are there any improvement towards our usages in 3.16 release? Thanks, Eric On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html <https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html>
https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.ht... <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html>
and use it with
https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.ht... <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html>
Is this sufficient?
Matt
Eric
On 2021-07-14 1:18 p.m., Eric Chamberland wrote: > Hi, > > I want to use DMPlexDistribute from PETSc for computing overlapping > and play with the different partitioners supported. > > However, after calling DMPlexDistribute, I noticed the elements are > renumbered and then the original number is lost. > > What would be the best way to keep track of the element renumbering? > > a) Adding an optional parameter to let the user retrieve a vector or > "IS" giving the old number? > > b) Adding a DMLabel (seems a wrong good solution) > > c) Other idea? > > Of course, I don't want to loose performances with the need of this > "mapping"... > > Thanks, > > Eric > -- Eric Chamberland, ing., M. Ing Professionnel de recherche GIREF/Université Laval (418) 656-2131 poste 41 22 42
On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
I think explaining this will help clear up a lot.
What the Natural2Global map does is permute a solution vector into the ordering that it would have had prior to mesh distribution. Now, in order to do this permutation, I need to know the original (global) data layout. If it is not specified _before_ distribution, we cannot build the permutation. The section describes the data layout, so I need it before distribution. I cannot think of another way that you would implement this, but if you want something else, let me know.
I am not sure what happened here, but if you could send a sample code, I will figure it out.
Yes, it just ignores it in this case because it does not have a global layout.
I don't think so. There would have to be _some_ way of describing your data layout in terms of mesh points, and I do not see how you could use less memory doing that.
Let me try and run the code above. Thanks, Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
c) Other idea?
Eric
Hi Matthew, we tried to reproduce the error in a simple example. The context is the following: We hard coded the mesh and initial partition into the code (see sConnectivity and sInitialPartition) for 2 ranks and try to create a section in order to use the DMPlexNaturalToGlobalBegin function to retreive our initial element numbers. Now the call to DMPlexDistribute give different errors depending on what type of component we ask the field to be created. For our objective, we would like a global field to be created on elements only (like a P0 interpolation). We now have the following error generated: [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Petsc has generated inconsistent data [0]PETSC ERROR: Inconsistency in indices, 18 should be 17 [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021 [0]PETSC ERROR: ./bug on a named rohan by ericc Wed Oct 20 14:52:36 2021 [0]PETSC ERROR: Configure options --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7 --with-mpi-compilers=1 --with-mpi-dir=/opt/openmpi-4.1.0_gcc7 --with-cxx-dialect=C++14 --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0 --download-ml=yes --download-mumps=yes --download-superlu=yes --download-hpddm=yes --download-slepc=yes --download-superlu_dist=yes --download-parmetis=yes --download-ptscotch=yes --download-metis=yes --download-strumpack=yes --download-suitesparse=yes --download-hypre=yes --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64 --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/.. --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/.. --with-scalapack=1 --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64" [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409 [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184 [0]PETSC ERROR: #3 DMPlexDistribute() at /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733 [0]PETSC ERROR: #4 main() at bug_section.cc:159 [0]PETSC ERROR: No PETSc Option Table entries [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] Hope the attached code is self-explaining, note that to make it short, we have not included the final part of it, just the buggy part we are encountering right now... Thanks for your insights, Eric On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
Thanks for making the example. I tweaked it slightly. I put in a test case that just makes a parallel 7 x 10 quad mesh. This works fine. Thus I think it must be something connected with the original mesh. It is hard to get a handle on it without the coordinates. Do you think you could put the coordinate array in? I have added the code to load them (see attached file).
Thanks, Matt
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
c) Other idea?
Eric
Hi Matthew, ok, I started back from your ex44.c example and added the global array of coordinates. I just have to code the creation of the local coordinates now. Eric On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
Hi Matthew,
[0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Petsc has generated inconsistent data [0]PETSC ERROR: Inconsistency in indices, 18 should be 17 [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting. [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021 [0]PETSC ERROR: ./bug on a named rohan by ericc Wed Oct 20 14:52:36 2021 [0]PETSC ERROR: Configure options --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7 --with-mpi-compilers=1 --with-mpi-dir=/opt/openmpi-4.1.0_gcc7 --with-cxx-dialect=C++14 --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0 --download-ml=yes --download-mumps=yes --download-superlu=yes --download-hpddm=yes --download-slepc=yes --download-superlu_dist=yes --download-parmetis=yes --download-ptscotch=yes --download-metis=yes --download-strumpack=yes --download-suitesparse=yes --download-hypre=yes --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64 --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/.. --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/.. --with-scalapack=1 --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64" [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409 [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184 [0]PETSC ERROR: #3 DMPlexDistribute() at /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733 [0]PETSC ERROR: #4 main() at bug_section.cc:159 [0]PETSC ERROR: No PETSc Option Table entries [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] <mailto:[email protected]>----------
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
Okay, I ran it. Something seems off with the mesh. First, I cannot simply explain the partition. The number of shared vertices and edges does not seem to come from a straight cut. Second, the mesh look scrambled on output. Thanks, Matt On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
Hi Matthew,
Matt
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
c) Other idea?
Eric
Here is a screenshot of the partition I hard coded (top) and vertices/element numbers (down): I have not yet modified the ex44.c example to properly assign the coordinates... (but I would not have done it like it is in the last version because the sCoords array is the global array with global vertices number) I will have time to do this tomorrow... Maybe I can first try to reproduce all this with a smaller mesh? Eric On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
Matt
On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
Hi Matthew,
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
That might make it easier to find a problem. Thanks! Matt
Matt
Hi Matthew,
Hi Matthew,
Matt
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
c) Other idea?
Eric
Hi Matthew, the smallest mesh which crashes the code is a 2x5 mesh: See the modified ex44.c With smaller meshes(2x2, 2x4, etc), it passes... But it bugs latter when I try to use DMPlexNaturalToGlobalBegin but let's keep that other problem for later... Thanks a lot for helping digging into this! :) Eric On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
On Tue, Oct 26, 2021 at 1:35 PM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
Thanks!
Matt
Eric
Matt
Hi Matthew,
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
Hi Matthew, the smallest mesh which crashes the code is a 2x5 mesh: See the modified ex44.c With smaller meshes(2x2, 2x4, etc), it passes... But it bugs latter when I try to use DMPlexNaturalToGlobalBegin but let's keep that other problem for later... Thanks a lot for helping digging into this! :) Eric (sorry if you received this for a 2nd times, I have trouble with my mail) On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
Thanks!
Matt
Eric
Matt
Hi Matthew,
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
On Wed, Oct 27, 2021 at 8:29 AM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
I have made a small fix in this branch https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n It seems to run for me. Can you check it? Thanks, Matt
Eric
Thanks!
Matt
Matt
Hi Matthew,
Hi Matthew,
Matt
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
c) Other idea?
Eric
Great! Thanks Matthew, it is working for me up to that point! We are continuing the ex44.c and forward it to you at the next blocking point... Eric On 2021-10-27 11:14 a.m., Matthew Knepley wrote:
On Wed, Oct 27, 2021 at 8:29 AM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
Hi Matthew,
https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n <https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n>
Matt
Eric
Thanks!
Matt
Eric
Matt
Hi Matthew,
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
Hi Matthew, we continued the example. Now it must be our misuse of PETSc that produced the wrong result. As stated into the code: // The call to DMPlexNaturalToGlobalBegin/End does not produce our expected result... // In lGlobalVec, we expect to have: /* * Process [0] * 2. * 4. * 8. * 3. * 9. * Process [1] * 1. * 5. * 7. * 0. * 6. * * but we obtained: * * Process [0] * 2. * 4. * 8. * 0. * 0. * Process [1] * 0. * 0. * 0. * 0. * 0. */ (see attached ex44.c) Thanks, Eric On 2021-10-27 1:25 p.m., Eric Chamberland wrote:
Great!
Eric
Hi Matthew,
Matt
Eric
Thanks!
Matt
Eric
Matt
Hi Matthew,
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/> -- Eric Chamberland, ing., M. Ing Professionnel de recherche GIREF/Université Laval (418) 656-2131 poste 41 22 42
Hi Matthew, we do not know if DMPlexNaturalToGlobalBegin/End is buggy or if it is our comprehension of what it should do that is wrong... Would you just check if what we try to do from line 313 to 356 is good or wrong? The expected result is that the global vector "lGlobalVec" contains the element numbers from the initial partition that have been put into "lNatVec". Thanks a lot for any insights!! Eric On 2021-10-27 2:32 p.m., Eric Chamberland wrote:
Hi Matthew,
Eric
Great!
Eric
Hi Matthew,
Matt
Eric
Thanks!
Matt
Eric
Matt
Hi Matthew,
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
On Sun, Oct 31, 2021 at 10:07 AM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
Okay, I have found the problem.I confess to not actually looking very closely at the implementation before. GlobalToNatural was assuming that the "natural" was also sequential, and looking at it all the tests are eq-to-parallel distribution. I need to fix it for a parallel natural state. Hopefully it will not take me long.
Thanks, Matt
Eric
Hi Matthew,
Great!
Hi Matthew,
Matt
Eric
Thanks!
Matt
Matt
Hi Matthew,
Hi Matthew,
Matt
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
c) Other idea?
Eric
Hi Matthew, ok, good news then! :) Meanwhile, I tested it the "other way" with DMPlexGlobalToNaturalBegin/End and it does not give a "sensed" result neither. Probably it does something like "GlobalToSequential" too? Thanks! Eric On 2021-11-01 3:25 p.m., Matthew Knepley wrote:
On Sun, Oct 31, 2021 at 10:07 AM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
Hi Matthew,
Matt
Eric
Hi Matthew,
Eric
Great!
Eric
Hi Matthew,
Matt
Eric
Thanks!
Matt
Eric
Matt
Hi Matthew,
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
On Mon, Nov 1, 2021 at 5:24 PM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
I am not sure how it worked before, but I think I have it fixed. I get the output you expect for the test. I force-pushed the branch so you will have to check it out again. Thanks! Matt
Thanks!
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Great!
Hi Matthew,
Matt
Eric
Thanks!
Matt
Matt
Hi Matthew,
Hi Matthew,
Matt
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
c) Other idea?
Eric
Hi Matthew, yes, it all works now! I modified the example to do a NaturalToGlobal then a GlobalToNatural and test if we have the good result... The test would just need that we "force" the computed partition to a given result, then we could check the result of the NaturalToGlobal independently of the partitioner... Thanks a lot! Eric On 2021-11-02 5:16 a.m., Matthew Knepley wrote:
On Mon, Nov 1, 2021 at 5:24 PM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
Hi Matthew,
Thanks!
Matt
Thanks!
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Eric
Great!
Eric
Hi Matthew,
Matt
Eric
Thanks!
Matt
Eric
Matt
Hi Matthew,
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
On Tue, Nov 2, 2021 at 10:27 PM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
Thanks a lot!
No problem. Thanks for generating a great test. I will get this into the CI tonight.
Thanks, Matt
Eric
Hi Matthew,
Thanks!
Matt
Thanks!
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Great!
Hi Matthew,
Matt
Eric
Thanks!
Matt
Matt
Hi Matthew,
Hi Matthew,
Matt
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
c) Other idea?
Eric
Hi Matthew, we are continuing our developments around the overlap (funny to say... ) and we have a question about the "adjacency" used. It is said into the documentation of DMPlexDistributeOverlap that: "The user can control the definition of adjacency for the mesh using DMSetAdjacency(). They should choose the combination appropriate for the function representation on the mesh." We expected that this could influence whether the overlap computed includes cells that touch a domain by only one vertex for example. But we tried "all" combinations of useCone and useClosure on each DM we create in for the computation of the overlap (as in ex44.c we shared with you) but the computed overlap is always the same! However, we have not understood which "field" number to pass, so we used both PETSC_DEFAULT and DMSetBasicAdjacency but it makes no differences... Any clue what's wrong? Thanks, Eric On 2021-11-03 7:41 a.m., Matthew Knepley wrote:
On Tue, Nov 2, 2021 at 10:27 PM Eric Chamberland <[email protected] <mailto:[email protected]>> wrote:
Hi Matthew,
Thanks a lot!
Matt
Eric
Hi Matthew,
Thanks!
Matt
Thanks!
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Eric
Great!
Eric
Hi Matthew,
Matt
Eric
Thanks!
Matt
Eric
Matt
Hi Matthew,
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
On Wed, Nov 10, 2021 at 3:08 PM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
Okay, so the PETSC_DEFAULT one is what is used for topology. There are two separate uses for adjacency info. First, for this kind of topological extension, and the second is for calculating Jacobians. You should be able to see the difference between FEM and FVM in just the case of a 2x2 mesh where each process gets 1 cell. With FEM, the overlap is the whole mesh, whereas with FVM it leaves out the diagonal partner. Thanks, Matt
Eric
Hi Matthew,
Thanks a lot!
Matt
Eric
Hi Matthew,
Thanks!
Matt
Thanks!
Eric
Hi Matthew,
Matt
Eric
Hi Matthew,
Great!
Hi Matthew,
Matt
Eric
Thanks!
Matt
Matt
Hi Matthew,
Hi Matthew,
Matt
Hi Matthew,
Matt
Eric
and use it with
Is this sufficient?
Matt
Eric
c) Other idea?
Eric
Hi Matthew, I have joined the ex44.c example so you can see that we see. The problem is about the "f" field number which I can't see any clue in the documentation to what to put there... We are missing some information maybe written elsewhere? I have tried 3 different calls (lines 180-182) with comments aside: //ierr = DMSetBasicAdjacency(ddm, PETSC_TRUE, PETSC_FALSE); CHKERRQ(ierr); //This works: it give only 2 cells for the overlap //ierr = DMSetAdjacency(ddm, 0, PETSC_TRUE, PETSC_FALSE); CHKERRQ(ierr); //This works too, but why do I have to use field #0 ??? Is it a convention? ierr = DMSetAdjacency(ddm, PETSC_DEFAULT, PETSC_TRUE, PETSC_FALSE); CHKERRQ(ierr); //This does not works: it give 3 cells for the overlap instead of 2. Also, do you think your gitlab/knepley/fix-plex-g2n branch will find it's way into next or main? ;) Thanks, Eric On 2021-11-10 3:26 p.m., Matthew Knepley wrote:
Matt
On Wed, Nov 10, 2021 at 11:45 PM Eric Chamberland < [email protected]> wrote:
Hi Matthew,
Okay, I will fix the docs. I will run it, but I think I see what is happening here. The default is used _only_ when no fields are defined. This is to support the case of just using Plex without any field definitions. Once you define fields, we let you have a different adjacency for each field, so that Jacobian layout can be customized. However, what is used for topology then? Right now, I believe it is field 0. It sounds like I need a flag to tell me whether the user set something, so we can have better defaults.
Put in the MR today. Thanks, Matt
Eric
Matt
participants (2)
Eric Chamberland -
Matthew Knepley
