Fortran preprocessor not work in pets-dev
Hi All, My code has some FPP. It works fine in PETSc 3.18 and earlier version, but stops working in the latest PETSc-Dev. For example the following FPP STANDARD_FORTRAN is not recognized. #ifdef STANDARD_FORTRAN 1 format(15x,1000a15) 2 format(1pe15.6e3,1000(1pe15.6e3)) #else 1 format(15x,<ncol>a15) 2 format(1pe15.6e3,<ncol>(1pe15.6e3)) #endif In the makefile, I define the preprocessor as PPFLAGS. PPFLAGS := -DLINUX -DRELEASE -DRELEASE_X64 -DSTANDARD_FORTRAN … exe: $(OBJS) chkopts -${FLINKER} $(FFLAGS) $(FPPFLAGS) $(CPPFLAGS) -o $(EXENAME) $(OBJS) ${PETSC_LIB} ${LIS_LIB} ${DLIB} ${SLIB} Any idea on this problem? All the best,
On Sat, 6 May 2023, Danyang Su wrote:
Hi All,
#else
#endif
Shouldn't this be FPPFLAGS? Can you send us a simple test case [with the makefile] that we can try to demonstrate this problem? Satish
All the best,
Hi Satish, Sorry, this is a typo when copy to the email. I use FPPFLAGS in the makefile. Not sure why this occurs. Actually not only the preprocessor fails, the petsc initialize does not work either. Attached is a very simple fortran code and below is the test results. Looks like the petsc is not properly installed. I am working on macOS Monterey version 12.5 (Intel Xeon W processor). Compiled using petsc-3.18 (base) ➜ petsc-dev-fppflags mpiexec -n 4 ./petsc_fppflags compiled by STANDARD_FORTRAN compiler called by rank 0 called by rank 1 called by rank 2 called by rank 3 compiled using petsc-dev (base) ➜ petsc-dev-fppflags mpiexec -n 4 ./petsc_fppflags called by rank 2 called by rank 2 called by rank 2 called by rank 2 Thanks, Danyang On 2023-05-06, 10:22 PM, "Satish Balay" <[email protected] <mailto:[email protected]>> wrote: On Sat, 6 May 2023, Danyang Su wrote:
Hi All,
#else
#endif
All the best,
Perhaps you are not using the latest 'main' (or release) branch? I get (with current main): $ mpiexec -n 4 ./petsc_fppflags compiled by STANDARD_FORTRAN compiler called by rank 0 called by rank 1 called by rank 2 called by rank 3 There was a issue with early petsc-3.19 release - here one had to reorder the lines from: FPPFLAGS = include ${PETSC_DIR}/lib/petsc/conf/variables include ${PETSC_DIR}/lib/petsc/conf/rules to include ${PETSC_DIR}/lib/petsc/conf/variables include ${PETSC_DIR}/lib/petsc/conf/rules FPPFLAGS = But this is fixed in latest release and main branches. Satish On Sun, 7 May 2023, Danyang Su wrote:
Hi Satish,
Danyang
Hi All,
#else
#endif
Satish
All the best,
Hi Satish, Exactly. Something went wrong when I pull the remote content last week. I made a clean download of dev version and the problem is solved. Thanks, Danyang On 2023-05-07, 7:14 AM, "Satish Balay" <[email protected] <mailto:[email protected]>> wrote: Perhaps you are not using the latest 'main' (or release) branch? I get (with current main): $ mpiexec -n 4 ./petsc_fppflags compiled by STANDARD_FORTRAN compiler called by rank 0 called by rank 1 called by rank 2 called by rank 3 There was a issue with early petsc-3.19 release - here one had to reorder the lines from: FPPFLAGS = include ${PETSC_DIR}/lib/petsc/conf/variables include ${PETSC_DIR}/lib/petsc/conf/rules to include ${PETSC_DIR}/lib/petsc/conf/variables include ${PETSC_DIR}/lib/petsc/conf/rules FPPFLAGS = But this is fixed in latest release and main branches. Satish On Sun, 7 May 2023, Danyang Su wrote:
Hi Satish,
Danyang
On 2023-05-06, 10:22 PM, "Satish Balay" <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> wrote:
Hi All,
#else
#endif
Satish
All the best,
participants (2)
Danyang Su -
Satish Balay
