mkl_cpardiso halt on petsc-3.16.x
Hi all, On petsc3.12, I successfully run the linear solver mkl cpardiso on parallel environment. However, with the exactly same code, petsc-3.16 halt [0] PCSetUp(): Setting up PC for first time ---------------------------------------- MKL_CPARDISO Options: -mat_mkl_cpardiso_65 <now 0 : formerly 0>: Suggested number of threads to use within MKL_CPARDISO (None) -mat_mkl_cpardiso_66 <now 1 : formerly 1>: Maximum number of factors with identical sparsity structure that must be kept in memory at the same time (None) -mat_mkl_cpardiso_67 <now 1 : formerly 1>: Indicates the actual matrix for the solution phase (None) -mat_mkl_cpardiso_68 <now 0 : formerly 0>: Message level information (None) -mat_mkl_cpardiso_69 <now 11 : formerly 11>: Defines the matrix type (None) -mat_mkl_cpardiso_1 <now 1 : formerly 1>: Use default values (None) <--------- halt here Regards Gong Ding
participants (1)
Gong Ding
