Vector 'Vec_0x84000002_0' (argument #1) was locked for read-only access
Hi all, I updated PETSc to 3.22.1, and now my code run with the following error message. Any idea this may happen? In the entire code, VecGetArray() are used in the following places: void PETScApp::setupPETScIC() { PetscScalar *uu; VecGetArray(u, &uu); _sim->setupPETScIC(uu); VecRestoreArray(u, &uu); } PetscErrorCode snesFormFunction(SNES /*snes*/, Vec u, Vec f, void * appCtx) { PETScApp * petscApp = (PETScApp *)appCtx; // zero out residuals VecZeroEntries(petscApp->res_tran); VecZeroEntries(petscApp->res_spatial); // get vectors PetscScalar *uu, *res_tran, *res_spatial; VecGetArray(u, &uu); VecGetArray(petscApp->res_tran, &res_tran); VecGetArray(petscApp->res_spatial, &res_spatial); // use the most updated solution vector to update solution, to compute RHS and transient residuals petscApp->_sim->updateSolutions(uu); petscApp->_sim->updateAuxVariables(); petscApp->_sim->computeTranRes(res_tran); petscApp->_sim->computeSpatialRes(res_spatial); // restore vectors VecRestoreArray(u, &uu); VecRestoreArray(petscApp->res_tran, &res_tran); VecRestoreArray(petscApp->res_spatial, &res_spatial); // assemble final residuals: f = transient + spatial VecWAXPY(f, 1.0, petscApp->res_tran, petscApp->res_spatial); PetscFunctionReturn(PETSC_SUCCESS); } PS: PETSc is available provided by moose env. -Ling Time Step 1, time = 0.1, dt = 0.1 [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Object is in wrong state [0]PETSC ERROR: Vector 'Vec_0x84000002_0' (argument #1) was locked for read-only access in unknown_function() at unknown file:0 (line numbers only accurate to function begin) [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc! [0]PETSC ERROR: Option left: name:-i value: tests/hc1d.i source: command line [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!a... for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: unknown GIT Date: unknown [0]PETSC ERROR: ./open_phase-opt with 1 MPI process(es) and PETSC_ARCH on CSI365324.local by lingzou Mon Jan 20 09:20:20 2025 [0]PETSC ERROR: Configure options: --with-64-bit-indices --with-cxx-dialect=C++17 --with-debugging=no --with-fortran-bindings=0 --with-mpi=1 --with-openmp=1 --with-strict-petscerrorcode=1 --with-shared-libraries=1 --with-sowing=0 --download-fblaslapack=1 --download-hpddm=1 --download-hypre=1 --download-metis=1 --download-mumps=1 --download-ptscotch=1 --download-parmetis=1 --download-scalapack=1 --download-slepc=1 --download-strumpack=1 --download-superlu_dist=1 --with-hdf5-dir=/Users/lingzou/miniforge/envs/moose --with-make-np=8 --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-x=0 --with-ssl=0 --with-mpi-dir=/Users/lingzou/miniforge/envs/moose AR=arm64-apple-darwin20.0.0-ar RANLIB=arm64-apple-darwin20.0.0-ranlib CFLAGS="-ftree-vectorize -fPIC -fstack-protector-strong -O2 -pipe -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " CXXFLAGS="-ftree-vectorize -fPIC -fstack-protector-strong -O2 -pipe -stdlib=libc++ -fvisibility-inlines-hidden -fmessage-length=0 -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " CPPFLAGS="-D_FORTIFY_SOURCE=2 -isystem /Users/lingzou/miniforge/envs/moose/include -mmacosx-version-min=11.3 " FFLAGS="-march=armv8.3-a -ftree-vectorize -fPIC -fno-stack-protector -O2 -pipe -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " FCFLAGS="-march=armv8.3-a -ftree-vectorize -fPIC -fno-stack-protector -O2 -pipe -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " LDFLAGS="-Wl,-headerpad_max_install_names -Wl,-rpath,/Users/lingzou/miniforge/envs/moose/lib -L/Users/lingzou/miniforge/envs/moose/lib -Wl,-ld_classic -Wl,-commons,use_dylibs" --prefix=/Users/lingzou/miniforge/envs/moose/petsc [0]PETSC ERROR: #1 VecSetErrorIfLocked() at /opt/civet0/build_0/_env/conda-bld/moose-petsc_1735976555173/work/include/petscvec.h:649 [0]PETSC ERROR: #2 VecGetArray() at /opt/civet0/build_0/_env/conda-bld/moose-petsc_1735976555173/work/src/vec/vec/interface/rvector.c:2020 NL Step = 0, fnorm = 1.10935E+30
I figure that it is most likely related to using VecGetArrayRead/VecRestoreArrayRead in one of the places. I will update later. -Ling From: petsc-users <[email protected]> on behalf of Zou, Ling via petsc-users <[email protected]> Date: Monday, January 20, 2025 at 9:27 AM To: [email protected] <[email protected]> Subject: [petsc-users] Vector 'Vec_0x84000002_0' (argument #1) was locked for read-only access Hi all, I updated PETSc to 3.22.1, and now my code run with the following error message. Any idea this may happen? In the entire code, VecGetArray() are used in the following places: void PETScApp::setupPETScIC() { PetscScalar *uu; VecGetArray(u, &uu); _sim->setupPETScIC(uu); VecRestoreArray(u, &uu); } PetscErrorCode snesFormFunction(SNES /*snes*/, Vec u, Vec f, void * appCtx) { PETScApp * petscApp = (PETScApp *)appCtx; // zero out residuals VecZeroEntries(petscApp->res_tran); VecZeroEntries(petscApp->res_spatial); // get vectors PetscScalar *uu, *res_tran, *res_spatial; VecGetArray(u, &uu); VecGetArray(petscApp->res_tran, &res_tran); VecGetArray(petscApp->res_spatial, &res_spatial); // use the most updated solution vector to update solution, to compute RHS and transient residuals petscApp->_sim->updateSolutions(uu); petscApp->_sim->updateAuxVariables(); petscApp->_sim->computeTranRes(res_tran); petscApp->_sim->computeSpatialRes(res_spatial); // restore vectors VecRestoreArray(u, &uu); VecRestoreArray(petscApp->res_tran, &res_tran); VecRestoreArray(petscApp->res_spatial, &res_spatial); // assemble final residuals: f = transient + spatial VecWAXPY(f, 1.0, petscApp->res_tran, petscApp->res_spatial); PetscFunctionReturn(PETSC_SUCCESS); } PS: PETSc is available provided by moose env. -Ling Time Step 1, time = 0.1, dt = 0.1 [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Object is in wrong state [0]PETSC ERROR: Vector 'Vec_0x84000002_0' (argument #1) was locked for read-only access in unknown_function() at unknown file:0 (line numbers only accurate to function begin) [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc! [0]PETSC ERROR: Option left: name:-i value: tests/hc1d.i source: command line [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!b... <https://urldefense.us/v3/__https:/petsc.org/release/faq/__;!!G_uCfscf7eWS!afeyp9qigjd3lpaTTPGFhRudAAw-yvYL974yeq5bR6xXsoGjkjeuvOHT8IxSXBtbGT-ULg-27kGV3D9K5Mo$> for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: unknown GIT Date: unknown [0]PETSC ERROR: ./open_phase-opt with 1 MPI process(es) and PETSC_ARCH on CSI365324.local by lingzou Mon Jan 20 09:20:20 2025 [0]PETSC ERROR: Configure options: --with-64-bit-indices --with-cxx-dialect=C++17 --with-debugging=no --with-fortran-bindings=0 --with-mpi=1 --with-openmp=1 --with-strict-petscerrorcode=1 --with-shared-libraries=1 --with-sowing=0 --download-fblaslapack=1 --download-hpddm=1 --download-hypre=1 --download-metis=1 --download-mumps=1 --download-ptscotch=1 --download-parmetis=1 --download-scalapack=1 --download-slepc=1 --download-strumpack=1 --download-superlu_dist=1 --with-hdf5-dir=/Users/lingzou/miniforge/envs/moose --with-make-np=8 --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-x=0 --with-ssl=0 --with-mpi-dir=/Users/lingzou/miniforge/envs/moose AR=arm64-apple-darwin20.0.0-ar RANLIB=arm64-apple-darwin20.0.0-ranlib CFLAGS="-ftree-vectorize -fPIC -fstack-protector-strong -O2 -pipe -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " CXXFLAGS="-ftree-vectorize -fPIC -fstack-protector-strong -O2 -pipe -stdlib=libc++ -fvisibility-inlines-hidden -fmessage-length=0 -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " CPPFLAGS="-D_FORTIFY_SOURCE=2 -isystem /Users/lingzou/miniforge/envs/moose/include -mmacosx-version-min=11.3 " FFLAGS="-march=armv8.3-a -ftree-vectorize -fPIC -fno-stack-protector -O2 -pipe -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " FCFLAGS="-march=armv8.3-a -ftree-vectorize -fPIC -fno-stack-protector -O2 -pipe -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " LDFLAGS="-Wl,-headerpad_max_install_names -Wl,-rpath,/Users/lingzou/miniforge/envs/moose/lib -L/Users/lingzou/miniforge/envs/moose/lib -Wl,-ld_classic -Wl,-commons,use_dylibs" --prefix=/Users/lingzou/miniforge/envs/moose/petsc [0]PETSC ERROR: #1 VecSetErrorIfLocked() at /opt/civet0/build_0/_env/conda-bld/moose-petsc_1735976555173/work/include/petscvec.h:649 [0]PETSC ERROR: #2 VecGetArray() at /opt/civet0/build_0/_env/conda-bld/moose-petsc_1735976555173/work/src/vec/vec/interface/rvector.c:2020 NL Step = 0, fnorm = 1.10935E+30
participants (1)
Zou, Ling
