Installing Triangle for PETSc by not using --download
Hi, I need to install PETSc and its dependencies to a linux system, which does not allow git clone from online. Thus I need to install all the dependencies by having their source files. First I downloaded and installed all the dependencies by relying on PETSc on my local linux (which means I used --download=triangle), then tar all of them, and brought them to the cluster. There is an issue with Triangle. I can do make (or cmake using the CMakeList file that Triangle 1.6 provides, although PETSc --download provides Triangle 1.3) and can get "libtriangle.a". But during the PETSc configure step, it fails with the error message below: {$Triangle_Home}/build/libtriangle.a(triangle.c.o): In function `poolinit': triangle.c:(.text+0x15aa): undefined reference to `PetscTrMalloc' {$Triangle_Home}/build/libtriangle.a(triangle.c.o): In function `pooldeinit': triangle.c:(.text+0x1708): undefined reference to `PetscTrFree' ... It seems that I need to let Triangle know that it will be used by PETSc to enable those functions when I install Triangle. Is this correct understanding? If so, how can I configure, install, and link Triangle with PETSc? I have seen some PETSc related commands in configure.py in the root directory of Triangle downloaded by PETSc, but it is not clear how this python script is related or can be used by user like me. Thanks, Mike
Can you try the --with-packages-download-dir option? It tells you the URL to download - and then PETSc configure does the install. Satish -------- balay@p1 /home/balay/petsc (release =) $ ./configure --with-packages-download-dir=$HOME/tmp --download-triangle Download the following packages to /home/balay/tmp triangle ['git://https://bitbucket.org/petsc/pkg-triangle', 'https://bitbucket.org/petsc/pkg-triangle/get/v1.3-p2.tar.gz'] Then run the script again balay@p1 /home/balay/petsc (release =) $ pushd $HOME/tmp ~/tmp ~/petsc balay@p1 /home/balay/tmp $ git clone -q https://bitbucket.org/petsc/pkg-triangle balay@p1 /home/balay/tmp $ popd ~/petsc balay@p1 /home/balay/petsc (release =) $ ./configure --with-packages-download-dir=$HOME/tmp --download-triangle ============================================================================================= Configuring PETSc to compile on your system ============================================================================================= ============================================================================================= Running /home/balay/soft/sowing-1.1.26-p1/bin/bfort to generate Fortran stubs ============================================================================================= ============================================================================================= Trying to download /home/balay/tmp/pkg-triangle for TRIANGLE ============================================================================================= ============================================================================================= Compiling Triangle; this may take several minutes ============================================================================================= ============================================================================================= Installing Triangle; this may take several minutes ============================================================================================= TESTING: checklsame from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:691) ... .. On Fri, 4 Nov 2022, Mike Michell wrote:
Thanks, Mike
Thank you very much. It seems that --download-package={downloaded_dir} is the right way to let PETSc know the source files and let it configures & installs everything as it wants. If I try --with-packages-download-dir, PETSc again tries to connect and get the external packages from online, which I cannot do. Thanks,
Satish
triangle ['git://https://bitbucket.org/petsc/pkg-triangle', ' https://bitbucket.org/petsc/pkg-triangle/get/v1.3-p2.tar.gz']
Thanks, Mike
No - it tells you what to download - and where to place it locally. In my example below - I used 'git clone' but you can use rsync or any other mechanism that you are currently using to copy stuff over. And sure --download-package=/local/location/[tarball,git,dir] also works . Satish
Satish
Thanks, Mike
participants (2)
Mike Michell -
Satish Balay
