Re: [petsc-users] access to matnest block (0,1) ?
I should add a MatNestGetISs() so you can get out the automatically-created ISs. They will have the structure described below. If you want to work with the released version, you should create the ISs yourself.
As a user, having MatNestGetISs would be most convenient.
A has a contigous distribution, so the ISs must respect that. Did you try creating the index sets described above? Please explain "something's wrong".
Finally I understand the relation between the nesting and the index sets. After replacing my incorrect ISs with the correct ones, everything's fine (no more [0]PETSC ERROR: Arguments are incompatible! [0]PETSC ERROR: Could not find index set!). Thanks a lot for your help, Jed, I really appreciate it. dr. ir. Christiaan Klaij CFD Researcher Research & Development E mailto:[email protected] T +31 317 49 33 44 MARIN 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
Pushed to petsc-dev, you have to allocate arrays to hold the returned ISs.
participants (2)
Jed Brown -
Klaij, Christiaan
