Using CUDA Graphs with MatComputeOperator
I have a MatShell object that I want to convert to a MATDENSECUDA. Normally, I use MatComputeOperator for this. However, I would now also like to use a CUDA Graph so that all the calls to MatMult are captured. I can wrap a code like for (int i = 0; i < N; i++) MatMult(A, x,y); in a CUDA Graph, and it runs fine. If I try to wrap MatComputeOperator in a graph, I get runtime errors like cuda error 906 (cudaErrorStreamCaptureImplicit) : operation would make the legacy stream depend on a capturing blocking stream I tried modifying the MatConvert_Shell routine to only put the graph around the main for loop, but that still gives the same errors. Is there a way to use CUDA Graphs here (either through a modified MatConvert_Shell or otherwise)? Thanks, Sreeram
I haven't used CUDA graph with PETSc. Do you happen to have a working example so we can debug? --Junchao Zhang On Tue, May 14, 2024 at 6:08 PM Sreeram R Venkat <[email protected]> wrote:
I have a MatShell object that I want to convert to a MATDENSECUDA. Normally, I use MatComputeOperator for this. However, I would now also like to use a CUDA Graph so that all the calls to MatMult are captured. I can wrap a code like for (int ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd I have a MatShell object that I want to convert to a MATDENSECUDA. Normally, I use MatComputeOperator for this. However, I would now also like to use a CUDA Graph so that all the calls to MatMult are captured. I can wrap a code like
Thanks, Sreeram
I don't have a working example that I can easily send you since the MatShell I have involves a lot of other code. Essentially, I am trying to do something like this: bool graphCreated = false; cudaGraph_t graph; cudaGraphExec_t instance; if (!graphCreated) { gpuErrchk(cudaStreamBeginCapture(s, cudaStreamCaptureModeGlobal)); PetscCall(MatComputeOperator(ShellMat, MATDENSECUDA, &DenseMat)); gpuErrchk(cudaStreamEndCapture(s, &graph)); gpuErrchk(cudaGraphInstantiate(&instance, graph, NULL, NULL, 0)); graphCreated = true; } gpuErrchk(cudaGraphLaunch(instance, s)); gpuErrchk(cudaStreamSynchronize(s)); gpuErrchk(cudaGraphExecDestroy(instance)); gpuErrchk(cudaGraphDestroy(graph)); The ShellMat context has the CUDA Stream "s", and that stream is used in the shell computations. If I replace the MatComputeOperator() call with for (int i = 0; i < N; i++) MatMult(ShellMat, x, y); the code works inside the CUDA graph. I tried modifying the MatConvert_Shell() code and wrapping the main for loop that computes each column with the graph, but this still doesn't work. I think if you have a MatShell that does some trivial computation (like return y = x), that should be a good enough example to start with. For now, I ended up making my own version of MatComputeOperator that doesn't involve Mats or Vecs in the main loop (working directly with arrays) so I could have control over the stream operations. Thanks, Sreeram On Tue, May 14, 2024 at 10:15 PM Junchao Zhang <[email protected]> wrote:
--Junchao Zhang
Thanks, Sreeram
participants (2)
Junchao Zhang -
Sreeram R Venkat
