Re: [petsc-users] PCMG with PCREDISTRIBUTE
You may be able to use https://petsc.org/main/manualpages/PC/PCSetApplicationContext/#pcsetapplicat... or KSPSetApplicationContext() or PetscObjectCompose() (this may be better since it can be eventually merged into PETSc). Barry
On Jul 29, 2023, at 7:54 AM, Carl-Johan Thore <[email protected]> wrote:
Hi again,
I’ve now managed to get PCMG with PCREDISTRIBUTE to work on multiple ranks, and convergence looks good on my examples. (the modification to redistribute.c was trivial – just skip the case “if (size > 1) {“ in PCSetUp_Redistribute).
The final step is your suggestion
“2) the only problem with 1 is it is likely to be poorly load balanced (but you can make some runs to see how imbalanced it is, that will depend exactly on what parts are locked and what MPI processes they are on). So if it is poorly balanced then you would need to get out of redistribute.c a mapping for each kept dof to what MPI rank it is moved to and use that to move the entries in the reduced interpolation you have created. “
My idea for this is to do “VecScatterBegin(red->scatter …” on my vector indicating fixed or free DOFs to redistribute it in the same way as the global matrix is redistributed. It is tempting to do something like “KSPGetPC(ksp, &pc); PC_Redistribute *red = (PC_Redistribute *)pc->data;” in my main code, and then do the scatter with the red object. But this is not directly possible, resulting in PC_Redistribute not defined and so on. Another alternative is perhaps to pass my vector into the PC via the “optional user-defined context” in the _p_PC context. Do you have any suggestions or hints for a good (efficient and non-intrusive) way to “get out of redistribute.c a mapping …”?
/Carl-Johan
From: Carl-Johan Thore <[email protected] <mailto:[email protected]>> Sent: Tuesday, July 25, 2023 4:49 PM To: Barry Smith <[email protected] <mailto:[email protected]>> Subject: Re: [petsc-users] PCMG with PCREDISTRIBUTE
Ok thanks! Good to know I'm not doing anything wrong on the PETSc-side, so to speak. It seems like it could be related to WSL then From: Barry Smith <[email protected] <mailto:[email protected]>> Sent: 25 July 2023 16:39:37 To: Carl-Johan Thore <[email protected] <mailto:[email protected]>> Subject: Re: [petsc-users] PCMG with PCREDISTRIBUTE
No idea why it would be particularly slow. Probably some issue with making the PETSc shared library, normally that would take a few seconds on Linux or a Mac.
On Jul 25, 2023, at 6:12 AM, Carl-Johan Thore <[email protected] <mailto:[email protected]>> wrote:
Hi again,
I’ve now gotten PCMG with PCREDISTRIBUTE to work nicely on simple examples on one core (attached ppt). I therefore plan to test with multiple cores by first modifying redistribute.c such that the dofs are not moved around as you suggested. For this I wonder what is the recommended way of modifying a single file in my PETSc-installation? I’ve tried running make in the folder containing redistribute.c:
<image001.png>
This works but is terribly slow on my computer (google indicates that this could be related to me using Windows Subsystem for Linux, but I didn’t succeed with the suggestions)
Kind regards, Carl-Johan
From: Carl-Johan Thore <[email protected] <mailto:[email protected]>> Sent: Sunday, July 2, 2023 8:07 PM To: Barry Smith <[email protected] <mailto:[email protected]>> Subject: Re: [petsc-users] PCMG with PCREDISTRIBUTE
"NN" is used to construct the row indices passed to matzerorowscolumns. That works fine, so at least in that sense NN is correct. But I should probably compare my IS:es with those row indices as well.
Yes, making a tiny problem is a good idea.
Thanks for taking time to look at this From: Barry Smith <[email protected] <mailto:[email protected]>> Sent: 02 July 2023 18:58:50 To: Carl-Johan Thore <[email protected] <mailto:[email protected]>> Cc: petsc-users <[email protected] <mailto:[email protected]>> Subject: Re: [petsc-users] PCMG with PCREDISTRIBUTE
Are you sure the NN is correct? I cannot see how you set that and know that it exactly matches the way PCREDISTRIBUTE selects rows?
I suggest making a tiny problem with artificial matrix values that you select to "slice" of parts of the grid, so you can see exactly on the grid that the selected rows and columns are correct as you expect.
On Jul 2, 2023, at 2:16 AM, Carl-Johan Thore <[email protected] <mailto:[email protected]>> wrote:
I tried your suggestion
“1) Use PCREDISTRIBUTE but hack the code in redistribute.c to not move dof between MPI ranks, just have it remove the locked rows/columns (to start just run on one MPI rank since then nothing is moved) Then in your code you just need to pull out the appropriate rows and columns of the interpolation that correspond to the dof you have kept and pass this smaller interpolation to the inner KSP PCMG. This is straightforward and like what is in DMSetVI. The MG convergence should be just as good as on the full system.”
from below and got the size of the interpolation matrix correct. But the convergence doesn’t seem right. In the attached .txt-file the code without redistribute convergences in 8 FGMRES iterations whereas with redistribute it takes 25 (I’ve tested this on various meshes and the redistribute-code consistently performs much worse in terms of number of iterations). The code without redistribute is very well tested and always performs very well, so I’m fairly certain the error is in my new code.
Would you be willing to take a quick look at the attached code snippet to see if I’m doing some obvious mistake?
From: Barry Smith <[email protected] <mailto:[email protected]>> Sent: Friday, June 30, 2023 5:21 PM To: Matthew Knepley <[email protected] <mailto:[email protected]>> Cc: Carl-Johan Thore <[email protected] <mailto:[email protected]>>; [email protected] <mailto:[email protected]> Subject: Re: [petsc-users] PCMG with PCREDISTRIBUTE
On Jun 30, 2023, at 10:22 AM, Matthew Knepley <[email protected] <mailto:[email protected]>> wrote:
On Fri, Jun 30, 2023 at 10:16 AM Carl-Johan Thore via petsc-users <[email protected] <mailto:[email protected]>> wrote: Thanks for the quick reply and the suggestions!
“ … you should first check that the PCMG works quite well “
Yes, the PCMG works very well for the full system.
“I am guessing that your code is slightly different than ex42.c because you take the interpolation matrix provided by the DM and give it to the inner KSP PCMG?. So you solve problem 2 but not problem 1.”
Yes, it’s slightly different so problem 2 should be solved.
It looked somewhat complicated to get PCMG to work with redistribute, so I’ll try with PCGAMG first (it ran immediately with redistribute, but was slower than PCMG on my, very small, test problem. I’ll try to tune the settings).
A related question: I’m here using a DMDA for a structured grid but I’m locking so many DOFs that for many of the elements all DOFs are locked. In such a case could it make sense to switch/convert the DMDA to a DMPlex containing only those elements that actually have DOFs?
Possibly, but if you are doing FD, then there is built-in topology in DMDA that is not present in Plex, so finding the neighbors in the right order is harder (possible, but harder, we address this in some new work that is not yet merged). There is also structured adaptive support with DMForest, but this also does not preserve the stencil.
The efficiency of active set VI solvers in PETSc demonstrates to me that solving reduced systems can be done efficiently with geometric multigrid using a structured grid so I would not suggest giving up on what you started.
You can do it in two steps
If you do succeed it would actually be useful code that we could add to PCREDISTRIBUTE for more general use by others.
Barry
Matt
From: Barry Smith <[email protected] <mailto:[email protected]>> Sent: Friday, June 30, 2023 3:57 PM To: Carl-Johan Thore <[email protected] <mailto:[email protected]>> Cc: [email protected] <mailto:[email protected]> Subject: Re: [petsc-users] PCMG with PCREDISTRIBUTE
Oh, I forgot to mention you should first check that the PCMG works quite well for the full system (without the PCREDISTRIBUTE); the convergence on the redistributed system (assuming you did all the work to get PCMG to work for you) should be very similar to (but not measurably better) than the convergence on the full system.
On Jun 30, 2023, at 9:17 AM, Barry Smith <[email protected] <mailto:[email protected]>> wrote:
ex42.c provides directly the interpolation/restriction needed to move between levels in the loop
for (k = 1; k < nlevels; k++) { PetscCall(DMCreateInterpolation(da_list[k - 1], da_list[k], &R, NULL)); PetscCall(PCMGSetInterpolation(pc, k, R)); PetscCall(MatDestroy(&R)); }
The more standard alternative to this is to call KSPSetDM() and have the PCMG setup use the DM to construct the interpolations (I don't know why ex42.c does this construction itself instead of having the KSPSetDM() process handle it but that doesn't matter). The end result is the same in both cases.
Since PCREDISTRIBUTE builds its own new matrix (by using only certain rows and columns of the original matrix) the original interpolation cannot be used for two reasons
1) (since it is for the full system) It is for the wrong problem.
2) In addition, if you ran with ex42.c the inner KSP does not have access to the interpolation that was constructed so you could not get PCMG to to work as indicated below.
So the short answer is that there is no "canned" way to use the PCMG process trivially with PCDISTRIBUTE.
To do what you want requires two additional steps
1) after you construct the full interpolation matrix (by using the DM) you need to remove the rows associated with the dof that have been removed by the "locked" variables (and the columns that are associated with coarse grid points that live on the removed points) so that the interpolation is the correct "size" for the smaller problem
2) since PCREDISTRIBUTE actually moves dof of freedom between MPI processes for load balancing after it has removed the locked variables you would need to do the exact same movement for the rows of the interpolation matrix that you have constructed (after you have removed the "locked" rows of the interpolation.
Lots of bookkeeping to acheive 1 and 2 but conceptually simple.
As an experiment you can try using PCGAMG on the redistributed matrix -redistribute_pc_type gamg to use algebraic multigrid just to see the time and convergence rates. Since GAMG creates its own interpolation based on the matrix and it will be built on the smaller redistributed matrix there will no issue with the wrong "sized" interpolation. Of course you have the overhead of algebraic multigrid and cannot take advantage of geometric multigrid. The GAMG approach may be satisfactory to your needs.
If you are game for looking more closely at using redistribute with geometric multigrid and PETSc (which will require digging into PETSc source code and using internal information in the PETSc source code) you can start by looking at how we solve variational problems with SNES using reduced space active set methods. SNESVINEWTONRSLS /src/snes/impls/vi/rs/virs.c This code solves problem 1 see() it builds the entire interpolation and then pulls out the required non-locked part. Reduced space active set methods essentially lock the constrained dof and solve a smaller system without those dof at each iteration.
But it does not solve problem 2. Moving the rows of the "smaller" interpolation to the correct MPI process based on where PCREDISTRIBUTE moved rows. To do this would requring looking at the PCREDISTRUBUTE code and extracting the information of where each row was moving and performing the process for the interpolation matrix. src/ksp/pc/impls/redistribute/redistribute.c
Barry
On Jun 30, 2023, at 8:21 AM, Carl-Johan Thore via petsc-users <[email protected] <mailto:[email protected]>> wrote:
I'm trying to run an iterative solver (FGMRES for example) with PCMG as preconditioner. The setup of PCMG is done roughly as in ex42 of the PETSc-tutorials (https://petsc.org/main/src/ksp/ksp/tutorials/ex42.c.html). Since I have many locked degrees-of-freedom I would like to use PCREDISTRIBUTE. However, this results in (30039 is the number of DOFs after redistribute and 55539 the number before):
[0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Nonconforming object sizes [0]PETSC ERROR: Matrix dimensions of A and P are incompatible for MatProductType PtAP: A 30039x30039, P 55539x7803 [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: v3.19.0-238-g512d1ae6db4 GIT Date: 2023-04-24 16:37:00 +0200 [0]PETSC ERROR: topopt on a arch-linux-c-opt Fri Jun 30 13:28:41 2023 [0]PETSC ERROR: Configure options COPTFLAGS="-O3 -march=native" CXXOPTFLAGS="-O3 -march=native" FOPTFLAGS="-O3 -march=native" CUDAOPTFLAGS=-O3 --with-cuda --with-cusp --with-debugging=0 --download-scalapack --download-hdf5 --download-zlib --download-mumps --download-parmetis --download-metis --download-ptscotch --download-hypre --download-spai [0]PETSC ERROR: #1 MatProductSetFromOptions_Private() at /mnt/c/mathware/petsc/src/mat/interface/matproduct.c:420 [0]PETSC ERROR: #2 MatProductSetFromOptions() at /mnt/c/mathware/petsc/src/mat/interface/matproduct.c:541 [0]PETSC ERROR: #3 MatPtAP() at /mnt/c/mathware/petsc/src/mat/interface/matrix.c:9868 [0]PETSC ERROR: #4 MatGalerkin() at /mnt/c/mathware/petsc/src/mat/interface/matrix.c:10899 [0]PETSC ERROR: #5 PCSetUp_MG() at /mnt/c/mathware/petsc/src/ksp/pc/impls/mg/mg.c:1029 [0]PETSC ERROR: #6 PCSetUp() at /mnt/c/mathware/petsc/src/ksp/pc/interface/precon.c:994 [0]PETSC ERROR: #7 KSPSetUp() at /mnt/c/mathware/petsc/src/ksp/ksp/interface/itfunc.c:406 [0]PETSC ERROR: #8 PCSetUp_Redistribute() at /mnt/c/mathware/petsc/src/ksp/pc/impls/redistribute/redistribute.c:327 [0]PETSC ERROR: #9 PCSetUp() at /mnt/c/mathware/petsc/src/ksp/pc/interface/precon.c:994 [0]PETSC ERROR: #10 KSPSetUp() at /mnt/c/mathware/petsc/src/ksp/ksp/interface/itfunc.c:406 [0]PETSC ERROR: #11 KSPSolve_Private() at /mnt/c/mathware/petsc/src/ksp/ksp/interface/itfunc.c:824 [0]PETSC ERROR: #12 KSPSolve() at /mnt/c/mathware/petsc/src/ksp/ksp/interface/itfunc.c:1070
It’s clear what happens I think, and it kind of make since not all levels are redistributed as they should (?). Is it possible to use PCMG with PCREDISTRIBUTE in an easy way?
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
<pcmg_redistribute_experiment_cantilever.pptx>
participants (1)
Barry Smith
