Use of flag dm_plex_high_order_view
Hello, In an old question about obtaining the node connectivity of a cell with a high order approximation space, the use of the flag "-dm_plex_high_order_view" for visualization purposes was brought up, as a way to refine the grid down to linear space. Link: https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/dm... I'm trying to make use of this flag to see the refinement, but I see no difference with higher order approximations. Perhaps I am misunderstanding its use? I thought that by using it, one could see a "subdivision" of each element. Say, a single triangle, FE approximation space order 2 (3 corner nodes, 3 mid-edge nodes), would be refined into e.g. 4 linear triangles. The code (Fortran) looks something along these lines: ! Create a DM from the mesh file DM :: cdm PetscInt :: K, cdim, fedim PetscBool :: simplex PetscFE :: cfe PetscViewer :: viewer PetscErrorCode :: ierr PetsCallA(DMSetFromOptions(cdm, ierr)) PetsCallA(DMGetDimension(cdm, cdim, ierr)) PetsCallA(DMPlexSimplex(cdm, simplex, ierr)) PetsCallA(PetscFECreateDefault(PETSC_COMM_WORLD, cdim, cdim, simplex, "ho_", K, cfe, ierr)) PetsCallA(PetscFEGetDimension(cfe, fedim, ierr)) PetsCallA(PetscViewerCreate(PETSC_COMM_WORLD, viewer, ierr)) PetsCallA(PetscViewerDrawOpen(PETSC_COMM_WORLD, PETSC_NULL_CHARACTER, PETSC_NULL_CHARACTER, 100, 100, 800, 800, viewer, ierr)) PetsCallA(PetscViewerSetFromOptions(viewer, ierr)) ! also using flag -draw_pause 5 PetsCallA(DMView(cdm, viewer, ierr)) [...] With the following list of flags: -ho_petscspace_degree K -ho_petscdualspace_lagrange_node_type equispaced -ho_petscdualspace_lagrange_node_endpoints 1 -dm_plex_high_order_view -options_left Using "-options_left" shows that "there are no unused options"; so "-dm_plex_high_order_view" is used somehow; it is at least required for the call to "DMPlexCreateHighOrderSurrogate_Internal" within the "draw" functions.
From the CoordinateDM I can see the additional nodes created for the higher order approximation (e.g. mid-edge, mid-face nodes), so it seems the FE space is correct.
Regardless of the order "K", the mesh plotted with "DMView" is always the same, corresponding to the linear case. Thank you. Noam
On Wed, Dec 10, 2025 at 8:14 AM Noam T. via petsc-users < [email protected]> wrote:
Hello,
This is the misunderstanding here. What I implemented was visualization for meshes with high order _coordinate_ spaces. I am "guaranteed" that this will work because I know that coordinates are discretized with Lagrange spaces. I did not do this for approximation spaces because I can't guarantee this. We could do the same thing for approximation spaces, and I would be happy to help you factor it out. In general, I would need to figure out the smallest DG space containing the approximation space (don't know how to do yet, but possible), then project to that first and start the descent as before. Thanks, Matt
Link: https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/dm... <https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/plex.c?ref_type=heads*L2021__;Iw!!G_uCfscf7eWS!ZZVaar4OGVdTXOAAjkEadcw-CAZUpAAzibpD_2SKpRupYG4oxSH-W7u5necsgTYDii6v-1kjfV4aqsllxL9XI_hK2YITfNz-$>
Thank you.
Noam
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCf... <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfs... >
participants (2)
Matthew Knepley -
Noam T.
