Hi, I'm trying to solve a linear system of equations Ax=b, where A has a null space (say Q) and x is known to be orthogonal to Q. In order to avoid ill-conditioning, I was trying to do the following: 1. Create A as a shell matrix 2. Overload the MATOP_MULT operation for with my own function which returns y = A*(I - QQ^T)x instead of y = Ax 3. Upon convergence, solution = (I-QQ^T)x instead of x. However, I realized that the linear solver can make x have any arbitrary component along Q and still y = A*(I-QQ^T)x will remain unaffected, and hence can cause convergence issues. Indeed, I saw such convergence problems. What fixed the problem was using MatSetNullSpace for A with Q as the nullspace, in addition to the above three steps. So my question is what exactly is MatSetNullSpace doing? And since the full A information is not present and A is only accessed through MAT_OP_MULT, I'm confused as how MatSetNullSpace might be fixing the convergence issue. Thanks, Bikash -- Bikash S. Kanungo PhD Student Computational Materials Physics Group Mechanical Engineering University of Michigan
On Thu, Jun 1, 2017 at 2:07 PM, Bikash Kanungo <[email protected]> wrote:
1) This implies that A is symmetric 2) I think you mean the b is orthogonal to Q
Its not MatSetNullSpace() that fixes this issue, it is the linear solver itself. Many Krylov solvers can converge to the minimum norm solution of this rank deficient problem. Second, we remove components in the nullspace from each iterate, which is not what you are doing above. It seems easier to just give your Q as the nullspace. Thanks, Matt
Thanks, Bikash
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener http://www.caam.rice.edu/~mk51/
Thank you Matthew for the quick response. I should provide some more details. 1) This implies that A is symmetric Yes A is symmetric 2) I think you mean the b is orthogonal to Q No. I've an extra condition on the solution x - that it has to be orthogonal to Q. Without this condition the problem will have multiple solutions. It's same as finding the minimum norm solution
minimum norm solution of this rank deficient problem. I was unable to get convergence without using MatSetNullSpace(). So it seems that the Krlov solvers are inadequate just by themselves. Second, we remove components in the nullspace from each iterate, which is
This might be the reason why without MatSetNullSpace() I'm unable to attain convergence.
Yeah using Q as nullspace is the easiest option. But my basis is non-orthogonal and has an overlap matrix S. So in order to provide orthonormal nullvectors as Q to Petsc, I need to evaluate S^{-1/2}. As of now, for small problems I can evalaute S^{-1/2}, however, it's a show stopper for large ones. I can possibly use MatNullSpaceSetFunction() to circumvent the requirement of orthonormal nullvectors in MatSetNullSpace(). I would appreciate your input on this. Lastly, I would like to know what operations do MatSetNullSpace enforce within a KSP solve. Thanks, Bikash On Thu, Jun 1, 2017 at 5:25 PM, Matthew Knepley <[email protected]> wrote:
Matt
Thanks, Bikash
Yes A is symmetric
You do not need this. Just use http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatNullSpace... to implement your (I - Q^T Q). Thanks, Matt
Thanks, Bikash
Matt
Thanks, Bikash
Thanks again Matthew. I'll try to use MatSetNullSpaceFunction and see if it resolves the issue. On Thu, Jun 1, 2017 at 6:00 PM, Matthew Knepley <[email protected]> wrote:
Yes A is symmetric
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/ MatNullSpaceSetFunction.html#MatNullSpaceSetFunction
Matt
Thanks, Bikash
Matt
Thanks, Bikash
participants (2)
Bikash Kanungo -
Matthew Knepley
