Hello, I created a code for solving the finite element method using the PCBDDC method according to ex71, but I got the following error at the end, I can't find out the cause of the error, can you tell me what the error is based on the error message? (PS. I have tried: Mat AA. PetscCall(MatConvert(A, MATAIJ, MAT_INITIAL_MATRIX, &AA)). to change the matrix type and then solve for AA, it works fine) [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [1]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: [1]PETSC ERROR: Error in external library Error in external library [0]PETSC ERROR: [1]PETSC ERROR: Error in query to SYEV Lapack routine 0 Error in query to SYEV Lapack routine 0 [0]PETSC ERROR: [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting. See https://petsc.org/release/faq/ for trouble shooting. [0]PETSC ERROR: [1]PETSC ERROR: Petsc Development GIT revision: unknown GIT Date: unknown Petsc Development GIT revision: unknown GIT Date: unknown [0]PETSC ERROR: [1]PETSC ERROR: test_petsc_fem.exe on a arch-mswin-c-debug named lmeep-329 by XiongZiming Wed May 31 16:52:36 2023 test_petsc_fem.exe on a arch-mswin-c-debug named lmeep-329 by XiongZiming Wed May 31 16:52:36 2023 [0]PETSC ERROR: [1]PETSC ERROR: Configure options --with-cc=/cygdrive/f/post_doc_C++/petsc_new/petsc-main/lib/petsc/bin/win32fe/win_cl --with-cxx=/cygdrive/f/post_doc_C++/petsc_new/petsc-main/lib/petsc/bin/win32fe/win_cl --with-fc=0 --download-metis --with-shared-libraries=0 --with-mpi-include="[/cygdrive/c/PROGRA~2/Intel/MPI/Include,/cygdrive/c/PROGRA~2/Intel/MPI/Include/x64]" --with-mpi-lib="-L/cygdrive/c/PROGRA~2/Intel/MPI/lib/x64 msmpifec.lib msmpi.lib" --with-mpiexec=/cygdrive/c/PROGRA~1/Microsoft_MPI/Bin/mpiexec --with-blaslapack-lib="-L/cygdrive/c/PROGRA~2/Intel/oneAPI/mkl/latest/lib/intel64 mkl_intel_lp64_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib" --with-64-bit-indices --with-mkl_pardiso-dir=/cygdrive/c/PROGRA~2/Intel/oneAPI/mkl/latest Configure options --with-cc=/cygdrive/f/post_doc_C++/petsc_new/petsc-main/lib/petsc/bin/win32fe/win_cl --with-cxx=/cygdrive/f/post_doc_C++/petsc_new/petsc-main/lib/petsc/bin/win32fe/win_cl --with-fc=0 --download-metis --with-shared-libraries=0 --with-mpi-include="[/cygdrive/c/PROGRA~2/Intel/MPI/Include,/cygdrive/c/PROGRA~2/Intel/MPI/Include/x64]" --with-mpi-lib="-L/cygdrive/c/PROGRA~2/Intel/MPI/lib/x64 msmpifec.lib msmpi.lib" --with-mpiexec=/cygdrive/c/PROGRA~1/Microsoft_MPI/Bin/mpiexec --with-blaslapack-lib="-L/cygdrive/c/PROGRA~2/Intel/oneAPI/mkl/latest/lib/intel64 mkl_intel_lp64_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib" --with-64-bit-indices --with-mkl_pardiso-dir=/cygdrive/c/PROGRA~2/Intel/oneAPI/mkl/latest [0]PETSC ERROR: [1]PETSC ERROR: #1 PCBDDCConstraintsSetUp() at F:\post_doc_C++\petsc_new\petsc-main\src\ksp\pc\impls\bddc\bddcprivate.c:5975 #1 PCBDDCConstraintsSetUp() at F:\post_doc_C++\petsc_new\petsc-main\src\ksp\pc\impls\bddc\bddcprivate.c:5975 [0]PETSC ERROR: [1]PETSC ERROR: #2 PCSetUp_BDDC() at F:\post_doc_C++\petsc_new\petsc-main\src\ksp\pc\impls\bddc\bddc.c:1659 #2 PCSetUp_BDDC() at F:\post_doc_C++\petsc_new\petsc-main\src\ksp\pc\impls\bddc\bddc.c:1659 [0]PETSC ERROR: [1]PETSC ERROR: #3 PCSetUp() at F:\post_doc_C++\petsc_new\petsc-main\src\ksp\pc\interface\precon.c:994 #3 PCSetUp() at F:\post_doc_C++\petsc_new\petsc-main\src\ksp\pc\interface\precon.c:994 [1]PETSC ERROR: [0]PETSC ERROR: #4 KSPSetUp() at F:\post_doc_C++\petsc_new\petsc-main\src\ksp\ksp\interface\itfunc.c:406 #4 KSPSetUp() at F:\post_doc_C++\petsc_new\petsc-main\src\ksp\ksp\interface\itfunc.c:406 [1]PETSC ERROR: [0]PETSC ERROR: #5 petsc_calcul_part_DMDA() at petsc_DMDA.cpp:285 #5 petsc_calcul_part_DMDA() at petsc_DMDA.cpp:285 [1]PETSC ERROR: [0]PETSC ERROR: #6 main() at ..\Main.cpp:281 #6 main() at ..\Main.cpp:281 [1]PETSC ERROR: [0]PETSC ERROR: No PETSc Option Table entries No PETSc Option Table entries [1]PETSC ERROR: [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] ----------------End of Error Message -------send entire error message to [email protected] job aborted: [ranks] message [0-1] application aborted aborting MPI_COMM_SELF (comm=0x44000001), error 76, comm rank 0 ---- error analysis ----- [0-1] on lmeep-329 test_petsc_fem.exe aborted the job. abort code 76 ---- error analysis ----- Ziming XIONG
This is an inconsistent error message. It prints
But the error check is on lierr != 0 so the error check should not have been triggered. I inspected the code and there is no obvious problem with mixing up different-size integers; the prototype for the function expects a PetscBlasInt, and that is what is passed in. Strong compiler optimizations are not turned on so it seems unlikely it is due to a compiler bug. Are you familiar with debugging? You can use the command line option -start_in_debugger type cont in the debugger windows, and when the debugger stops with the error, you can type bt and look around at the variables to see if any look off. Barry
Ziming XIONG
participants (2)
Barry Smith -
ziming xiong
