Hi, I am now trying to use MS MPI after compiling with PETSc. I was using MPICH before. During linking, I got the error: 1>Compiling manifest to resources... 1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1 1>Copyright (C) Microsoft Corporation. All rights reserved. 1>Linking... 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB1 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB1 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB2 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB2 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB3 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB3 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB4 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB4 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB7 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB7 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB8 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB8 imported 1>libpetsc.lib(pinit.o) : error LNK2019: unresolved external symbol MPI_Reduce_scatter_block referenced in function PetscMaxSum 1>libpetsc.lib(mpits.o) : error LNK2001: unresolved external symbol MPI_Reduce_scatter_block 1>C:\Obj_tmp\ibm3d_IIB_mpi\Debug\ibm3d_IIB_mpi.exe : fatal error LNK1120: 1 unresolved externals 1> May I know what's wrong? -- Thank you Yours sincerely, TAY wee-beng
Hi, Sorry I just realised that I was pointing to the wrong library. It's ok now. -------- Forwarded Message -------- Subject: Problem linking code with MS MPI + PETSc Date: Tue, 27 Dec 2016 16:02:40 +0800 From: TAY wee-beng <[email protected]> To: PETSc list <[email protected]> Hi, I am now trying to use MS MPI after compiling with PETSc. I was using MPICH before. During linking, I got the error: 1>Compiling manifest to resources... 1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1 1>Copyright (C) Microsoft Corporation. All rights reserved. 1>Linking... 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB1 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB1 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB2 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB2 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB3 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB3 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB4 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB4 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB7 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB7 imported 1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol MPIFCMB8 imported 1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol MPIFCMB8 imported 1>libpetsc.lib(pinit.o) : error LNK2019: unresolved external symbol MPI_Reduce_scatter_block referenced in function PetscMaxSum 1>libpetsc.lib(mpits.o) : error LNK2001: unresolved external symbol MPI_Reduce_scatter_block 1>C:\Obj_tmp\ibm3d_IIB_mpi\Debug\ibm3d_IIB_mpi.exe : fatal error LNK1120: 1 unresolved externals 1> May I know what's wrong? -- Thank you Yours sincerely, TAY wee-beng
Its good to always verify if a petsc example with makefile works [or reproduces the same error] If the petsc example with petsc makefile works - then you would look at the differences bettween this compile - and yours.. Satish On Tue, 27 Dec 2016, TAY wee-beng wrote:
participants (2)
Satish Balay -
TAY wee-beng
