Hello, I want to solve PF solidification+Navier stokes using Finite different method. The Poisson equation is much more complicated that the one for just a fluid-flow problems (because it includes different terms order parameter terms). The code converges but the convergence rate is very slow. I have tried different options. Following is the best options I found but the convergence is still very slow. I did not include the ksp_convergence data because it takes around 1000 liner solver steps for each snes step. I look in literature, but I did not find any data on PF+navierstokes solutions using Petsc. Do you have any suggestions how should I improve the convergence? Best, Sepideh ibrun -np 136 ./one.out -ts_monitor -snes_fd_color -ts_max_snes_failures -1 -ts_type bdf -ts_bdf_adapt -snes_linesearch_type l2 -snes_type ksponly -pc_type fieldsplit -pc_fieldsplit_0_fields 0,1 -pc_fieldsplit_1_fields 2,3 -pc_fieldsplit_2_fields 4 -pc_fieldsplit_type multiplicative -fieldsplit_0_pc_type bjacobi -fieldsplit_1_pc_type bjacobi -fieldsplit_2_pc_type ilu -fieldsplit_0_ksp_type preonly -fieldsplit_1_ksp_type preonly -fieldsplit_2_ksp_type preonly -sub_pc_type ilu -sub_ksp_type preonly -snes_monitor -log_view log.txt TACC: Starting up job 7605521 TACC: Starting parallel tasks... nu_nd=14948.511 ! tau/w=26225.459! initial! 0 TS dt 0.0001 time 0. copy! Write output at step= 0! 0 SNES Function norm 1.465357113711e+01 1 SNES Function norm 1.131764004117e+02 0 SNES Function norm 5.657793773935e+01 1 SNES Function norm 9.539772669908e-02 1 TS dt 0.0002 time 0.0001 copy! 0 SNES Function norm 1.734774194628e+02 1 SNES Function norm 1.009134558763e+00 2 TS dt 0.000324128 time 0.0003 copy! 0 SNES Function norm 1.199860231725e+01 1 SNES Function norm 1.698885201785e-02 3 TS dt 0.000470679 time 0.000624128 copy! 0 SNES Function norm 8.344934987594e+00 1 SNES Function norm 4.082958856578e-03 4 TS dt 0.000769357 time 0.00109481 copy! 0 SNES Function norm 9.338443428763e+00 1 SNES Function norm 2.472903267511e-03 5 TS dt 0.00153871 time 0.00186416 copy! 0 SNES Function norm 9.836384162921e+00 1 SNES Function norm 6.383053421790e-03 6 TS dt 0.00215245 time 0.00340288 copy! 0 SNES Function norm 5.043289760603e+00 1 SNES Function norm 2.168332362305e-03 7 TS dt 0.0022353 time 0.00555533 copy! 0 SNES Function norm 1.421255264272e+00 1 SNES Function norm 1.750393691475e-03 8 TS dt 0.0044706 time 0.00779063 copy! 0 SNES Function norm 1.216746389225e+00 1 SNES Function norm 5.339123694240e-04 0 SNES Function norm 2.168489818312e+00 1 SNES Function norm 1.928809773415e-03 9 TS dt 0.00310217 time 0.0110885 copy! 0 SNES Function norm 8.021629529051e-01 1 SNES Function norm 2.161901383228e-04 10 TS dt 0.00300302 time 0.0141906 copy! 0 SNES Function norm 7.731190774223e-01 1 SNES Function norm 2.807020573793e-04 11 TS dt 0.00367968 time 0.0171937 copy! 0 SNES Function norm 1.263830181443e+00 1 SNES Function norm 1.049133009231e-02 12 TS dt 0.00704796 time 0.0208733 copy! 0 SNES Function norm 5.619818748359e+00 1 SNES Function norm 1.569218805659e-01 13 TS dt 0.00742462 time 0.0279213 copy! 0 SNES Function norm 2.268051808662e+01 1 SNES Function norm 7.055762930884e+00 0 SNES Function norm 2.173806325395e+01 1 SNES Function norm 1.564571270312e+00 0 SNES Function norm 1.208038223084e+01 1 SNES Function norm 5.192087605517e-02 14 TS dt 0.00186927 time 0.0299244 copy! 0 SNES Function norm 4.797722218343e+00 1 SNES Function norm 3.975928994156e-03 15 TS dt 0.00189622 time 0.0317937 copy! 0 SNES Function norm 5.510229536082e+00 1 SNES Function norm 4.496811351139e-03 16 TS dt 0.00172953 time 0.0336899 copy! 0 SNES Function norm 6.945417639798e+00 1 SNES Function norm 4.569326335543e-03 17 TS dt 0.00218527 time 0.0354194 copy! 0 SNES Function norm 1.351474156680e+01 1 SNES Function norm 1.719775600164e-02 18 TS dt 0.00224386 time 0.0376047 copy! 0 SNES Function norm 2.174969556700e+01 1 SNES Function norm 3.814212178889e-02 0 SNES Function norm 4.891415655138e+01 1 SNES Function norm 6.772042718901e-02 0 SNES Function norm 2.828143585009e+01 1 SNES Function norm 6.965842377755e-03 0 SNES Function norm 2.168193335917e+01 1 SNES Function norm 2.463212234975e-03 19 TS dt 0.000205482 time 0.0378175 copy! 0 SNES Function norm 1.409435206457e+00 1 SNES Function norm 1.859628755245e-02 20 TS dt 0.000188785 time 0.0380229 copy! Write output at step= 20! 0 SNES Function norm 5.900261363044e-01 1 SNES Function norm 2.653576084845e-02 0 SNES Function norm 5.122905363140e+00 1 SNES Function norm 4.297068425492e-03 0 SNES Function norm 3.428448792746e+00 1 SNES Function norm 1.000610664096e-02 21 TS dt 6.50511e-05 time 0.0380738 copy! 0 SNES Function norm 3.700405789863e-01 1 SNES Function norm 6.263642369355e-02 22 TS dt 7.93452e-05 time 0.0381388 copy! 0 SNES Function norm 5.282939288286e-01 1 SNES Function norm 3.003209840754e-01 23 TS dt 7.50242e-05 time 0.0382181 copy! 0 SNES Function norm 7.079201595974e-01 1 SNES Function norm 1.247544399226e-02 24 TS dt 0.000150048 time 0.0382932 copy! 0 SNES Function norm 6.197633272307e-01 1 SNES Function norm 3.176914154297e-02 25 TS dt 0.000171939 time 0.0384432 copy! 0 SNES Function norm 5.849423362557e-01 1 SNES Function norm 9.462256964187e-03 26 TS dt 0.000176855 time 0.0386152 copy! 0 SNES Function norm 4.304951653234e-01 1 SNES Function norm 3.939112950208e-03
First question: Are your nonlinear solves converging? I see you have -snes_type ksponly, but it looks like your SNES iteration _diverges_ sometimes, and mostly fails to converge. Is this correct? Thanks, Matt
Best, Sepideh
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Dear Mathew, thank you for your response. I double checked and snes is converged in all steps. following is output of -snes_converged_reason 0 TS dt 0.0001 time 0. copy! Write output at step= 0! 0 SNES Function norm 1.465357113711e+01 1 SNES Function norm 1.131764004094e+02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 5.657793773845e+01 1 SNES Function norm 9.539766295097e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 1 TS dt 0.0002 time 0.0001 copy! 0 SNES Function norm 1.734774181586e+02 1 SNES Function norm 1.009139331913e+00 Nonlinear solve converged due to CONVERGED_ITS iterations 1 2 TS dt 0.000324496 time 0.0003 copy! 0 SNES Function norm 1.200543689889e+01 1 SNES Function norm 1.715000763566e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 3 TS dt 0.000471924 time 0.000624496 copy! 0 SNES Function norm 8.374168676869e+00 1 SNES Function norm 3.806213226152e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 4 TS dt 0.00076859 time 0.00109642 copy! 0 SNES Function norm 9.316857431814e+00 1 SNES Function norm 3.125732297714e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 5 TS dt 0.00153718 time 0.00186501 copy! 0 SNES Function norm 9.820005256073e+00 1 SNES Function norm 8.107044589689e-04 Nonlinear solve converged due to CONVERGED_ITS iterations 1 6 TS dt 0.00218053 time 0.00340219 copy! 0 SNES Function norm 5.122834112454e+00 1 SNES Function norm 1.662895139952e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 7 TS dt 0.0022609 time 0.00558272 copy! 0 SNES Function norm 1.423878996243e+00 1 SNES Function norm 1.329199025944e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 8 TS dt 0.0045218 time 0.00784362 copy! 0 SNES Function norm 1.241101191899e+00 1 SNES Function norm 1.758309073907e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 2.174982578512e+00 1 SNES Function norm 1.977451891592e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 9 TS dt 0.00309088 time 0.0111379 copy! 0 SNES Function norm 7.952246195856e-01 1 SNES Function norm 3.315360582766e-04 Nonlinear solve converged due to CONVERGED_ITS iterations 1 10 TS dt 0.00302529 time 0.0142288 copy! 0 SNES Function norm 7.852078318680e-01 1 SNES Function norm 6.819399397977e-04 Nonlinear solve converged due to CONVERGED_ITS iterations 1 11 TS dt 0.0036818 time 0.0172541 copy! 0 SNES Function norm 1.269332622839e+00 1 SNES Function norm 1.508985874154e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 12 TS dt 0.00736361 time 0.0209359 copy! 0 SNES Function norm 6.143748829896e+00 1 SNES Function norm 2.172457806998e-01 Nonlinear solve converged due to CONVERGED_ITS iterations 1 13 TS dt 0.00792431 time 0.0282995 copy! 0 SNES Function norm 2.762542847702e+01 1 SNES Function norm 1.329294167855e+01 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 2.287537833706e+01 1 SNES Function norm 1.608258731248e+00 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 1.279894262237e+01 1 SNES Function norm 5.112278399366e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 14 TS dt 0.0017228 time 0.0301754 copy! 0 SNES Function norm 4.714428103053e+00 1 SNES Function norm 3.141482420272e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 15 TS dt 0.00174124 time 0.0318982 copy! 0 SNES Function norm 5.161696766061e+00 1 SNES Function norm 3.434924981822e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 1.440940181693e+01 1 SNES Function norm 2.060277373865e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 16 TS dt 0.00143688 time 0.0334492 copy! 0 SNES Function norm 4.954103004576e+00 1 SNES Function norm 1.705855165536e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 17 TS dt 0.00287377 time 0.0348861 copy! 0 SNES Function norm 1.757129021431e+01 1 SNES Function norm 3.191948709005e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 3.031772340693e+01 1 SNES Function norm 7.097653811013e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 18 TS dt 0.00203648 time 0.0368402 copy! 0 SNES Function norm 1.629074198276e+01 1 SNES Function norm 9.774829708834e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 4.007821179267e+01 1 SNES Function norm 4.322266335869e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 2.348161408350e+01 1 SNES Function norm 5.218780461268e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 1.789799437816e+01 1 SNES Function norm 2.727867493741e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 19 TS dt 0.000223859 time 0.0370644 copy! 0 SNES Function norm 1.164475864748e+00 1 SNES Function norm 5.580165229404e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 20 TS dt 0.000209603 time 0.0372882 copy! Write output at step= 20! 0 SNES Function norm 7.548512298179e-01 1 SNES Function norm 8.191710667867e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 5.113158684224e+00 1 SNES Function norm 4.059400705957e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 0 SNES Function norm 3.408310084009e+00 1 SNES Function norm 5.257240981430e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 21 TS dt 7.85133e-05 time 0.0373492 copy! 0 SNES Function norm 4.156375747211e-01 1 SNES Function norm 3.052885436956e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 22 TS dt 9.58699e-05 time 0.0374277 copy! 0 SNES Function norm 4.583956492983e-01 1 SNES Function norm 1.176944126767e-01 Nonlinear solve converged due to CONVERGED_ITS iterations 1 23 TS dt 9.32603e-05 time 0.0375236 copy! 0 SNES Function norm 4.969090229611e-01 1 SNES Function norm 1.738678566558e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 24 TS dt 0.000186521 time 0.0376169 copy! 0 SNES Function norm 6.406466977155e-01 1 SNES Function norm 8.183507106613e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 25 TS dt 0.000213369 time 0.0378034 copy! 0 SNES Function norm 6.235579283905e-01 1 SNES Function norm 7.038633582283e-02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 26 TS dt 0.000217545 time 0.0380168 copy! 0 SNES Function norm 5.375653976237e-01 1 SNES Function norm 7.318538883142e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 27 TS dt 0.000384287 time 0.0382343 copy! 0 SNES Function norm 8.638617026715e-01 1 SNES Function norm 1.596171692523e-03 Nonlinear solve converged due to CONVERGED_ITS iterations 1 ________________________________ From: Matthew Knepley <[email protected]> Sent: Tuesday, April 20, 2021 7:23 AM To: Sepideh Kavousi <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: [petsc-users] convergence slow On Mon, Apr 19, 2021 at 5:43 PM Sepideh Kavousi <[email protected]<mailto:[email protected]>> wrote: Hello, I want to solve PF solidification+Navier stokes using Finite different method. The Poisson equation is much more complicated that the one for just a fluid-flow problems (because it includes different terms order parameter terms). The code converges but the convergence rate is very slow. I have tried different options. Following is the best options I found but the convergence is still very slow. I did not include the ksp_convergence data because it takes around 1000 liner solver steps for each snes step. I look in literature, but I did not find any data on PF+navierstokes solutions using Petsc. Do you have any suggestions how should I improve the convergence? First question: Are your nonlinear solves converging? I see you have -snes_type ksponly, but it looks like your SNES iteration _diverges_ sometimes, and mostly fails to converge. Is this correct? Thanks, Matt Best, Sepideh ibrun -np 136 ./one.out -ts_monitor -snes_fd_color -ts_max_snes_failures -1 -ts_type bdf -ts_bdf_adapt -snes_linesearch_type l2 -snes_type ksponly -pc_type fieldsplit -pc_fieldsplit_0_fields 0,1 -pc_fieldsplit_1_fields 2,3 -pc_fieldsplit_2_fields 4 -pc_fieldsplit_type multiplicative -fieldsplit_0_pc_type bjacobi -fieldsplit_1_pc_type bjacobi -fieldsplit_2_pc_type ilu -fieldsplit_0_ksp_type preonly -fieldsplit_1_ksp_type preonly -fieldsplit_2_ksp_type preonly -sub_pc_type ilu -sub_ksp_type preonly -snes_monitor -log_view log.txt TACC: Starting up job 7605521 TACC: Starting parallel tasks... nu_nd=14948.511 ! tau/w=26225.459! initial! 0 TS dt 0.0001 time 0. copy! Write output at step= 0! 0 SNES Function norm 1.465357113711e+01 1 SNES Function norm 1.131764004117e+02 0 SNES Function norm 5.657793773935e+01 1 SNES Function norm 9.539772669908e-02 1 TS dt 0.0002 time 0.0001 copy! 0 SNES Function norm 1.734774194628e+02 1 SNES Function norm 1.009134558763e+00 2 TS dt 0.000324128 time 0.0003 copy! 0 SNES Function norm 1.199860231725e+01 1 SNES Function norm 1.698885201785e-02 3 TS dt 0.000470679 time 0.000624128 copy! 0 SNES Function norm 8.344934987594e+00 1 SNES Function norm 4.082958856578e-03 4 TS dt 0.000769357 time 0.00109481 copy! 0 SNES Function norm 9.338443428763e+00 1 SNES Function norm 2.472903267511e-03 5 TS dt 0.00153871 time 0.00186416 copy! 0 SNES Function norm 9.836384162921e+00 1 SNES Function norm 6.383053421790e-03 6 TS dt 0.00215245 time 0.00340288 copy! 0 SNES Function norm 5.043289760603e+00 1 SNES Function norm 2.168332362305e-03 7 TS dt 0.0022353 time 0.00555533 copy! 0 SNES Function norm 1.421255264272e+00 1 SNES Function norm 1.750393691475e-03 8 TS dt 0.0044706 time 0.00779063 copy! 0 SNES Function norm 1.216746389225e+00 1 SNES Function norm 5.339123694240e-04 0 SNES Function norm 2.168489818312e+00 1 SNES Function norm 1.928809773415e-03 9 TS dt 0.00310217 time 0.0110885 copy! 0 SNES Function norm 8.021629529051e-01 1 SNES Function norm 2.161901383228e-04 10 TS dt 0.00300302 time 0.0141906 copy! 0 SNES Function norm 7.731190774223e-01 1 SNES Function norm 2.807020573793e-04 11 TS dt 0.00367968 time 0.0171937 copy! 0 SNES Function norm 1.263830181443e+00 1 SNES Function norm 1.049133009231e-02 12 TS dt 0.00704796 time 0.0208733 copy! 0 SNES Function norm 5.619818748359e+00 1 SNES Function norm 1.569218805659e-01 13 TS dt 0.00742462 time 0.0279213 copy! 0 SNES Function norm 2.268051808662e+01 1 SNES Function norm 7.055762930884e+00 0 SNES Function norm 2.173806325395e+01 1 SNES Function norm 1.564571270312e+00 0 SNES Function norm 1.208038223084e+01 1 SNES Function norm 5.192087605517e-02 14 TS dt 0.00186927 time 0.0299244 copy! 0 SNES Function norm 4.797722218343e+00 1 SNES Function norm 3.975928994156e-03 15 TS dt 0.00189622 time 0.0317937 copy! 0 SNES Function norm 5.510229536082e+00 1 SNES Function norm 4.496811351139e-03 16 TS dt 0.00172953 time 0.0336899 copy! 0 SNES Function norm 6.945417639798e+00 1 SNES Function norm 4.569326335543e-03 17 TS dt 0.00218527 time 0.0354194 copy! 0 SNES Function norm 1.351474156680e+01 1 SNES Function norm 1.719775600164e-02 18 TS dt 0.00224386 time 0.0376047 copy! 0 SNES Function norm 2.174969556700e+01 1 SNES Function norm 3.814212178889e-02 0 SNES Function norm 4.891415655138e+01 1 SNES Function norm 6.772042718901e-02 0 SNES Function norm 2.828143585009e+01 1 SNES Function norm 6.965842377755e-03 0 SNES Function norm 2.168193335917e+01 1 SNES Function norm 2.463212234975e-03 19 TS dt 0.000205482 time 0.0378175 copy! 0 SNES Function norm 1.409435206457e+00 1 SNES Function norm 1.859628755245e-02 20 TS dt 0.000188785 time 0.0380229 copy! Write output at step= 20! 0 SNES Function norm 5.900261363044e-01 1 SNES Function norm 2.653576084845e-02 0 SNES Function norm 5.122905363140e+00 1 SNES Function norm 4.297068425492e-03 0 SNES Function norm 3.428448792746e+00 1 SNES Function norm 1.000610664096e-02 21 TS dt 6.50511e-05 time 0.0380738 copy! 0 SNES Function norm 3.700405789863e-01 1 SNES Function norm 6.263642369355e-02 22 TS dt 7.93452e-05 time 0.0381388 copy! 0 SNES Function norm 5.282939288286e-01 1 SNES Function norm 3.003209840754e-01 23 TS dt 7.50242e-05 time 0.0382181 copy! 0 SNES Function norm 7.079201595974e-01 1 SNES Function norm 1.247544399226e-02 24 TS dt 0.000150048 time 0.0382932 copy! 0 SNES Function norm 6.197633272307e-01 1 SNES Function norm 3.176914154297e-02 25 TS dt 0.000171939 time 0.0384432 copy! 0 SNES Function norm 5.849423362557e-01 1 SNES Function norm 9.462256964187e-03 26 TS dt 0.000176855 time 0.0386152 copy! 0 SNES Function norm 4.304951653234e-01 1 SNES Function norm 3.939112950208e-03 -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<https://nam04.safelinks.protection.outlook.com/?url=http:%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=04%7C01%7Cskavou1%40lsu.edu%7C647e2e1d2354483d00cd08d903f72940%7C2d4dad3f50ae47d983a09ae2b1f466f8%7C0%7C0%7C637545182357863533%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=U9kUKpcqDvvtZUvnvvydYXwABgzYihSzrApF3ik5dnQ%3D&reserved=0>
Let's look at the first one: 0 SNES Function norm 1.465357113711e+01 1 SNES Function norm 1.131764004094e+02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 This is not usually what we mean by convergence. The SNES has been told, using -snes_type ksponly, to take only one step, but it still has a huge residual. In fact, the residual is growing. This suggests the system is not actually being solved. Thanks, Matt
------------------------------ *From:* Matthew Knepley <[email protected]> *Sent:* Tuesday, April 20, 2021 7:23 AM *To:* Sepideh Kavousi <[email protected]> *Cc:* [email protected] <[email protected]> *Subject:* Re: [petsc-users] convergence slow
Matt
Best, Sepideh
https://www.cse.buffalo.edu/~knepley/ <https://nam04.safelinks.protection.outlook.com/?url=http:%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=04%7C01%7Cskavou1%40lsu.edu%7C647e2e1d2354483d00cd08d903f72940%7C2d4dad3f50ae47d983a09ae2b1f466f8%7C0%7C0%7C637545182357863533%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=U9kUKpcqDvvtZUvnvvydYXwABgzYihSzrApF3ik5dnQ%3D&reserved=0>
participants (2)
Matthew Knepley -
Sepideh Kavousi
