parallel computing error
Dear developers I'm trying to use parallel computing and I ran the command 'mpirun -np 4 ./app' In this case, there are two problems. *First,* I encountered error message /// [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [1]PETSC ERROR: Invalid argument [1]PETSC ERROR: Comm must be of size 1 /// The code on the error position is MatCreateSeqDense(PETSC_COMM_SELF, nns, ns, NULL, &Kns)); Could "MatCreateSeqDense" not be used in parallel computing? *Second*, the same error message is repeated as many times as the number of cores. if I use command -np 4, then the error message is repeated 4 times. Could you recommend some advice related to this? Best, Seung Lee Kwon -- Seung Lee Kwon, Ph.D.Candidate Aerospace Structures and Materials Laboratory Department of Mechanical and Aerospace Engineering Seoul National University Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826 E-mail : [email protected] Office : +82-2-880-7389 C. P : +82-10-4695-1062
On Wed, May 3, 2023 at 6:05 AM 권승리 / 학생 / 항공우주공학과 <[email protected]> wrote:
Dear developers
1) "Seq" means sequential, that is "not parallel". 2) This line should still be fine since PETSC_COMM_SELF is a serial communicator 3) You should be checking the error code for each call, maybe using the CHKERRQ() macro 4) Please always send the entire error message, not a snippet THanks Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Dear developers Thank you for your explanation. But I should use the MatCreateSeqDense because I want to use the MatMatSolve that B matrix must be a SeqDense matrix. Using MatMatSolve is an inevitable part of my code. Could you give me a comment to avoid this error? Best, Seung Lee Kwon 2023년 5월 3일 (수) 오후 7:30, Matthew Knepley <[email protected]>님이 작성:
Dear developers
THanks
Matt
You can configure with MUMPS ./configure --download-mumps --download-scalapack --download-ptscotch --download-metis --download-parmetis And then use MatMatSolve() as in src/mat/tests/ex125.c with parallel MatMatSolve() using MUMPS as the solver. Barry
On May 3, 2023, at 10:29 PM, 권승리 / 학생 / 항공우주공학과 <[email protected]> wrote:
Dear developers
Best,
Seung Lee Kwon
2023년 5월 3일 (수) 오후 7:30, Matthew Knepley <[email protected] <mailto:[email protected]>>님이 작성:
On Wed, May 3, 2023 at 6:05 AM 권승리 / 학생 / 항공우주공학과 <[email protected] <mailto:[email protected]>> wrote:
Dear developers
First, I encountered error message /// [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [1]PETSC ERROR: Invalid argument [1]PETSC ERROR: Comm must be of size 1 /// The code on the error position is MatCreateSeqDense(PETSC_COMM_SELF, nns, ns, NULL, &Kns));
THanks
Matt
Second, the same error message is repeated as many times as the number of cores. if I use command -np 4, then the error message is repeated 4 times. Could you recommend some advice related to this?
-- Seung Lee Kwon, Ph.D.Candidate Aerospace Structures and Materials Laboratory Department of Mechanical and Aerospace Engineering Seoul National University Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826 E-mail : [email protected] <mailto:[email protected]> Office : +82-2-880-7389 C. P : +82-10-4695-1062
Dear Barry Smith Thank you for your reply. I've already installed MUMPS. And I checked the example you said (ex125.c), I don't understand why the RHS matrix becomes the SeqDense matrix. Could you explain in more detail? Best regards Seung Lee Kwon 2023년 5월 4일 (목) 오후 12:08, Barry Smith <[email protected]>님이 작성:
Barry
Dear developers
Best,
Seung Lee Kwon
Dear developers
THanks
Matt
The code in ex125.c contains PetscCall(MatCreate(PETSC_COMM_WORLD, &C)); PetscCall(MatSetOptionsPrefix(C, "rhs_")); PetscCall(MatSetSizes(C, m, PETSC_DECIDE, PETSC_DECIDE, nrhs)); PetscCall(MatSetType(C, MATDENSE)); PetscCall(MatSetFromOptions(C)); PetscCall(MatSetUp(C)); This dense parallel matrix is suitable for passing to MatMatSolve() as the right-hand side matrix. Note it is created with PETSC_COMM_WORLD and its type is set to be MATDENSE. You may need to make a sample code by stripping out all the excess code in ex125.c to just create an MATAIJ and MATDENSE and solves with MatMatSolve() to determine why you code does not work.
On May 4, 2023, at 3:20 AM, 권승리 / 학생 / 항공우주공학과 <[email protected]> wrote:
Dear Barry Smith
2023년 5월 4일 (목) 오후 12:08, Barry Smith <[email protected] <mailto:[email protected]>>님이 작성:
Barry
On May 3, 2023, at 10:29 PM, 권승리 / 학생 / 항공우주공학과 <[email protected] <mailto:[email protected]>> wrote:
Dear developers
Best,
Seung Lee Kwon
Dear developers
THanks
Matt
Dear Barry Smith Thanks to you, I knew the difference between MATAIJ and MATDENSE. However, I still have some problems. There is no problem when I run with a single core. But, MatGetFactor error occurs when using multi-core. Could you give me some advice? The error message is [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: See https://petsc.org/release/overview/linear_solve_table/ for possible LU and Cholesky solvers [0]PETSC ERROR: MatSolverType petsc does not support matrix type mpidense [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting. [0]PETSC ERROR: Petsc Release Version 3.18.5, unknown [0]PETSC ERROR: ./app on a arch-linux-c-opt named ubuntu by ksl Fri May 5 00:35:23 2023 [0]PETSC ERROR: Configure options --download-mpich --with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3 -march=native -mtune=native" --download-mumps --download-scalapack --download-parmetis --download-metis --download-parmetis --download-hpddm --download-slepc [0]PETSC ERROR: #1 MatGetFactor() at /home/ksl/petsc/src/mat/interface/matrix.c:4757 [0]PETSC ERROR: #2 main() at /home/ksl/Downloads/coding_test/coding/a1.c:66 [0]PETSC ERROR: No PETSc Option Table entries [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] application called MPI_Abort(MPI_COMM_SELF, 92) - process 0 My code is below: int main(int argc, char** args) { Mat A, E, A_temp, A_fac; int n = 15; PetscInitialize(&argc, &args, NULL, NULL); PetscCallMPI(MPI_Comm_size(PETSC_COMM_WORLD, &size)); PetscCall(MatCreate(PETSC_COMM_WORLD, &A)); PetscCall(MatSetType(A,MATDENSE)); PetscCall(MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, n, n)); PetscCall(MatSetFromOptions(A)); PetscCall(MatSetUp(A)); // Insert values double val; for (int i = 0; i < n; i++) { for (int j = 0; j < n; j++) { if (i == j){ val = 2.0; } else{ val = 1.0; } PetscCall(MatSetValue(A, i, j, val, INSERT_VALUES)); } } PetscCall(MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY)); PetscCall(MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY)); // Make Identity matrix PetscCall(MatCreate(PETSC_COMM_WORLD, &E)); PetscCall(MatSetType(E,MATDENSE)); PetscCall(MatSetSizes(E, PETSC_DECIDE, PETSC_DECIDE, n, n)); PetscCall(MatSetFromOptions(E)); PetscCall(MatSetUp(E)); PetscCall(MatShift(E,1.0)); PetscCall(MatAssemblyBegin(E, MAT_FINAL_ASSEMBLY)); PetscCall(MatAssemblyEnd(E, MAT_FINAL_ASSEMBLY)); PetscCall(MatDuplicate(A, MAT_DO_NOT_COPY_VALUES, &A_temp)); PetscCall(MatGetFactor(A, MATSOLVERPETSC, MAT_FACTOR_LU, &A_fac)); IS isr, isc; MatFactorInfo info; MatGetOrdering(A, MATORDERINGNATURAL, &isr, &isc); PetscCall(MatLUFactorSymbolic(A_fac, A, isr, isc, &info)); PetscCall(MatLUFactorNumeric(A_fac, A, &info)); MatMatSolve(A_fac, E, A_temp); PetscCall(MatView(A_temp, PETSC_VIEWER_STDOUT_WORLD)); MatDestroy(&A); MatDestroy(&A_temp); MatDestroy(&A_fac); MatDestroy(&E); PetscCall(PetscFinalize()); } Best regards Seung Lee Kwon 2023년 5월 4일 (목) 오후 10:19, Barry Smith <[email protected]>님이 작성:
Dear Barry Smith
Barry
Dear developers
Best,
Seung Lee Kwon
Dear developers
THanks
Matt
On Fri, May 5, 2023 at 3:49 AM 권승리 / 학생 / 항공우주공학과 <[email protected]> wrote:
Dear Barry Smith
PETSc uses 3rd party packages for parallel dense factorization. You would need to reconfigure with either ScaLAPACK or Elemental. Thanks, Matt
My code is below:
Dear Barry Smith
Barry
Dear developers
Best,
Seung Lee Kwon
Dear developers
THanks
Matt
Dear Matthew Knepley However, I've already installed ScaLAPACK. cd $PETSC_DIR ./configure --download-mpich --with-debugging=0 COPTFLAGS='-O3 -march=native -mtune=native' CXXOPTFLAGS='-O3 -march=native -mtune=native' FOPTFLAGS='-O3 -march=native -mtune=native' --download-mumps -- *download-scalapack* --download-parmetis --download-metis --download-parmetis --download-hpddm --download-slepc Is there some way to use ScaLAPCK? Or, Can I run the part related to MatMatSolve with a single core? 2023년 5월 5일 (금) 오후 6:21, Matthew Knepley <[email protected]>님이 작성:
Dear Barry Smith
Matt
My code is below:
Dear Barry Smith
Barry
Dear developers
Best,
Seung Lee Kwon
Dear developers
THanks
Matt
However, I've already installed ScaLAPACK. cd $PETSC_DIR ./configure --download-mpich --with-debugging=0 COPTFLAGS='-O3 -march=native -mtune=native' CXXOPTFLAGS='-O3 -march=native -mtune=native' FOPTFLAGS='-O3 -march=native -mtune=native' --download-mumps --download-scalapack --download-parmetis --download-metis --download-parmetis --download-hpddm --download-slepc
You need to convert your MatDense to MatSCALAPACK before the call to MatMatSolve(). This library (ScaLAPACK, but also Elemental) has severe limitations with respect to the matrix distribution. Depending on what you are doing, you may be better of using KSPMatSolve() and computing only an approximation of the solution with a cheap preconditioner (I don’t recall you telling us why you need to do such an operation even though we told you it was not practical — or maybe I’m being confused by another thread). Thanks, Pierre
2023년 5월 5일 (금) 오후 6:21, Matthew Knepley <[email protected] <mailto:[email protected]>>님이 작성:
On Fri, May 5, 2023 at 3:49 AM 권승리 / 학생 / 항공우주공학과 <[email protected] <mailto:[email protected]>> wrote:
Dear Barry Smith
Matt
My code is below:
2023년 5월 4일 (목) 오후 10:19, Barry Smith <[email protected] <mailto:[email protected]>>님이 작성:
On May 4, 2023, at 3:20 AM, 권승리 / 학생 / 항공우주공학과 <[email protected] <mailto:[email protected]>> wrote:
Dear Barry Smith
Barry
Dear developers
Best,
Seung Lee Kwon
Dear developers
THanks
Matt
Dear Pierre Jolivet Thank you for your explanation. I will try to use a converting matrix. I know it's really inefficient, but I need an inverse matrix (inv(A)) itself for my research. If parallel computing is difficult to get inv(A), can I run the part related to MatMatSolve with a single core? Best, Seung Lee Kwon 2023년 5월 5일 (금) 오후 8:35, Pierre Jolivet <[email protected]>님이 작성:
Thanks, Pierre
Dear Barry Smith
Matt
My code is below:
Dear Barry Smith
Barry
Dear developers
Best,
Seung Lee Kwon
Dear developers
THanks
Matt
On 5 May 2023, at 2:00 PM, 권승리 / 학생 / 항공우주공학과 <[email protected]> wrote:
Dear Pierre Jolivet
Yes. Thanks, Pierre
2023년 5월 5일 (금) 오후 8:35, Pierre Jolivet <[email protected] <mailto:[email protected]>>님이 작성:
On 5 May 2023, at 1:25 PM, 권승리 / 학생 / 항공우주공학과 <[email protected] <mailto:[email protected]>> wrote:
Thanks, Pierre
Dear Barry Smith
Matt
My code is below:
Dear Barry Smith
Barry
Dear developers
Best,
Seung Lee Kwon
Dear developers
THanks
Matt
participants (4)
Barry Smith -
Matthew Knepley -
Pierre Jolivet -
권승리 / 학생 / 항공우주공학과
