self-defined preconditioner available?
Hi, I was wondering if petsc could convert an existing matrix into a preconditioner and use it in ksp solvers...thought this shall be a straight-forward question but I didn't find the answer in manuals. Thanks a lot. Regards, Xiaoyin Ji
Xiaoyin:
Yes, you can. See "Shell Preconditioners" in petsc user manual. Also, check out ~petsc/src/ksp/ksp/examples/tutorials/ex15.c as an example. Hong
It is unclear what you mean. Do you mean use the MatMult() for an existing matrix as a preconditioner application for some other matrix? If so then use PCType of PCMAT and call KSPSetOperators() or SNESSetJacobian() with two different matrices the first that defines the linear system and the second that you wish to use directly as the preconditioner. See the manual page for PCMAT. If you mean something else please explain. Barry On Dec 19, 2010, at 10:17 PM, Xiaoyin Ji wrote:
Xiaoyin Ji
participants (3)
Barry Smith -
Hong Zhang -
Xiaoyin Ji
