Question about the performance of KSP solver
Hi, I'm using the GMRES with ASM preconditioner with sub-domain solver ILU(2) to solve an elasticity problem. First, I use 16 cores to test the computation time, then use 32 cores to run the same code with the same parameters. But I just get about 10% speed up. From the log file I found that the computation time of KSPSolve() and MatSolve() just decrease a little bit. My PETSc version is 3.16.0 and use --with-debugging=0 when configure it. The matrix size is about 7*10^6. Some detail of the log is shown below: 16-cores: ------------------------------------------------------------------------------------------------------------------------ Event Count Time (sec) Flop --- Global --- --- Stage ---- Total Max Ratio Max Ratio Max Ratio Mess AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s ------------------------------------------------------------------------------------------------------------------------ MatMult 664 1.0 5.0794e+01 1.6 2.70e+10 1.1 7.1e+04 4.8e+04 1.0e+00 7 13 49 20 0 7 13 49 20 0 8010 MatSolve 663 1.0 1.9868e+02 1.1 1.43e+11 1.1 0.0e+00 0.0e+00 0.0e+00 33 70 0 0 0 33 70 0 0 0 10932 MatLUFactorNum 1 1.0 6.1501e+00 1.1 1.40e+10 1.1 0.0e+00 0.0e+00 0.0e+00 1 7 0 0 0 1 7 0 0 0 35056 MatILUFactorSym 1 1.0 1.5566e+01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0 KSPSetUp 2 1.0 5.9627e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0 KSPSolve 1 1.0 2.5168e+02 1.0 1.90e+11 1.1 1.4e+05 4.8e+04 1.3e+03 44 93 98 40 89 44 93 98 40 90 11437 KSPGMRESOrthog 641 1.0 1.8980e+01 1.7 1.82e+10 1.1 0.0e+00 0.0e+00 6.4e+02 3 9 0 0 43 3 9 0 0 44 14578 PCSetUp 2 1.0 2.2480e+01 1.1 1.40e+10 1.1 5.3e+02 6.5e+05 7.0e+00 4 7 0 2 0 4 7 0 2 0 9591 PCSetUpOnBlocks 1 1.0 2.1555e+01 1.1 1.40e+10 1.1 0.0e+00 0.0e+00 0.0e+00 3 7 0 0 0 3 7 0 0 0 10002 PCApply 663 1.0 2.0296e+02 1.1 1.43e+11 1.1 7.0e+04 4.8e+04 1.0e+00 33 70 49 20 0 33 70 49 20 0 10701 PCApplyOnBlocks 663 1.0 1.9908e+02 1.1 1.43e+11 1.1 0.0e+00 0.0e+00 0.0e+00 33 70 0 0 0 33 70 0 0 0 10910 32-cores: ------------------------------------------------------------------------------------------------------------------------ Event Count Time (sec) Flop --- Global --- --- Stage ---- Total Max Ratio Max Ratio Max Ratio Mess AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s ------------------------------------------------------------------------------------------------------------------------ MatMult 671 1.0 4.7602e+01 2.0 1.39e+10 1.1 1.7e+05 2.8e+04 1.0e+00 7 13 49 23 0 7 13 49 23 0 8637 MatSolve 670 1.0 1.7800e+02 1.1 7.56e+10 1.1 0.0e+00 0.0e+00 0.0e+00 33 71 0 0 0 33 71 0 0 0 12544 MatLUFactorNum 1 1.0 3.5714e+00 1.1 7.16e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 7 0 0 0 1 7 0 0 0 60743 MatILUFactorSym 1 1.0 8.4088e+00 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0 KSPSetUp 2 1.0 3.8060e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0 KSPSolve 1 1.0 2.1680e+02 1.0 9.95e+10 1.1 3.5e+05 2.8e+04 1.3e+03 44 93 98 47 89 44 93 98 47 90 13592 KSPGMRESOrthog 648 1.0 1.6999e+01 2.0 9.39e+09 1.1 0.0e+00 0.0e+00 6.5e+02 2 9 0 0 43 2 9 0 0 44 16450 PCSetUp 2 1.0 1.2439e+01 1.1 7.16e+09 1.1 1.3e+03 3.7e+05 7.0e+00 2 7 0 2 0 2 7 0 2 0 17440 PCSetUpOnBlocks 1 1.0 1.1876e+01 1.1 7.16e+09 1.1 0.0e+00 0.0e+00 0.0e+00 2 7 0 0 0 2 7 0 0 0 18267 PCApply 670 1.0 1.8235e+02 1.1 7.56e+10 1.1 1.7e+05 2.7e+04 1.0e+00 34 71 49 23 0 34 71 49 23 0 12245 PCApplyOnBlocks 670 1.0 1.7838e+02 1.1 7.56e+10 1.1 0.0e+00 0.0e+00 0.0e+00 33 71 0 0 0 33 71 0 0 0 12517 Hope you can help me! Best Regards, Yujie
This is pretty typical. You see the factorization time is significantly better (because their more compute-limited) but MatMult and MatSolve are about the same because they are limited by memory bandwidth. On most modern architectures, the bandwidth is saturated with 16 cores or so. https://petsc.org/release/faq/#what-kind-of-parallel-computers-or-clusters-a... If you haven't yet, I recommend trying to use AMG for this problem. You should call MatSetNearNullSpace() to set the rigid body modes and then use -pc_type gamg or (with external packages -pc_type ml and -pc_type hypre). The iteration count should be much less and solves reasonably fast. If you're interested in using different data structures, our experience is that we can solve similar problem sizes using Q2 elements in a few seconds (2-10) on a single node. Gong Yujie <[email protected]> writes:
Best Regards, Yujie
Ah, "cores". Jed is right if these are cores on one socket. On Sun, Feb 27, 2022 at 10:16 AM Jed Brown <[email protected]> wrote:
16-cores:
32-cores:
Best Regards, Yujie
Hi, Sanjay. The method uses matrix-free p-multigrid with AMG coarse solves. Attached is one of the models we're using as a test problem (hyperelastic model on an extruded Schwarz-P surface). Docs for the code we're using. https://ratel.micromorph.org/ https://gitlab.com/micromorph/ratel https://doi.org/10.21105/joss.02945 (about libCEED's data structures) We'd love to test these methods out on more problems. We're working on improving integration with PETSc -- the goal is that users of PETSc will be able to write libCEED qfunctions and run with these data structures (which are optimized for both CPU and GPU) with almost no other code modifications. Sanjay Govindjee <[email protected]> writes:
Hi Jed, Do you have a reference for this? -sanjay
First, you probably want -ksp_type cg ILU sucks, you can try 'gamg' and I would configure it with hypre and try that also. Now, you are getting very little increase in flop rate on MatMult (8K -->8.6K). That is the problem * You have a "bad" network * Your problem is too small (with respect to your network) to get speedup after 16 porcs * Bad partitioning * You have a fair amount of load imbalance (MatMult 671 1.0 4.7602e+01 *2.0* ), and it gets worse at 32 procs. That can be from bad partitioning or a bad network. With a decent network you probably want to keep at least 25K equations per processor. This depends on these other issues, but it is a start. With a good network you should be able to get down to 10K/proc It is best to start with a simple model problem like a cube, with cube shaped subdomains is ideal, and isolate issues. Mark On Sun, Feb 27, 2022 at 9:51 AM Gong Yujie <[email protected]> wrote:
Best Regards, Yujie
We should think about have -log_view automatically running streams on subsets of ranks and using the resulting information to provide guidance to users on interpretating the -log_view output instead of expecting users to run streams themselves on their system and then figuring out what to do.
On Feb 27, 2022, at 9:50 AM, Gong Yujie <[email protected]> wrote:
Best Regards, Yujie
Probably not implied by -log_view alone, but -streams_view or some such doing it automatically would save having to context switch elsewhere to obtain that data. Barry Smith <[email protected]> writes:
Best Regards, Yujie
At PetscLogView() the code could see how long the run was, if it was greater than n seconds it could automatically run a few levels of streams (taking presumably well less than a few seconds) and adjust suitable the output. If the user runs, for example, 10min they surely don't mind .5 seconds to get more useful information.
Best Regards, Yujie
I assume this would be running VecWAXPY on CPU (and GPU) with some empty ranks? I'd be mildly concerned about allocating GPU memory because a crash here would be really bad. Barry Smith <[email protected]> writes:
Best Regards, Yujie
This would be after the user code is complete, PETSc memory has all been freed and we can put a signal catch around the code to prevent such crashes.
Best Regards, Yujie
That's sounds okay, just need to be able to guarantee that no system errors can prevent us from finishing writing the -log_view. Barry Smith <[email protected]> writes:
Best Regards, Yujie
Could even write the "normal" logview information before gathering the data to ensure no early crash.
Best Regards, Yujie
participants (5)
Barry Smith -
Gong Yujie -
Jed Brown -
Mark Adams -
Sanjay Govindjee
