Hi all, I want to use PETSc with 64-bit indices with a Fortran90 code. It seems some PETSc functions have no problem, but some of the others do not accept 32-bit error code integer (e.g., "ierr" declared as PetscErrorCode type). For example, call DMPlexGetChart(dm, pst, pend, ierr);CHKERRA(ierr) works okay, but call DMPlexGetDepthStratum(dm, 0, vst, vend, ierr);CHKERRA(ierr) gives an error regarding the datatype of ierr. The error basically leads: Error: Type mismatch in argument ‘b’ at (1); passed INTEGER(4) to INTEGER(8) I tried to declare ierr as integer(kind=8) type, but there are still some problems. If PETSc is configured with 32-bit indices, the Fortran code works without problem. What surprising to me is that as mentioned above, DMPlexGetChart() works okay, but DMPlexGetDepthStratum() does not work with "ierr (PetscErrorCode type)" variable with 64-bit indices. Can I get any comments on it? Thanks, Mike
Check petsc examples You would use 'PetscErrorCode ierr' - not 'INTEGER(4) or INTEGER(8) Some routines probably don't have Interface definitions - hence compiler can't cat this issue with all functions. [but they all consistently need PetscErrorCode] Satish On Wed, 1 Feb 2023, Mike Michell wrote:
Hi all,
For example,
but
Thanks, Mike
@Satish and Blaise - Thank you for the notes. @Satish - When you say: "Some routines probably don't have Interface definitions - hence compiler can't cat this issue with all functions." Does it mean that I cannot use 64-bit option for those routines, which do not have the interface definitions? Thanks, Mike
I use the following I all my fortran codes (inspired by a post from Michael Metcalf on comp.lang.fortran many many moons ago):
PetscReal,Parameter :: PReal = 1.0 Integer,Parameter,Public :: Kr = Selected_Real_Kind(Precision(PReal)) PetscInt,Parameter :: PInt = 1 Integer,Parameter,Public :: Ki = kind(PInt)
You will need to pass constant with their kind (i.e. 1_Ki instead of 1)
The advantage of this approach over explicitly trying to figure out the proper type of integer ois that the same code will automatically work with 32 and 64 bit indices.
I’ve been wondering if petsc should include these definitions (perhaps under another name).
Blaise
On Feb 1, 2023, at 2:58 PM, Mike Michell <[email protected]> wrote:
Hi all,
For example,
but
Thanks, Mike
— Canada Research Chair in Mathematical and Computational Aspects of Solid Mechanics (Tier 1) Professor, Department of Mathematics & Statistics Hamilton Hall room 409A, McMaster University 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
sorry - meant to say 'catch' [not cat]
All routines are usable. Its just that compiler treats routines without interface definitions as F77 - and it won't verify the data-types of arguments passed in. [i.e F77 mode..] But I do see interface defs for both DMPlexGetDepthStratum() and DMPlexGetChart() so don't know why they behave differently for you. src/dm/f90-mod/ftn-auto-interfaces/petscdmplex.h90
subroutine DMPlexGetDepthStratum(a,b,c,d,z) import tDM DM a ! DM PetscInt b ! PetscInt PetscInt c ! PetscInt PetscInt d ! PetscInt PetscErrorCode z end subroutine DMPlexGetDepthStratum
subroutine DMPlexGetChart(a,b,c,z) import tDM DM a ! DM PetscInt b ! PetscInt PetscInt c ! PetscInt PetscErrorCode z end subroutine DMPlexGetChart Satish
Thanks, Mike
Blaise
Hi all,
For example,
but
Thanks, Mike
Ok - I think the error here is with '0' - not ierr. Use:
PetscInt zero zero = 0 call DMPlexGetDepthStratum(dm, zero, vst, vend, ierr);CHKERRA(ierr) <<<
Satish
Thanks, Mike
Blaise
Hi all,
For example,
but
Thanks, Mike
That was the real problem indeed! Thanks a lot for the help. Mike
Use:
Satish
Satish
Thanks, Mike
the
Blaise
Hi all,
For example,
but
Thanks, Mike
participants (3)
Blaise Bourdin -
Mike Michell -
Satish Balay
