I am getting some sort of error in build zlib on Spock at ORNL. Other libraries are downloaded and I am sure the network is fine. Any ideas? Thanks, Mark
Mark, You can try what the configure error message should be suggesting (it is not clear if that is being printed to your screen or no). ERROR: Unable to download package ZLIB from: http://www.zlib.net/zlib-1.2.11.tar.gz * If URL specified manually - perhaps there is a typo? * If your network is disconnected - please reconnect and rerun ./configure * Or perhaps you have a firewall blocking the download * You can run with --with-packages-download-dir=/adirectory and ./configure will instruct you what packages to download manually * or you can download the above URL manually, to /yourselectedlocation/zlib-1.2.11.tar.gz and use the configure option: --download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz Barry
On Jul 6, 2021, at 4:29 PM, Mark Adams <[email protected]> wrote:
I am getting some sort of error in build zlib on Spock at ORNL. Other libraries are downloaded and I am sure the network is fine. Any ideas? Thanks, Mark <configure.log>
I see this: ============================================================================================= Trying to download http://www.zlib.net/zlib-1.2.11.tar.gz for ZLIB ============================================================================================= ============================================================================================= Building and installing zlib; this may take several minutes ============================================================================================= ******************************************************************************* UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details): ------------------------------------------------------------------------------- Error building/install zlib files from /gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/externalpackages/zlib-1.2.11/zlib to /gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/externalpackages/zlib-1.2.11 ******************************************************************************* And I did look in the configure log and saw these suggestions, but I was so confused by this output that I did not want to chase it down. I will try this --download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz stuff. Thanks, On Tue, Jul 6, 2021 at 6:42 PM Barry Smith <[email protected]> wrote:
Mark,
Barry
Mark,
My browser can not open this and I could not see a download button on this site. Can you download this?
Barry
$ curl http://www.zlib.net/zlib-1.2.11.tar.gz > zlib-1.2.11.tar.gz % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 593k 100 593k 0 0 835k 0 --:--:-- --:--:-- --:--:-- 834k ~/Src/petsc (barry/2021-07-03/demonstrate-network-parallel-build=) arch-demonstrate-network-parallel-build $ tar -zxf zlib-1.2.11.tar.gz ~/Src/petsc (barry/2021-07-03/demonstrate-network-parallel-build=) arch-demonstrate-network-parallel-build $ ls zlib-1.2.11 CMakeLists.txt adler32.c deflate.c gzread.c inflate.h os400 watcom zlib.h ChangeLog amiga deflate.h gzwrite.c inftrees.c qnx win32 zlib.map FAQ compress.c doc infback.c inftrees.h test zconf.h zlib.pc.cmakein INDEX configure examples inffast.c make_vms.com treebuild.xml zconf.h.cmakein zlib.pc.in Makefile contrib gzclose.c inffast.h msdos trees.c zconf.h.in zlib2ansi Makefile.in crc32.c gzguts.h inffixed.h nintendods trees.h zlib.3 zutil.c README crc32.h gzlib.c inflate.c old uncompr.c zlib.3.pdf zutil.h
On Jul 6, 2021, at 7:57 PM, Mark Adams <[email protected]> wrote:
On Tue, Jul 6, 2021 at 6:42 PM Barry Smith <[email protected] <mailto:[email protected]>> wrote:
Mark,
ERROR: Unable to download package ZLIB from: http://www.zlib.net/zlib-1.2.11.tar.gz <http://www.zlib.net/zlib-1.2.11.tar.gz>
Barry
On Jul 6, 2021, at 4:29 PM, Mark Adams <[email protected] <mailto:[email protected]>> wrote:
Apparently the same error with --download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz On Tue, Jul 6, 2021 at 11:53 PM Barry Smith <[email protected]> wrote:
$ curl http://www.zlib.net/zlib-1.2.11.tar.gz > zlib-1.2.11.tar.gz % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 593k 100 593k 0 0 835k 0 --:--:-- --:--:-- --:--:-- 834k ~/Src/petsc* (barry/2021-07-03/demonstrate-network-parallel-build=)* arch-demonstrate-network-parallel-build $ tar -zxf zlib-1.2.11.tar.gz ~/Src/petsc* (barry/2021-07-03/demonstrate-network-parallel-build=)* arch-demonstrate-network-parallel-build $ ls zlib-1.2.11 CMakeLists.txt adler32.c deflate.c gzread.c inflate.h os400 watcom zlib.h ChangeLog amiga deflate.h gzwrite.c inftrees.c qnx win32 zlib.map FAQ compress.c doc infback.c inftrees.h test zconf.h zlib.pc.cmakein INDEX configure examples inffast.c make_vms.com treebuild.xml zconf.h.cmakein zlib.pc.in Makefile contrib gzclose.c inffast.h msdos trees.c zconf.h.in zlib2ansi Makefile.in crc32.c gzguts.h inffixed.h nintendods trees.h zlib.3 zutil.c README crc32.h gzlib.c inflate.c old uncompr.c zlib.3.pdf zutil.h
Mark,
Barry
Also, this is in jczhang/fix-kokkos-includes On Wed, Jul 7, 2021 at 8:46 AM Mark Adams <[email protected]> wrote:
Mark,
Barry
It is hard to see the error. I suspect it is something crazy with the install. Can you run the build by hand? cd /gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/externalpackages/zlib-1.2.11 && CC="cc" CFLAGS="-fPIC -fstack-protector -Qunused-arguments -g -O0 -I${ROCM_PATH}/include" prefix="/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos" ./configure && /usr/bin/gmake -j8 -l307.2 && /usr/bin/gmake install and see what happens, and what the error code is? Thanks, Matt On Wed, Jul 7, 2021 at 8:48 AM Mark Adams <[email protected]> wrote:
Mark,
Barry
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Thanks, 08:30 jczhang/fix-kokkos-includes= /gpfs/alpine/csc314/scratch/adams/petsc$ cd /gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/externalpackages/zlib-1.2.11 && CC="cc" CFLAGS="-fPIC -fstack-protector -Qunused-arguments -g -O0 -I${ROCM_PATH}/include" prefix="/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos" ./configure && /usr/bin/gmake -j8 -l307.2 && /usr/bin/gmake install Checking for shared library support... Building shared library libz.so.1.2.11 with cc. Checking for size_t... Yes. Checking for off64_t... Yes. Checking for fseeko... Yes. Checking for strerror... No. Checking for unistd.h... Yes. Checking for stdarg.h... Yes. Checking whether to use vs[n]printf() or s[n]printf()... using vs[n]printf(). Checking for vsnprintf() in stdio.h... No. WARNING: vsnprintf() not found, falling back to vsprintf(). zlib can build but will be open to possible buffer-overflow security vulnerabilities. Checking for return value of vsprintf()... Yes. Checking for attribute(visibility) support... Yes. cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -c -o example.o test/example.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o adler32.o adler32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o crc32.o crc32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o deflate.o deflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o infback.o infback.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o inffast.o inffast.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o inflate.o inflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o inftrees.o inftrees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o trees.o trees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o zutil.o zutil.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o compress.o compress.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o uncompr.o uncompr.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzclose.o gzclose.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzlib.o gzlib.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzread.o gzread.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzwrite.o gzwrite.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -c -o minigzip.o test/minigzip.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/adler32.o adler32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/crc32.o crc32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/deflate.o deflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/infback.o infback.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/inffast.o inffast.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/inflate.o inflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/inftrees.o inftrees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/trees.o trees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/zutil.o zutil.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/compress.o compress.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/uncompr.o uncompr.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzclose.o gzclose.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzlib.o gzlib.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzread.o gzread.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzwrite.o gzwrite.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -D_FILE_OFFSET_BITS=64 -c -o example64.o test/example.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -D_FILE_OFFSET_BITS=64 -c -o minigzip64.o test/minigzip.c ar rc libz.a adler32.o crc32.o deflate.o infback.o inffast.o inflate.o inftrees.o trees.o zutil.o compress.o uncompr.o gzclose.o gzlib.o gzread.o gzwrite.o cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o example example.o -L. libz.a cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o minigzip minigzip.o -L. libz.a cc -shared -Wl,-soname,libz.so.1,--version-script,zlib.map -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o libz.so.1.2.11 adler32.lo crc32.lo deflate.lo infback.lo inffast.lo inflate.lo inftrees.lo trees.lo zutil.lo compress.lo uncompr.lo gzclose.lo gzlib.lo gzread.lo gzwrite.lo -lc cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o minigzip64 minigzip64.o -L. libz.a cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o example64 example64.o -L. libz.a ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] clang-11: error: linker command failed with exit code 1 (use -v to see invocation) clang-11: error: linker command failed with exit code 1 (use -v to see invocation) gmake: *** [Makefile:292: minigzip] Error 1 gmake: *** Waiting for unfinished jobs.... gmake: *** [Makefile:289: example] Error 1 ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] clang-11: error: linker command failed with exit code 1 (use -v to see invocation) gmake: *** [Makefile:304: minigzip64] Error 1 ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] clang-11: error: linker command failed with exit code 1 (use -v to see invocation) gmake: *** [Makefile:301: example64] Error 1 rm -f libz.so libz.so.1 ln -s libz.so.1.2.11 libz.so ln -s libz.so.1.2.11 libz.so.1 11:03 2 jczhang/fix-kokkos-includes= /gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/externalpackages/zlib-1.2.11$ On Wed, Jul 7, 2021 at 9:18 AM Matthew Knepley <[email protected]> wrote:
Matt
Mark,
Barry
Mark On Spock, you can use https://gitlab.com/petsc/petsc/-/blob/main/config/examples/arch-olcf-spock.p... <https://gitlab.com/petsc/petsc/-/blob/main/config/examples/arch-olcf-spock.py> as a template for your configuration. You need to add libraries as LDFLAGS to resolve the hsa symbols
On Jul 7, 2021, at 5:04 PM, Mark Adams <[email protected]> wrote:
On Wed, Jul 7, 2021 at 9:18 AM Matthew Knepley <[email protected] <mailto:[email protected]>> wrote: It is hard to see the error. I suspect it is something crazy with the install. Can you run the build by hand?
Matt
On Wed, Jul 7, 2021 at 8:48 AM Mark Adams <[email protected] <mailto:[email protected]>> wrote: Also, this is in jczhang/fix-kokkos-includes
On Wed, Jul 7, 2021 at 8:46 AM Mark Adams <[email protected] <mailto:[email protected]>> wrote: Apparently the same error with --download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz
On Tue, Jul 6, 2021 at 11:53 PM Barry Smith <[email protected] <mailto:[email protected]>> wrote: $ curl http://www.zlib.net/zlib-1.2.11.tar.gz <http://www.zlib.net/zlib-1.2.11.tar.gz> > zlib-1.2.11.tar.gz % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 593k 100 593k 0 0 835k 0 --:--:-- --:--:-- --:--:-- 834k ~/Src/petsc (barry/2021-07-03/demonstrate-network-parallel-build=) arch-demonstrate-network-parallel-build $ tar -zxf zlib-1.2.11.tar.gz ~/Src/petsc (barry/2021-07-03/demonstrate-network-parallel-build=) arch-demonstrate-network-parallel-build $ ls zlib-1.2.11 CMakeLists.txt adler32.c deflate.c gzread.c inflate.h os400 watcom zlib.h ChangeLog amiga deflate.h gzwrite.c inftrees.c qnx win32 zlib.map FAQ compress.c doc infback.c inftrees.h test zconf.h zlib.pc.cmakein INDEX configure examples inffast.c make_vms.com <http://make_vms.com/> treebuild.xml zconf.h.cmakein zlib.pc.in <http://zlib.pc.in/> Makefile contrib gzclose.c inffast.h msdos trees.c zconf.h.in <http://zconf.h.in/> zlib2ansi Makefile.in crc32.c gzguts.h inffixed.h nintendods trees.h zlib.3 zutil.c README crc32.h gzlib.c inflate.c old uncompr.c zlib.3.pdf zutil.h
On Jul 6, 2021, at 7:57 PM, Mark Adams <[email protected] <mailto:[email protected]>> wrote:
Mark,
Barry
Cray is idiotic! We have to add MPI and who knows what other libraries to compile anything? Matt On Wed, Jul 7, 2021 at 11:08 AM Stefano Zampini <[email protected]> wrote:
On Spock, you can use https://gitlab.com/petsc/petsc/-/blob/main/config/examples/arch-olcf-spock.p... as a template for your configuration. You need to add libraries as LDFLAGS to resolve the hsa symbols
Matt
Mark,
Barry
Humm, I get this error (I just copied your whole file into here): 12:06 jczhang/fix-kokkos-includes= /gpfs/alpine/csc314/scratch/adams/petsc$ ~/arch-spock-dbg-cray-kokkos.py Traceback (most recent call last): File "/ccs/home/adams/arch-spock-dbg-cray-kokkos.py", line 27, in <module> '--LDFLAGS=-L'+os.environ['ROCM_PATH'],+'lib -lhsa-runtime64', TypeError: bad operand type for unary +: 'str' On Wed, Jul 7, 2021 at 11:08 AM Stefano Zampini <[email protected]> wrote:
Matt
Mark,
Barry
There's an extra comma Il Mer 7 Lug 2021, 18:08 Mark Adams <[email protected]> ha scritto:
Matt
Mark,
Barry
Ok, I tried that but now I get this error. On Wed, Jul 7, 2021 at 12:13 PM Stefano Zampini <[email protected]> wrote:
On Wed, Jul 7, 2021 at 11:08 AM Stefano Zampini < [email protected]> wrote:
Matt
Mark,
Barry
Did you look in /sw/spock/spack-envs/views/rocm-4.1.0lib ? Matt On Wed, Jul 7, 2021 at 12:29 PM Mark Adams <[email protected]> wrote:
Matt
Mark,
Barry
Thanks, it was missing the / '--LDFLAGS=-L'+os.environ['ROCM_PATH'],+'/lib -lhsa-runtime64', On Wed, Jul 7, 2021 at 12:48 PM Matthew Knepley <[email protected]> wrote:
Matt
Matt
Mark,
Barry
Well, still getting these hsa errors: 13:07 jczhang/fix-kokkos-includes= /gpfs/alpine/csc314/scratch/adams/petsc$ !136 cd /gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/externalpackages/zlib-1.2.11 && CC="cc" CFLAGS="-fPIC -fstack-protector -Qunused-arguments -g -O0 -I${ROCM_PATH}/include" prefix="/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos" ./configure && /usr/bin/gmake -j8 -l307.2 && /usr/bin/gmake install Checking for shared library support... Building shared library libz.so.1.2.11 with cc. Checking for size_t... Yes. Checking for off64_t... Yes. Checking for fseeko... Yes. Checking for strerror... No. Checking for unistd.h... Yes. Checking for stdarg.h... Yes. Checking whether to use vs[n]printf() or s[n]printf()... using vs[n]printf(). Checking for vsnprintf() in stdio.h... No. WARNING: vsnprintf() not found, falling back to vsprintf(). zlib can build but will be open to possible buffer-overflow security vulnerabilities. Checking for return value of vsprintf()... Yes. Checking for attribute(visibility) support... Yes. cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -c -o example.o test/example.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o adler32.o adler32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o crc32.o crc32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o deflate.o deflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o infback.o infback.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o inffast.o inffast.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o inflate.o inflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o inftrees.o inftrees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o trees.o trees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o zutil.o zutil.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o compress.o compress.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o uncompr.o uncompr.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzclose.o gzclose.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzlib.o gzlib.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzread.o gzread.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzwrite.o gzwrite.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -c -o minigzip.o test/minigzip.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/adler32.o adler32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/crc32.o crc32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/deflate.o deflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/infback.o infback.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/inffast.o inffast.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/inflate.o inflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/inftrees.o inftrees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/trees.o trees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/zutil.o zutil.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/compress.o compress.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/uncompr.o uncompr.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzclose.o gzclose.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzlib.o gzlib.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzread.o gzread.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzwrite.o gzwrite.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -D_FILE_OFFSET_BITS=64 -c -o example64.o test/example.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -D_FILE_OFFSET_BITS=64 -c -o minigzip64.o test/minigzip.c ar rc libz.a adler32.o crc32.o deflate.o infback.o inffast.o inflate.o inftrees.o trees.o zutil.o compress.o uncompr.o gzclose.o gzlib.o gzread.o gzwrite.o cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o example example.o -L. libz.a cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o minigzip minigzip.o -L. libz.a cc -shared -Wl,-soname,libz.so.1,--version-script,zlib.map -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o libz.so.1.2.11 adler32.lo crc32.lo deflate.lo infback.lo inffast.lo inflate.lo inftrees.lo trees.lo zutil.lo compress.lo uncompr.lo gzclose.lo gzlib.lo gzread.lo gzwrite.lo -lc cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o minigzip64 minigzip64.o -L. libz.a cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o example64 example64.o -L. libz.a ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] clang-11: error: linker command failed with exit code 1 (use -v to see invocation) clang-11: error: linker command failed with exit code 1 (use -v to see invocation) gmake: *** [Makefile:289: example] Error 1 gmake: *** Waiting for unfinished jobs.... gmake: *** [Makefile:292: minigzip] Error 1 ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] clang-11: error: linker command failed with exit code 1 (use -v to see invocation) gmake: *** [Makefile:304: minigzip64] Error 1 ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] clang-11: error: linker command failed with exit code 1 (use -v to see invocation) gmake: *** [Makefile:301: example64] Error 1 rm -f libz.so libz.so.1 ln -s libz.so.1.2.11 libz.so ln -s libz.so.1.2.11 libz.so.1 On Wed, Jul 7, 2021 at 1:05 PM Mark Adams <[email protected]> wrote:
Matt
Matt
Mark,
Barry
You will need to pass the -L arguments appropriately to zlib's ./configure so it can link its shared library appropriately. That is, the zlib configure requires the value obtained with L'+os.environ['ROCM_PATH'],+'/lib -lhsa-runtime64',
On Wed, Jul 7, 2021 at 1:05 PM Mark Adams <[email protected] <mailto:[email protected]>> wrote: Thanks, it was missing the /
On Wed, Jul 7, 2021 at 12:48 PM Matthew Knepley <[email protected] <mailto:[email protected]>> wrote: Did you look in /sw/spock/spack-envs/views/rocm-4.1.0lib ?
Matt
On Wed, Jul 7, 2021 at 12:29 PM Mark Adams <[email protected] <mailto:[email protected]>> wrote: Ok, I tried that but now I get this error.
On Wed, Jul 7, 2021 at 12:13 PM Stefano Zampini <[email protected] <mailto:[email protected]>> wrote: There's an extra comma
Il Mer 7 Lug 2021, 18:08 Mark Adams <[email protected] <mailto:[email protected]>> ha scritto: Humm, I get this error (I just copied your whole file into here):
On Wed, Jul 7, 2021 at 11:08 AM Stefano Zampini <[email protected] <mailto:[email protected]>> wrote: Mark
On Jul 7, 2021, at 5:04 PM, Mark Adams <[email protected] <mailto:[email protected]>> wrote:
Matt
Mark,
Barry
https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/> <configure.log>
It's not clear to me how to do that. I added the -L to my configure script. It is not clear to me how to modify Matt's command.
Matt
Matt
Mark,
Barry
<configure.log>
Can you try this? knepley/feature-orientation-rethink *$:/PETSc3/petsc/petsc-dev$ git diff config/BuildSystem/config/packages/zlib.py diff --git a/config/BuildSystem/config/packages/zlib.py b/config/BuildSystem/config/packages/zlib.py index fbf9bdf4a0a..b76d3625364 100644 --- a/config/BuildSystem/config/packages/zlib.py +++ b/config/BuildSystem/config/packages/zlib.py @@ -25,6 +25,7 @@ class Configure(config.package.Package): self.pushLanguage('C') args.append('CC="'+self.getCompiler()+'"') args.append('CFLAGS="'+self.updatePackageCFlags(self.getCompilerFlags())+'"') + args.append('LDFLAGS="'+self.getLinkerFlags()+'"') args.append('prefix="'+self.installDir+'"') self.popLanguage() args=' '.join(args) Matt
Matt
Matt
Mark,
Barry
<configure.log>
No diffs. I added this: diff --git a/config/BuildSystem/config/packages/zlib.py b/config/BuildSystem/config/packages/zlib.py index fbf9bdf4a0..b76d362536 100644 --- a/config/BuildSystem/config/packages/zlib.py +++ b/config/BuildSystem/config/packages/zlib.py @@ -25,6 +25,7 @@ class Configure(config.package.Package): self.pushLanguage('C') args.append('CC="'+self.getCompiler()+'"') args.append('CFLAGS="'+self.updatePackageCFlags(self.getCompilerFlags())+'"') + args.append('LDFLAGS="'+self.getLinkerFlags()+'"') args.append('prefix="'+self.installDir+'"') self.popLanguage() args=' '.join(args) lines 1-12/12 (END) but it still fails. 15:20 jczhang/fix-kokkos-includes *= /gpfs/alpine/csc314/scratch/adams/petsc$ cd /gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/externalpackages/zlib-1.2.11 && CC="cc" CFLAGS="-fPIC -fstack-protector -Qunused-arguments -g -O0 -I${ROCM_PATH}/include" prefix="/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos" ./configure && /usr/bin/gmake -j8 -l307.2 && /usr/bin/gmake install Checking for shared library support... Building shared library libz.so.1.2.11 with cc. Checking for size_t... Yes. Checking for off64_t... Yes. Checking for fseeko... Yes. Checking for strerror... No. Checking for unistd.h... Yes. Checking for stdarg.h... Yes. Checking whether to use vs[n]printf() or s[n]printf()... using vs[n]printf(). Checking for vsnprintf() in stdio.h... No. WARNING: vsnprintf() not found, falling back to vsprintf(). zlib can build but will be open to possible buffer-overflow security vulnerabilities. Checking for return value of vsprintf()... Yes. Checking for attribute(visibility) support... Yes. cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -c -o example.o test/example.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o adler32.o adler32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o crc32.o crc32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o deflate.o deflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o infback.o infback.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o inffast.o inffast.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o inflate.o inflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o inftrees.o inftrees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o trees.o trees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o zutil.o zutil.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o compress.o compress.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o uncompr.o uncompr.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzclose.o gzclose.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzlib.o gzlib.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzread.o gzread.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -c -o gzwrite.o gzwrite.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -c -o minigzip.o test/minigzip.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/adler32.o adler32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/crc32.o crc32.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/deflate.o deflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/infback.o infback.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/inffast.o inffast.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/inflate.o inflate.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/inftrees.o inftrees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/trees.o trees.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/zutil.o zutil.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/compress.o compress.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/uncompr.o uncompr.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzclose.o gzclose.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzlib.o gzlib.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzread.o gzread.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -DPIC -c -o objs/gzwrite.o gzwrite.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -D_FILE_OFFSET_BITS=64 -c -o example64.o test/example.c cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -I. -D_FILE_OFFSET_BITS=64 -c -o minigzip64.o test/minigzip.c ar rc libz.a adler32.o crc32.o deflate.o infback.o inffast.o inflate.o inftrees.o trees.o zutil.o compress.o uncompr.o gzclose.o gzlib.o gzread.o gzwrite.o cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o example example.o -L. libz.a cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o minigzip minigzip.o -L. libz.a cc -shared -Wl,-soname,libz.so.1,--version-script,zlib.map -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o libz.so.1.2.11 adler32.lo crc32.lo deflate.lo infback.lo inffast.lo inflate.lo inftrees.lo trees.lo zutil.lo compress.lo uncompr.lo gzclose.lo gzlib.lo gzread.lo gzwrite.lo -lc cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o minigzip64 minigzip64.o -L. libz.a cc -fPIC -fstack-protector -Qunused-arguments -g -O0 -I/sw/spock/spack-envs/views/rocm-4.1.0/include -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN -o example64 example64.o -L. libz.a ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lldld.lld: : error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined]/opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lld: ld.lld: error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined]ld.lld : ld.lld: error: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] clang-11: error: linker command failed with exit code 1 (use -v to see invocation) clang-11: error: linker command failed with exit code 1 (use -v to see invocation) gmake: *** [Makefile:292: minigzip] Error 1 gmake: *** Waiting for unfinished jobs.... gmake: *** [Makefile:289: example] Error 1 ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] clang-11: error: linker command failed with exit code 1 (use -v to see invocation) gmake: *** [Makefile:304: minigzip64] Error 1 ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_allocate [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agent_iterate_memory_pools [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_iterate_agents [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_load_scacquire [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_unlock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_signal_destroy [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_get_info [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_lock [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_memory_pool_free [--no-allow-shlib-undefined] ld.lld: error: /opt/cray/pe/mpich/8.1.4/gtl/lib/libmpi_gtl_hsa.so: undefined reference to hsa_amd_agents_allow_access [--no-allow-shlib-undefined] clang-11: error: linker command failed with exit code 1 (use -v to see invocation) gmake: *** [Makefile:301: example64] Error 1 rm -f libz.so libz.so.1 ln -s libz.so.1.2.11 libz.so On Wed, Jul 7, 2021 at 2:03 PM Matthew Knepley <[email protected]> wrote:
Can you try this?
Matt
Matt
Matt
Mark,
You can try what the configure error message should be suggesting (it is not clear if that is being printed to your screen or no).
* If URL specified manually - perhaps there is a typo? * If your network is disconnected - please reconnect and rerun ./configure * Or perhaps you have a firewall blocking the download * You can run with --with-packages-download-dir=/adirectory and ./configure will instruct you what packages to download manually * or you can download the above URL manually, to /yourselectedlocation/zlib-1.2.11.tar.gz and use the configure option: --download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz
Barry
On Jul 6, 2021, at 4:29 PM, Mark Adams <[email protected]> wrote:
I am getting some sort of error in build zlib on Spock at ORNL. Other libraries are downloaded and I am sure the network is fine. Any ideas? Thanks, Mark <configure.log>
<configure.log>
I do see this: 15:43 /sw/spock/spack-envs/views/rocm-4.1.0/lib$ nm libhsa-runtime64.so | grep -n hsa_signal_load_scacquir 349:0000000000074de0 T hsa_signal_load_scacquire 1491:000000000004bef0 t _ZN4rocr3HSA25hsa_signal_load_scacquireE12hsa_signal_s 15:43 /sw/spock/spack-envs/views/rocm-4.1.0/lib$ On Wed, Jul 7, 2021 at 3:45 PM Mark Adams <[email protected]> wrote:
but it still fails.
Can you try this?
Matt
Matt
Matt
Mark,
Barry
<configure.log>
but it still fails.
It is hard to understand how that was added. You can see that 'CC', 'CFLAGS', and 'prefix' are present on the line below, but 'LDFLAGS' is not. That is difficult to reconcile. Thanks, Matt
Can you try this?
Matt
Matt
Matt
On Tue, Jul 6, 2021 at 6:42 PM Barry Smith <[email protected]> wrote:
Mark,
My browser can not open this and I could not see a download button on this site.
Can you download this?
Barry
<configure.log>
participants (4)
Barry Smith -
Mark Adams -
Matthew Knepley -
Stefano Zampini
