[Bug 782] New: worker.pl fails to run on some systems
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=782 Summary: worker.pl fails to run on some systems Product: Swift Version: trunk Platform: PC OS/Version: Linux Status: NEW Severity: normal Priority: P2 Component: Providers AssignedTo: [email protected] ReportedBy: [email protected] CC: [email protected], [email protected], [email protected] I see this while trying to run trunk locally on communicado. On other systems it seems fine. This is the error I see in the swift log (causes the application to fail with an error code of 255) 2012-04-24 14:43:37,707-0500 INFO Block Worker task failed: Bareword "POSIX::EWOULDBLOCK" not allowed while "strict subs" in use at /home/davidk/.globus/coasters/cscript1534233173477550576.pl line 466. Execution of /home/davidk/.globus/coasters/cscript1534233173477550576.pl aborted due to compilation errors. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=782 --- Comment #1 from Mihael Hategan <[email protected]> 2012-04-25 00:19:04 --- Can you try the most recent worker.pl (cog r3377) and see if that fixes it? -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=782 David Kelly <[email protected]> changed: What |Removed |Added ---------------------------------------------------------------------------- Status|NEW |RESOLVED Resolution| |FIXED --- Comment #2 from David Kelly <[email protected]> 2012-04-25 12:15:27 --- Seems to be fixed now. Thanks -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
participants (1)
bugzilla-daemon@mcs.anl.gov
