[Bug 684] New: Feature request: -nosec option for SSH with automatic coasters
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 Summary: Feature request: -nosec option for SSH with automatic coasters Product: Swift Version: trunk Platform: PC OS/Version: Linux Status: NEW Severity: enhancement Priority: Medium Component: Providers AssignedTo: [email protected] ReportedBy: [email protected] CC: [email protected], [email protected], [email protected] This may be related to the changes slated for SSH in 0.94. Currently, when we use the persistent coaster service, we can provide a -nosec option which disables the requirement for security certificates. Could we have a setting that also disables the need for certificates with ssh and automatic coasters? -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 David Kelly <[email protected]> changed: What |Removed |Added ---------------------------------------------------------------------------- Priority|Medium |P1 Status|NEW |ASSIGNED --- Comment #1 from David Kelly <[email protected]> 2012-07-26 17:54:37 --- This would be very useful to have for some things we are doing now with CMTS. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 Mihael Hategan <[email protected]> changed: What |Removed |Added ---------------------------------------------------------------------------- Status|ASSIGNED |RESOLVED Resolution| |FIXED --- Comment #2 from Mihael Hategan <[email protected]> 2012-08-07 00:05:47 --- An alternative solution (an automatic CA) is now in trunk. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #3 from David Kelly <[email protected]> 2012-08-07 12:07:29 --- Should it work with ssh-cl too? I'm trying to test this with a setup we created for CMTS that uses ssh-cl:pbs. This is the error I get: Caused by: org.globus.cog.karajan.workflow.service.channels.ChannelException: org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: GSSException: Defective credential detected [Caused by: [JGLOBUS-5] Proxy file (/tmp/x509up_u1310) not found.] at org.globus.cog.karajan.workflow.service.ChannelFactory.newChannel(ChannelFactory.java:59) at org.globus.cog.karajan.workflow.service.Client.connect(Client.java:116) at org.globus.cog.karajan.workflow.service.Client.newClient(Client.java:72) at org.globus.cog.karajan.workflow.service.channels.ChannelManager.connect(ChannelManager.java:236) at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:256) at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:211) at org.globus.cog.abstraction.coaster.service.CoasterService.start(CoasterService.java:163) ... 1 more The sites.xml: <config> <pool handle="makena-ssh"> <execution provider="coaster" url="makena.uchicago.edu" jobmanager="ssh-cl:pbs"/> <filesystem provider="local" url="none" /> <profile namespace="globus" key="HighOverAllocation">100</profile> <profile namespace="globus" key="LowOverAllocation">100</profile> <profile namespace="globus" key="maxWallTime">00:50:00</profile> <profile namespace="globus" key="maxTime">3600</profile> <profile key="jobsPerNode" namespace="globus">1</profile> <profile key="nodeGranularity" namespace="globus">1</profile> <profile key="maxNodes" namespace="globus">2</profile> <profile key="queue" namespace="globus">devel</profile> <profile key="jobThrottle" namespace="karajan">1.01</profile> <profile key="initialScore" namespace="karajan">10000</profile> <profile key="count" namespace="globus">2</profile> <profile key="jobType" namespace="globus">single</profile> <profile key="ppn" namespace="globus">8</profile> <workdirectory>/home/davidk/rmsd/run042/swiftwork</workdirectory> </pool> </config> The full logs are in /home/davidk/rmsd/run039 on CI. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #4 from Mihael Hategan <[email protected]> 2012-08-07 14:10:01 --- This does not work with ssh-cl (because ssh-cl cannot fake GSI delegation). I can take a look and see if I can convince it to. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #5 from David Kelly <[email protected]> 2012-08-07 14:30:43 --- Cool, thanks, I think ssh-cl would be useful to have if it's relatively easy to do. I tried testing with the regular ssh provider, and seem to be getting this: Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could not submit job Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could not start coaster service Caused by: org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: Failed to find root CA certificate (C=US,O=JavaCoG,OU=AutoCA,CN=Certificate Authority) Execution failed: Failed to find root CA certificate (C=US,O=JavaCoG,OU=AutoCA,CN=Certificate Authority) (/home/davidk/rmsd/run044) Is there something else I need? -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 Mihael Hategan <[email protected]> changed: What |Removed |Added ---------------------------------------------------------------------------- Status|RESOLVED |REOPENED Resolution|FIXED | --- Comment #6 from Mihael Hategan <[email protected]> 2012-08-07 16:19:54 --- You shouldn't need anything else. Can I have the log and the output of 'ls -alR ~/.globus' on both client and remote sites? -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #7 from David Kelly <[email protected]> 2012-08-08 09:14:45 --- The ls output and swift log is at: http://www.ci.uchicago.edu/~davidk/logs/logs-ssh-20120808.tar.gz -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #8 from David Kelly <[email protected]> 2012-08-08 16:12:51 --- I think this may be causing some issues when using coaster/local:local. Without a proxy, it fails with a message about a missing proxy. http://www.ci.uchicago.edu/~davidk/logs/serialforeach-20120808-1557-c7kl6jbb... With a proxy, I see a message that says "Discarding connection" and seems to make no progress. http://www.ci.uchicago.edu/~davidk/logs/serialforeach-20120808-1605-thp0au3e... -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #9 from Mihael Hategan <[email protected]> 2012-08-08 20:41:24 --- (In reply to comment #8)
The above should now be fixed.
That shouldn't be happening, but check with the last update and let me know if it's still there. As for the SSH root CA issue, I suspect it might be a problem with the way trusted certificates are loaded in jglobus. Can you update and run with the latest code? I added some code to print a list of trusted CAs so we can confirm if that's the case. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #10 from David Kelly <[email protected]> 2012-08-09 01:41:19 --- The issue with coasters/local:local seem to be fine now. The new logs are at: http://www.ci.uchicago.edu/~davidk/logs/logs-ssh-20120809.tar.gz -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #11 from Mihael Hategan <[email protected]> 2012-08-09 03:29:17 --- (In reply to comment #10)
Sorry. CoGProperties ignores setProxyFile and setCaCertLocations if the respective system properties are set (and those are set if the env variables are set). The latest version sets the system properties instead. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #12 from David Kelly <[email protected]> 2012-08-09 13:57:17 --- It looks like it's getting further - the error I am seeing now is: No signing policy file found http://www.ci.uchicago.edu/~davidk/logs/logs-ssh-20120809-2.tar.gz -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #13 from Mihael Hategan <[email protected]> 2012-08-09 14:03:12 --- (In reply to comment #12)
Ah, yes. Quick workaround: add the following line to ~/.globus/cog.properties (on both sites): java.security.gsi.signing.policy=false I'll try to add signing policies for the dummy CA. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #14 from David Kelly <[email protected]> 2012-08-09 14:08:51 --- That worked - it ran 10 small jobs and everything completed fine. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #15 from Mihael Hategan <[email protected]> 2012-08-11 11:04:46 --- I committed code to generate and forward signing policies. Things should now work with default setting (no disabling of signing policies in cog.properties). Please give it a shot. Might be a good idea to clean ~/.globus/coasters. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #16 from David Kelly <[email protected]> 2012-09-10 15:20:06 --- Hello, Just curious if there are any updates on this for ssh-cl? This would be very useful for a CMTS script that I'm working on. Thanks, David -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 Mihael Hategan <[email protected]> changed: What |Removed |Added ---------------------------------------------------------------------------- Status|REOPENED |RESOLVED Resolution| |FIXED --- Comment #17 from Mihael Hategan <[email protected]> 2012-09-20 20:03:02 --- SSH-CL now also has proxy forwarding and can use the automatic CA (cog trunk r3473). -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 David Kelly <[email protected]> changed: What |Removed |Added ---------------------------------------------------------------------------- Status|RESOLVED |REOPENED Resolution|FIXED | --- Comment #18 from David Kelly <[email protected]> 2012-09-21 01:40:46 --- Thanks for committing this! It seems to work well when using a single site. When I try to use multiple pools/sites together I run into an error. The full log is at: http://www.ci.uchicago.edu/~davidk/logs/rmsd-20120921-0129-zdez34v0.log. Swift trunk swift-r5942 (swift modified locally) cog-r3474 RunID: 20120921-0129-zdez34v0 Progress: time: Fri, 21 Sep 2012 01:29:55 -0500 Failed to lock CA dir java.io.IOException: Failed to delete /home/davidk/.globus/coasters/locking.entering.30217 at org.globus.cog.util.concurrent.FileLock.write(Unknown Source) at org.globus.cog.util.concurrent.FileLock.lock(Unknown Source) at org.globus.cog.abstraction.impl.execution.coaster.AutoCA.ensureCACertsExist(AutoCA.java:125) at org.globus.cog.abstraction.impl.execution.coaster.AutoCA.createProxy(AutoCA.java:116) at org.globus.cog.abstraction.impl.execution.coaster.ServiceManager.setupGSIProxy(ServiceManager.java:216) at org.globus.cog.abstraction.impl.execution.coaster.ServiceManager.startService(ServiceManager.java:179) at org.globus.cog.abstraction.impl.execution.coaster.ServiceManager.reserveService(ServiceManager.java:122) at org.globus.cog.abstraction.impl.execution.coaster.ServiceManager.reserveService(ServiceManager.java:136) at org.globus.cog.abstraction.impl.execution.coaster.JobSubmissionTaskHandler.getChannel(JobSubmissionTaskHandler.java:118) at org.globus.cog.abstraction.impl.execution.coaster.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:104) at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45) at org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:97) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303) at java.util.concurrent.FutureTask.run(FutureTask.java:138) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:662) Execution failed: Failed to delete /home/davidk/.globus/coasters/locking.number.30217 -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #19 from David Kelly <[email protected]> 2012-09-21 01:48:00 --- This seems to happen with both ssh and ssh-cl (probably the first time I've tested with a multisite configuration since the automatic CA updates) -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #20 from Mihael Hategan <[email protected]> 2012-09-21 02:45:56 --- I'm an idiot. The file lock was working with multiple concurrent jvms but not with multiple threads in the same jvm. Try now. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #21 from David Kelly <[email protected]> 2012-09-21 12:20:22 --- I can run multisite jobs like this now, but maybe 1 out of 5 times it fails with the unable to delete error. http://www.ci.uchicago.edu/~davidk/logs/rmsd-20120921-1210-08grfqx9.log -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 Michael Wilde <[email protected]> changed: What |Removed |Added ---------------------------------------------------------------------------- CC| |[email protected] --- Comment #22 from Michael Wilde <[email protected]> 2012-09-22 11:59:18 --- This is great progress on this enhancement! I think the remaining intermittent failure though is a showstopper for getting multi-site scripts working well for the CMTS-Voth lab, so can you move it near or to the top of your to-do list, Mihael? Thanks! Not sure if you need any logs for the failures from David. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 --- Comment #23 from Mihael Hategan <[email protected]> 2012-09-22 19:08:26 --- Third time is the charm! r3476. -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=684 David Kelly <[email protected]> changed: What |Removed |Added ---------------------------------------------------------------------------- Status|REOPENED |RESOLVED Resolution| |FIXED --- Comment #24 from David Kelly <[email protected]> 2012-09-24 16:18:20 --- I was able to do some multisite runs this morning and everything seems to be working great. Thank you! -- Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email ------- You are receiving this mail because: ------- You are watching all bug changes.
participants (1)
bugzilla-daemon@mcs.anl.gov
