#39: Seperate config values for domain password server (kerb) and auth server
#39: Seperate config values for domain password server (kerb) and auth server -----------------------------------+---------------------------------------- Reporter: cwalker | Owner: Type: defect | Status: new Priority: major | Milestone: CI Launch Component: Admin - Configuration | Version: Keywords: | -----------------------------------+---------------------------------------- In order to be able to authenticate against the ldap server, and set passwords, there needs to be separate variables for this in the domain config -- Ticket URL: <https://trac.mcs.anl.gov/projects/userbase2/ticket/39> userbase2 <https://sovereign.mcs.anl.gov/> Userbase2
#39: Seperate config values for domain password server (kerb) and auth server -----------------------------------+---------------------------------------- Reporter: cwalker | Owner: Type: defect | Status: in_QA Priority: major | Milestone: CI Launch Component: Admin - Configuration | Version: Keywords: | -----------------------------------+---------------------------------------- Changes (by cwalker): * status: new => in_QA Comment: This has been fixed in a previous commit. The ldap server is now the only backend mechanism for authentication, so there is no need to worry about these 2 configuration settings conflicting -- Ticket URL: <https://trac.mcs.anl.gov/projects/userbase2/ticket/39#comment:1> userbase2 <https://sovereign.mcs.anl.gov/> Userbase2
#39: Seperate config values for domain password server (kerb) and auth server ------------------------------------+--------------------------------------- Reporter: cwalker | Owner: Type: defect | Status: closed Priority: major | Milestone: CI Launch Component: Admin - Configuration | Version: Resolution: fixed | Keywords: ------------------------------------+--------------------------------------- Changes (by cwalker): * status: in_QA => closed * resolution: => fixed -- Ticket URL: <https://trac.mcs.anl.gov/projects/userbase2/ticket/39#comment:2> userbase2 <https://sovereign.mcs.anl.gov/> Userbase2
participants (1)
userbase2
