Author: janehu Date: 2008-04-18 14:20:39 -0500 (Fri, 18 Apr 2008) New Revision: 1771 Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp Log: make_Lump failed because it doesn't consider the shell with 6 faces a closed shell, debugging on it. Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-17 20:12:35 UTC (rev 1770) +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-18 19:20:39 UTC (rev 1771) @@ -1045,7 +1045,10 @@ for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More()&& stat; Ex.Next()) aShell = TopoDS::Shell(Ex.Current()); - if(aShell.Closed(CUBIT_TRUE)) + int num_edge = 0; + for (Ex.Init(aShell, TopAbs_EDGE); Ex.More()&& stat; Ex.Next()) + num_edge++; + if(aShell.Closed()) { BRepBuilderAPI_MakeSolid aMakeSolid(aShell); if (!aMakeSolid.IsDone()) @@ -1057,6 +1060,9 @@ TopoDS_Solid aSolid = aMakeSolid.Solid(); + int num_edge = 0; + for (Ex.Init(aSolid, TopAbs_EDGE); Ex.More()&& stat; Ex.Next()) + num_edge++; return OCCQueryEngine::instance()->populate_topology_bridge(aSolid, CUBIT_TRUE); } @@ -1571,18 +1577,19 @@ OCCSurface::update_OCC_entity(face, face, &fuser); } fuse = fuser.Shape(); + TopExp_Explorer Ex_edge; + TopoDS_Edge edge; + for (Ex_edge.Init(fuse,TopAbs_EDGE); Ex_edge.More(); Ex_edge.Next()) + edge = TopoDS::Edge(Ex_edge.Current()); first_face = &fuse; } TopExp_Explorer Ex; - int count_face = 0; int count_shell = 0; - for (Ex.Init(fuse, TopAbs_FACE, TopAbs_SHELL); Ex.More(); Ex.Next()) - count_face++; for (Ex.Init(fuse, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next()) count_shell++; - if (count_face != 1 && count_shell != 1) + if ( count_shell != 1) { PRINT_ERROR("Can't stitch all surfaces into one BodySM's. \n"); return CUBIT_FAILURE; @@ -1642,6 +1649,15 @@ } TopoDS_Solid* solid = CAST_TO(lumps.get(), OCCLump)->get_TopoDS_Solid(); + TopExp_Explorer Ex_edge; + TopoDS_Edge edge; + int num_edge = 0; + for (Ex_edge.Init(*solid,TopAbs_EDGE); Ex_edge.More(); Ex_edge.Next()) + { + edge = TopoDS::Edge(Ex_edge.Current()); + num_edge++; + } + BRepBuilderAPI_Copy api_copy(*solid); TopoDS_Shape newShape = api_copy.ModifiedShape(*solid); TopoDS_Shape* newShape_ptr = new TopoDS_Shape(newShape);
participants (1)
janehu@mcs.anl.gov
