Author: janehu Date: 2008-04-21 14:49:42 -0500 (Mon, 21 Apr 2008) New Revision: 1772 Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp cgm/trunk/geom/OCC/OCCSurface.cpp Log: Solved the stitched shell unclosed issue: we have to check the closed status, and set up the flag. some other make_Lump changes. Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-18 19:20:39 UTC (rev 1771) +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-21 19:49:42 UTC (rev 1772) @@ -1040,14 +1040,34 @@ TopoDS_Shape aShape; CubitStatus stat = stitch_surfs(body_list, aShape); - TopExp_Explorer Ex; + TopExp_Explorer Ex, Ex2; TopoDS_Shell aShell ; for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More()&& stat; Ex.Next()) aShell = TopoDS::Shell(Ex.Current()); - int num_edge = 0; + //check to make sure the aShell is closed. + int num_edges = 0; + int pairs = 0; for (Ex.Init(aShell, TopAbs_EDGE); Ex.More()&& stat; Ex.Next()) - num_edge++; + { + TopoDS_Edge edge1 = TopoDS::Edge(Ex.Current()); + num_edges++; + for (Ex2.Init(aShell, TopAbs_EDGE); Ex2.More()&& stat; Ex2.Next()) + { + TopoDS_Edge edge2 = TopoDS::Edge(Ex2.Current()); + if (!edge1.IsEqual(edge2)&& edge1.IsSame(edge2)) + { + pairs++; + break; + } + } + } + if (num_edges == pairs) + aShell.Closed(CUBIT_TRUE); + + else + PRINT_ERROR("Surfaces must make a water-tight shape to make a lump.\n"); + if(aShell.Closed()) { BRepBuilderAPI_MakeSolid aMakeSolid(aShell); @@ -1111,6 +1131,18 @@ if (lump_list.size() == 0) return (BodySM*) NULL; + //make sure the lumps in lump_list don't attached to any Bodies. + for (int i = 0; i < lump_list.size(); i++) + { + Lump* lump = lump_list.get_and_step(); + BodySM* body = CAST_TO(lump, OCCLump)->get_body(); + if (body) + { + if (lump_list.size()>1) + PRINT_ERROR("the lump_list should be free to bodysm's to make a new bodysm.\n"); + return body; + } + } //Create a compsolid shape, save all BodySM's correponding to lump_list //for deletion. DLIList<BodySM*> bodysm_list; Modified: cgm/trunk/geom/OCC/OCCSurface.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-04-18 19:20:39 UTC (rev 1771) +++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-04-21 19:49:42 UTC (rev 1772) @@ -784,13 +784,13 @@ if (shapes.Extent() > 0) shape = shapes.First(); else - need_update = CUBIT_FALSE; + return CUBIT_SUCCESS; } TopoDS_Face surface; surface = TopoDS::Face(shape); - if (aBRepTrsf && need_update) + if (aBRepTrsf) { OCCQueryEngine::instance()->update_OCC_map(*myTopoDSFace, surface); @@ -805,13 +805,9 @@ set_TopoDS_Face(surface); } - else if(op && need_update) + else if(op) update_OCC_entity(*myTopoDSFace, surface, op); - else - update_OCC_entity(*myTopoDSFace, *myTopoDSFace, op); //underling curves may - //need update - return CUBIT_SUCCESS; } @@ -859,6 +855,9 @@ else continue; + if(wire.Orientation() == TopAbs_REVERSED) + shape.Orientation( + shape.Orientation()==TopAbs_FORWARD? TopAbs_REVERSED:TopAbs_FORWARD); OCCQueryEngine::instance()->update_OCC_map(edge, shape); //update vertex
participants (1)
janehu@mcs.anl.gov
