r1927 - in cgm/trunk/geom: . ACIS_SRC OCC facet
Author: janehu Date: 2008-06-25 13:34:20 -0500 (Wed, 25 Jun 2008) New Revision: 1927 Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp cgm/trunk/geom/GeometryModifyEngine.hpp cgm/trunk/geom/GeometryModifyTool.cpp cgm/trunk/geom/GeometryModifyTool.hpp cgm/trunk/geom/OCC/OCCModifyEngine.cpp cgm/trunk/geom/OCC/OCCModifyEngine.hpp cgm/trunk/geom/facet/FacetModifyEngine.cpp cgm/trunk/geom/facet/FacetModifyEngine.hpp Log: change back the thicken interface for making thick solid, and added a hollow method of making thick solid. Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp =================================================================== --- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp 2008-06-25 17:34:56 UTC (rev 1926) +++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp 2008-06-25 18:34:20 UTC (rev 1927) @@ -5922,6 +5922,16 @@ return CUBIT_SUCCESS; } + +CubitStatus AcisModifyEngine::hollow( DLIList<BodySM*>& bodies, + DLIList<Surface*>& surfs_to_remove, + DLIList<BodySM*>& new_body_list, + double depth) const +{ + PRINT_ERROR( "This function is not available in ACIS engine.\n"); + return CUBIT_FAILURE; +} + //------------------------------------------------------------------------- // Purpose : To thicken sheet bodies // @@ -5941,7 +5951,6 @@ return CUBIT_FAILURE; #else CubitStatus AcisModifyEngine::thicken( DLIList<BodySM*>& bodies, - DLIList<Surface*>& surfs_to_remove, DLIList<BodySM*>& new_body_list, double depth, bool both) const Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp =================================================================== --- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp 2008-06-25 17:34:56 UTC (rev 1926) +++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp 2008-06-25 18:34:20 UTC (rev 1927) @@ -382,16 +382,23 @@ virtual CubitStatus thicken( DLIList<BodySM*>& bodies, - DLIList<Surface*>& surfs_to_remove, DLIList<BodySM*>& new_bodies, double depth, bool both = false) const; //- Thicken a sheet body into a solid - //- surfs_to_remove is a dummy input //R CubitStatus //R-the result of the thicken operation: Success or Failure + virtual CubitStatus hollow( DLIList<BodySM*>& bodies, + DLIList<Surface*>& surfs_to_remove, + DLIList<BodySM*>& new_bodies, + double depth) const; + + //- Hollow a solid body into a thick body + //R CubitStatus + //R-the result of the hollow operation: Failure + virtual CubitStatus flip_normals( DLIList<Surface*>& face_list ) const; //R CubitStatus //R-the result of the flip_normals operation: Success or Failure Modified: cgm/trunk/geom/GeometryModifyEngine.hpp =================================================================== --- cgm/trunk/geom/GeometryModifyEngine.hpp 2008-06-25 17:34:56 UTC (rev 1926) +++ cgm/trunk/geom/GeometryModifyEngine.hpp 2008-06-25 18:34:20 UTC (rev 1927) @@ -412,7 +412,6 @@ virtual CubitStatus thicken( DLIList<BodySM*>& bodies, - DLIList<Surface*>& surfs_to_remove, DLIList<BodySM*>& new_body_list, double depth, bool both = false) const = 0; @@ -420,9 +419,6 @@ //R-the result of the thicken operation: Success or Failure //I bodies //I-DLIList<Body*>: a list of Body pointers that will be thicken - //I- or for OCC: a list of solid BodySM's that will be hollowed into a - //I- thick solid. - //I- surfs_to_remove: the faces to be removed from the original solid (OCC). //O- new Bodies build by thicken operation on the list of Body pointers. //- This function performs a thicken of sheet bodies and returns //- the result through the output argument in_out_body. If the thicken @@ -431,6 +427,23 @@ //- argument is assigned a NULL value and the function returns //- CUBIT_FAILURE. + virtual CubitStatus hollow(DLIList<BodySM*>& bodies, + DLIList<Surface*>& surfs_to_remove, + DLIList<BodySM*>& new_bodies, + double depth) const = 0; + //R CubitStatus + //R-the result of the hollow operation: Success or Failure + //I body + //I- for OCC: a list of solid BodySM's that will be hollowed into a list of + //I- thick solids. + //I- surfs_to_remove: the faces to be removed from the original solid (OCC). + //O- new Bodies build by hollow operation on the body pointers. + //- This function performs a hollow of solid body and returns + //- the result through the output argument in_out_body. If the hollow + //- operation went through OK, the function returns CUBIT_SUCCESS. If, + //- for some reason, the hollow operation did not go well, the output + //- argument is assigned a NULL value and the function returns + //- CUBIT_FAILURE. virtual CubitStatus flip_normals( DLIList<Surface*>& face_list ) const = 0; //R CubitStatus Modified: cgm/trunk/geom/GeometryModifyTool.cpp =================================================================== --- cgm/trunk/geom/GeometryModifyTool.cpp 2008-06-25 17:34:56 UTC (rev 1926) +++ cgm/trunk/geom/GeometryModifyTool.cpp 2008-06-25 18:34:20 UTC (rev 1927) @@ -4155,12 +4155,10 @@ return CUBIT_SUCCESS; } -CubitStatus GeometryModifyTool:: - make_thick_solid( DLIList<Body*>& bodies, - DLIList<RefFace*>& faces_to_remove, - DLIList<Body*>& new_bodies, - double depth, - bool both ) +CubitStatus GeometryModifyTool::thicken( DLIList<Body*>& bodies, + DLIList<Body*>& new_bodies, + double depth, + bool both ) { if (bodies.size() <= 0) { @@ -4188,24 +4186,11 @@ return CUBIT_FAILURE; } - DLIList<Surface*> surfs_to_remove; - if(faces_to_remove.size() > 0) - { - GeometryModifyEngine* gme2 = common_modify_engine(faces_to_remove, - surfs_to_remove); - if(gme2 != gme) - { - PRINT_ERROR("Performing THICKEN with volumes containing geometry\n" - " from different modeling engines is not allowed.\n" - "Delete uncommon geometry on these volumes before operation.\n\n"); - return CUBIT_FAILURE; - } - } DLIList<BodySM*> new_sms(count); DLIList<BodySM*> body_sms(count); CAST_LIST(bridge_list, body_sms, BodySM); - CubitStatus result = gme->thicken( body_sms, surfs_to_remove, new_sms, depth, both); + CubitStatus result = gme->thicken( body_sms, new_sms, depth, both); // check for resued entities, they have been moved and we need to notify observers DLIList<RefEntity*> entities_to_update; Modified: cgm/trunk/geom/GeometryModifyTool.hpp =================================================================== --- cgm/trunk/geom/GeometryModifyTool.hpp 2008-06-25 17:34:56 UTC (rev 1926) +++ cgm/trunk/geom/GeometryModifyTool.hpp 2008-06-25 18:34:20 UTC (rev 1927) @@ -225,8 +225,7 @@ bool keep_old = false, bool nonreg = false ); - CubitStatus make_thick_solid( DLIList<Body*>& bodies, - DLIList<RefFace*>& faces_to_remove, + CubitStatus thicken( DLIList<Body*>& bodies, DLIList<Body*>& new_bodies, double depth, bool both = false ); Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-06-25 17:34:56 UTC (rev 1926) +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-06-25 18:34:20 UTC (rev 1927) @@ -3580,23 +3580,29 @@ return CUBIT_SUCCESS; } +CubitStatus OCCModifyEngine::thicken( DLIList<BodySM*>& bodies, + DLIList<BodySM*>& new_bodies, + double depth, + CubitBoolean both) const +{ + PRINT_ERROR("Option not supported for OCC based geometry.\n"); + return CUBIT_FAILURE; +} //=============================================================================== -// Function : thicken +// Function : hollow // Member Type: PUBLIC // Description: Hollow existing solid body by remove one or several surfaces // Can only take one body at a time. -// No both (side) option. // depth > 0, thick body going outside bodies // depth < 0, thick body going inside bodies // Author : Jane Hu // Date : 06/08 //=============================================================================== -CubitStatus OCCModifyEngine::thicken(DLIList<BodySM*>& bodies, +CubitStatus OCCModifyEngine::hollow( DLIList<BodySM*>& bodies, DLIList<Surface*>& surfs_to_remove, DLIList<BodySM*>& new_bodies, - double depth, - bool /*both*/) const + double depth) const { if(bodies.size() != 1 || surfs_to_remove.size() < 1) { Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp =================================================================== --- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-06-25 17:34:56 UTC (rev 1926) +++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-06-25 18:34:20 UTC (rev 1927) @@ -201,11 +201,15 @@ bool keep_old = CUBIT_FALSE) const; virtual CubitStatus thicken(DLIList<BodySM*>& bodies, - DLIList<Surface*>& surfs_to_remove, DLIList<BodySM*>& new_bodies, double depth, bool both = CUBIT_FALSE) const ; + virtual CubitStatus hollow( DLIList<BodySM*>& bodies, + DLIList<Surface*>& surfs_to_remove, + DLIList<BodySM*>& new_bodies, + double depth) const ; + virtual CubitStatus flip_normals( DLIList<Surface*>& face_list ) const; virtual CubitStatus sweep_translational( Modified: cgm/trunk/geom/facet/FacetModifyEngine.cpp =================================================================== --- cgm/trunk/geom/facet/FacetModifyEngine.cpp 2008-06-25 17:34:56 UTC (rev 1926) +++ cgm/trunk/geom/facet/FacetModifyEngine.cpp 2008-06-25 18:34:20 UTC (rev 1927) @@ -1737,6 +1737,15 @@ } +CubitStatus FacetModifyEngine::hollow( DLIList<BodySM*>& /*bodies*/, + DLIList<Surface*> & /*surfs*/, + DLIList<BodySM*>& /*new_bodies*/, + double /*depth*/) const +{ + PRINT_ERROR("Option not supported for mesh based geometry.\n"); + return CUBIT_FAILURE; +} + //=============================================================================== // Function : thicken // Member Type: PUBLIC @@ -1745,7 +1754,6 @@ // Date : 10/02 //=============================================================================== CubitStatus FacetModifyEngine::thicken(DLIList<BodySM*>& /*bodies*/, - DLIList<Surface*> & /*surfs*/, DLIList<BodySM*>& /*new_bodies*/, double /*depth*/, bool /*both*/) const Modified: cgm/trunk/geom/facet/FacetModifyEngine.hpp =================================================================== --- cgm/trunk/geom/facet/FacetModifyEngine.hpp 2008-06-25 17:34:56 UTC (rev 1926) +++ cgm/trunk/geom/facet/FacetModifyEngine.hpp 2008-06-25 18:34:20 UTC (rev 1927) @@ -216,11 +216,15 @@ bool keep_old = CUBIT_FALSE) const; virtual CubitStatus thicken(DLIList<BodySM*>& bodies, - DLIList<Surface*>& surfs_to_remove, DLIList<BodySM*>& new_bodies, double depth, bool both = CUBIT_FALSE) const ; + virtual CubitStatus hollow(DLIList<BodySM*>& bodies, + DLIList<Surface*>& surfs_to_remove, + DLIList<BodySM*>& new_bodies, + double depth) const ; + virtual CubitStatus flip_normals( DLIList<Surface*>& face_list ) const; virtual CubitStatus sweep_translational(
participants (1)
janehu@mcs.anl.gov
