r1926 - in cgm/trunk: geom geom/Cholla util
Author: janehu Date: 2008-06-25 12:34:56 -0500 (Wed, 25 Jun 2008) New Revision: 1926 Modified: cgm/trunk/geom/Cholla/CubitFacet.hpp cgm/trunk/geom/Cholla/CubitPoint.hpp cgm/trunk/geom/Curve.hpp cgm/trunk/geom/DagType.hpp cgm/trunk/geom/IntermediateGeomEngine.hpp cgm/trunk/geom/RefEntity.hpp cgm/trunk/geom/TBOwner.hpp cgm/trunk/util/CubitFileIOWrapper.hpp cgm/trunk/util/CubitString.hpp cgm/trunk/util/CubitUtil.hpp cgm/trunk/util/CubitVector.hpp cgm/trunk/util/DLIList.cpp cgm/trunk/util/DLIList.hpp cgm/trunk/util/KDDTree.cpp cgm/trunk/util/KDDTree.hpp cgm/trunk/util/PriorityQueue.cpp cgm/trunk/util/RTreeNode.cpp cgm/trunk/util/RTreeNode.hpp Log: Check in for Serge Gosselin to remove compiling warnings we see in CGM. Modified: cgm/trunk/geom/Cholla/CubitFacet.hpp =================================================================== --- cgm/trunk/geom/Cholla/CubitFacet.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/geom/Cholla/CubitFacet.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -134,7 +134,7 @@ virtual int id() = 0; virtual void set_id( int ii ) = 0; int tool_id(){return toolID;} - void set_tool_id(int tool_id){toolID = tool_id;} + void set_tool_id(int my_tool_id){toolID = my_tool_id;} virtual CubitFacetEdge *edge( int index ) = 0; virtual void edge( CubitFacetEdge *the_edge, int index ) = 0; @@ -261,7 +261,7 @@ //- Returns all adjacent facets to this edge (not including //- this facet) - CubitFacet *adjacent( int &index, int *tool_data ) + CubitFacet *adjacent( int &index, int *my_tool_data ) //- Returns all adjacent facets to this edge index(not including //- this facet) { @@ -270,7 +270,7 @@ CubitPoint *p1, *p2; get_edge_pts( index, p1, p2 ); - return shared_facet_on_surf( p1, p2, *tool_data ); + return shared_facet_on_surf( p1, p2, *my_tool_data ); } CubitPoint* next_node(CubitPoint *current_point) Modified: cgm/trunk/geom/Cholla/CubitPoint.hpp =================================================================== --- cgm/trunk/geom/Cholla/CubitPoint.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/geom/Cholla/CubitPoint.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -85,7 +85,7 @@ virtual double z() = 0; virtual void set( const CubitVector &pos ) = 0; - virtual void marked(int marked) {markedFlag = marked;}; + virtual void marked(int is_marked) {markedFlag = is_marked;}; virtual int marked() {return markedFlag;}; virtual CubitVector coordinates() const = 0; @@ -111,8 +111,9 @@ virtual double u() { return uVal; }; virtual double v() { return vVal; }; virtual double size() {return sizeVal; }; - virtual void set_uv( double u, double v ) { uVal = u; vVal = v; }; - virtual void set_uvs(double u, double v, double s) {uVal = u; vVal = v; sizeVal = s; } + virtual void set_uv( double u_new, double v_new ) { uVal = u_new; vVal = v_new; }; + virtual void set_uvs(double u_new, double v_new, double s_new) + {uVal = u_new; vVal = v_new; sizeVal = s_new; } //- get and set the u-v coordinates (careful with internal boundaries - see TDFacetBoundarPoint) virtual CubitStatus get_uv( CubitFacet *facet, double &u, double &v ); virtual CubitStatus get_uvs( CubitFacet *facet, double &u, double &v, double &s); Modified: cgm/trunk/geom/Curve.hpp =================================================================== --- cgm/trunk/geom/Curve.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/geom/Curve.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -109,7 +109,7 @@ virtual CubitStatus mid_point(const CubitVector &point1, const CubitVector &point2, - CubitVector& mid_point ); + CubitVector& my_mid_point ); //R CubitStatus //I CubitVector, CubitVector //I- points between which the mid_point is needed @@ -118,7 +118,7 @@ //- This function returns the mid point between two points on this //-edge, by parameter - virtual CubitStatus mid_point(CubitVector& mid_point); + virtual CubitStatus mid_point(CubitVector& my_mid_point); //R CubitStatus //O CubitVector //O- mid point on this edge @@ -397,11 +397,11 @@ } inline -CubitStatus Curve::mid_point(CubitVector &mid_point) +CubitStatus Curve::mid_point(CubitVector &my_mid_point) { double param1 = 0.5 * (start_param() + end_param()); - return position_from_u(param1, mid_point); + return position_from_u(param1, my_mid_point); } inline @@ -418,12 +418,12 @@ inline CubitStatus Curve::mid_point(const CubitVector &point1, const CubitVector &point2, - CubitVector& mid_point ) + CubitVector& my_mid_point ) { double param1 = u_from_position(point1); double param2 = u_from_position(point2); param1 = 0.5 * (param1 + param2); - return position_from_u(param1, mid_point); + return position_from_u(param1, my_mid_point); } //R CubitStatus Modified: cgm/trunk/geom/DagType.hpp =================================================================== --- cgm/trunk/geom/DagType.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/geom/DagType.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -27,8 +27,8 @@ // Dimension may be outside the range [0,3], but // if so is_valid() will return false. (i.e. it is // possible to construct invalid DagType objects.) - inline DagType( int dimension, FunctionalType func ) - : intType( 3 * dimension + func ) + inline DagType( int my_dimension, FunctionalType func ) + : intType( 3 * my_dimension + func ) { } @@ -44,7 +44,7 @@ // Return values are one of GroupingEntity_TYPE, // SenseEntity_TYPE, or BasicTopologyEntity_TYPE. inline FunctionalType functional_type() const - { return (FunctionalType)(intType % 3); } + { return static_cast<FunctionalType> (intType % 3); } // Is this a valid DagType? @@ -55,8 +55,8 @@ // move above a Body or below a RefVertex in the DAG. inline bool is_valid() const { - const unsigned body_type = 11; - return (unsigned)intType <= body_type; + const unsigned my_body_type = 11; + return static_cast<unsigned>(intType) <= my_body_type; } // get parent of this type Modified: cgm/trunk/geom/IntermediateGeomEngine.hpp =================================================================== --- cgm/trunk/geom/IntermediateGeomEngine.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/geom/IntermediateGeomEngine.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -12,6 +12,9 @@ { public: + + virtual ~IntermediateGeomEngine() {} + virtual bool is_composite(TBOwner *bridge_owner) = 0; virtual bool is_partition(TBOwner *bridge_owner) = 0; Modified: cgm/trunk/geom/RefEntity.hpp =================================================================== --- cgm/trunk/geom/RefEntity.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/geom/RefEntity.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -304,7 +304,7 @@ inline int RefEntity::marked() -{return (int) markedFlag;} +{return static_cast<int>(markedFlag);} inline void RefEntity::list_mark(int value) Modified: cgm/trunk/geom/TBOwner.hpp =================================================================== --- cgm/trunk/geom/TBOwner.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/geom/TBOwner.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -22,6 +22,8 @@ { public: + + virtual ~TBOwner() {} virtual CubitStatus remove_bridge( TopologyBridge* bridge ) = 0; @@ -33,7 +35,7 @@ bool reversed ) = 0; virtual CubitBoolean contains_bridge( TopologyBridge* bridge ) const - { return (CubitBoolean)(bridge->owner() == this); } + { return static_cast<CubitBoolean>(bridge->owner() == this); } virtual void notify_reversed( TopologyBridge* ) = 0; Modified: cgm/trunk/util/CubitFileIOWrapper.hpp =================================================================== --- cgm/trunk/util/CubitFileIOWrapper.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/CubitFileIOWrapper.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -77,7 +77,7 @@ unsigned char* lpCurFromByte; unsigned char lachrBuffer[sizeof(T)]; - unsigned char* lpCurAtom = (unsigned char*)xpT; + unsigned char* lpCurAtom = reinterpret_cast<unsigned char*>(xpT); int lintAtom = xintCount; while(lintAtom) { lintAtom--; Modified: cgm/trunk/util/CubitString.hpp =================================================================== --- cgm/trunk/util/CubitString.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/CubitString.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -27,7 +27,7 @@ class CubitStringRep; -const size_t MAX_POS = (size_t) -1; // "SIZE_T_MAX" +const size_t MAX_POS = static_cast<size_t>(-1); // "SIZE_T_MAX" class CUBIT_UTIL_EXPORT CubitString { Modified: cgm/trunk/util/CubitUtil.hpp =================================================================== --- cgm/trunk/util/CubitUtil.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/CubitUtil.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -130,7 +130,7 @@ sense == CUBIT_REVERSED ); if ( sense == CUBIT_UNKNOWN ) return CUBIT_UNKNOWN; else { - CubitSense opp_sense = (CubitSense) (1 - sense); + CubitSense opp_sense = static_cast<CubitSense>(1 - sense); return opp_sense; } } Modified: cgm/trunk/util/CubitVector.hpp =================================================================== --- cgm/trunk/util/CubitVector.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/CubitVector.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -44,7 +44,7 @@ CubitVector(const CubitVectorStruct& from); //- Heading: Set and Inquire Functions - void set(const double x, const double y, const double z); + void set(const double x_coord, const double y_coord, const double z_coord); //- Change vector components to {x}, {y}, and {z} void set( const double xyz[3] ); @@ -66,22 +66,22 @@ double& y(); double& z(); - void get_xyz( double &x, double &y, double &z ) const; //- Get x, y, z components + void get_xyz( double &x_coord, double &y_coord, double &z_coord ) const; //- Get x, y, z components void get_xyz( double xyz[3] ) const; //- Get xyz tuple double &r(); //- Return r component of vector, if (r,theta) format double &theta(); //- Return theta component of vector, if (r,theta) format - void x( const double x ); //- Set x component of vector + void x( const double x_coord ); //- Set x component of vector - void y( const double y ); //- Set y component of vector + void y( const double y_coord ); //- Set y component of vector - void z( const double z ); //- Set z component of vector + void z( const double z_coord ); //- Set z component of vector - void r( const double x ); //- Set r component of vector, if (r,theta) format + void r( const double radius ); //- Set r component of vector, if (r,theta) format - void theta( const double y ); //- Set theta component of vector, if (r,theta) format + void theta( const double angle ); //- Set theta component of vector, if (r,theta) format void xy_to_rtheta(); //- convert from cartesian to polar coordinates, just 2d for now @@ -303,26 +303,26 @@ xyz[1] = yVal; xyz[2] = zVal; } -inline void CubitVector::get_xyz(double &x, double &y, double &z) const +inline void CubitVector::get_xyz(double &x_coord, double &y_coord, double &z_coord) const { - x = xVal; - y = yVal; - z = zVal; + x_coord = xVal; + y_coord = yVal; + z_coord = zVal; } inline double &CubitVector::r() { return xVal; } inline double &CubitVector::theta() { return yVal; } -inline void CubitVector::x( const double x ) -{ xVal = x; } -inline void CubitVector::y( const double y ) -{ yVal = y; } -inline void CubitVector::z( const double z ) -{ zVal = z; } -inline void CubitVector::r( const double x ) -{ xVal = x; } -inline void CubitVector::theta( const double y ) -{ yVal = y; } +inline void CubitVector::x( const double x_coord ) +{ xVal = x_coord; } +inline void CubitVector::y( const double y_coord ) +{ yVal = y_coord; } +inline void CubitVector::z( const double z_coord ) +{ zVal = z_coord; } +inline void CubitVector::r( const double radius ) +{ xVal = radius; } +inline void CubitVector::theta( const double angle ) +{ yVal = angle; } inline CubitVector& CubitVector::operator+=(const CubitVector &v) { xVal += v.xVal; @@ -386,13 +386,13 @@ y( -temp ); } -inline void CubitVector::set(const double x, - const double y, - const double z) +inline void CubitVector::set(const double x_coord, + const double y_coord, + const double z_coord) { - xVal = x; - yVal = y; - zVal = z; + xVal = x_coord; + yVal = y_coord; + zVal = z_coord; } inline void CubitVector::set(const double xyz[3]) Modified: cgm/trunk/util/DLIList.cpp =================================================================== --- cgm/trunk/util/DLIList.cpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/DLIList.cpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -27,16 +27,16 @@ //- will be grown by {increment} each time it is filled. Memory for the //- list is not allocated until the first element is inserted using //- {insertLink}. -template <class X> MY_INLINE DLIList<X>::DLIList (int size) +template <class X> MY_INLINE DLIList<X>::DLIList (int list_size) { index = 0; itemCount = 0; listLength = 0; listArray = NULL; - if (size) + if (list_size) { - listArray = new X [size]; - listLength = size; + listArray = new X [list_size]; + listLength = list_size; } } @@ -76,7 +76,7 @@ { // Make a new array int new_size = - (int) ((double)listLength * by_what_factor) + static_cast<int>( static_cast<double>(listLength) * by_what_factor ) + by_how_much; X* temp_list = new X [new_size]; @@ -173,7 +173,7 @@ X* end1 = iter1 + itemCount; // end of this array X* iter2 = intersect_list.listArray; // iterstor for other array X* end2 = iter2 + intersect_list.itemCount;// end of other array - X* insert = iter1 - 1; // location of last insert + X* last_insert = iter1 - 1; // location of last insert for ( ; iter1 < end1; ++iter1 ) { @@ -183,13 +183,13 @@ if (iter2 == end2) break; - if ((*iter2 == *iter1) && // items are the same and ... - (insert < listArray || // is the first item or ... - *iter1 != *insert)) // is not the same as the previous item - *++insert = *iter1; + if ((*iter2 == *iter1) && // items are the same and ... + (last_insert < listArray || // is the first item or ... + *iter1 != *last_insert)) // is not the same as the previous item + *++last_insert = *iter1; } - itemCount = insert - listArray + 1; + itemCount = last_insert - listArray + 1; reset(); } @@ -218,7 +218,7 @@ template <class X> MY_INLINE void DLIList<X>::intersect ( void* merge_list ) { - intersect( *(DLIList<X>*)merge_list ); + intersect( *static_cast< DLIList<X>* >(merge_list) ); } @@ -230,7 +230,7 @@ if ( !itemCount ) { PRINT_WARNING("Attempted link removal from empty DLIList\n"); - return (X)0; + return X(0); } // save the current value @@ -267,7 +267,7 @@ if ( !itemCount ) { PRINT_WARNING("Attempted link removal from empty DLIList\n"); - return (X)0; + return X(0); } // save the current value @@ -334,7 +334,7 @@ if ( !itemCount ) { PRINT_WARNING("Attempted step_and_get from empty DLIList\n"); - return (X)0; + return X(0); } if (++index == itemCount) @@ -400,7 +400,7 @@ template <class X> MY_INLINE DLIList<X>& DLIList<X>:: operator+=(void* from) { - DLIList<X>* cast_from = (DLIList<X>*)from; + DLIList<X>* cast_from = static_cast< DLIList<X>* >(from); // Don't do anything if the list being appended is empty. if (cast_from->itemCount == 0) @@ -594,14 +594,14 @@ { // report amount of memory allocated - int size = listLength * sizeof(X); + int my_size = listLength * sizeof(X); if (verbose_boolean) { - PRINT_INFO(" DLIList: %d bytes\n",size); + PRINT_INFO(" DLIList: %d bytes\n", my_size); } - return size; + return my_size; } template <class X> MY_INLINE void DLIList<X>::copy_to(X *other_array) Modified: cgm/trunk/util/DLIList.hpp =================================================================== --- cgm/trunk/util/DLIList.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/DLIList.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -37,7 +37,7 @@ public: friend class DLIListIterator<X>; - explicit DLIList (int size = 0); + explicit DLIList (int list_size = 0); //- Constructor: Create a list with initial size 'size'. Memory for the //- list is not allocated until the first element is added to the list. @@ -109,7 +109,7 @@ int operator==(const DLIList<X>& from); int operator!=(const DLIList<X>& from); - X & operator[](int index) const; + X & operator[](int my_index) const; void merge_unique(const DLIList<X>& merge_list, bool merge_list_unique = false); //- Merges the contents of the list, merge_list, with those of "this" @@ -264,10 +264,10 @@ } template <class X> inline -X & DLIList<X>::operator[](int index) const +X & DLIList<X>::operator[](int my_index) const { - assert( index >= 0 && index < itemCount ); - return listArray[index]; + assert( my_index >= 0 && my_index < itemCount ); + return listArray[my_index]; } template <class X> inline void DLIList<X>::step() @@ -379,7 +379,7 @@ if ( !itemCount ) { PRINT_WARNING("Attempted get of empty DLIList\n"); - return (X)0; + return X(0); } else { @@ -393,7 +393,7 @@ if ( !itemCount ) { PRINT_WARNING("Attempted get_and_step from empty DLIList\n"); - return (X)0; + return X(0); } else #endif @@ -410,7 +410,7 @@ if ( !itemCount ) { PRINT_WARNING("Attempted get_and_back from empty DLIList\n"); - return (X)0; + return X(0); } X temp = listArray[index--]; if (index < 0) @@ -423,7 +423,7 @@ if (!itemCount) { PRINT_WARNING("Attempted next of empty DLIList\n"); - return (X)0; + return X(0); } else if (index == itemCount-1) return listArray[0]; @@ -436,7 +436,7 @@ if ( !itemCount ) { PRINT_WARNING("Attempted next of empty DLIList\n"); - return (X)0; + return X(0); } else { @@ -484,7 +484,7 @@ template <class X> inline X DLIList<X>::change_to (X new_value) { - X temp = (X)0; + X temp = X(0); if ( !itemCount ) { PRINT_WARNING("DLIList: Attempted update of empty list\n"); @@ -516,7 +516,7 @@ // If the item was found and removed it is returned, else 0 is returned. template <class X> inline X DLIList<X>::remove (X item) { - X temp = (X)0; + X temp = X(0); if (move_to(item)) temp = remove(); return temp; Modified: cgm/trunk/util/KDDTree.cpp =================================================================== --- cgm/trunk/util/KDDTree.cpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/KDDTree.cpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -60,7 +60,7 @@ if (myRandomOn) { //// seed the random number generator - srand( (unsigned)time( NULL ) ); + srand( static_cast<unsigned>(time(NULL)) ); } } @@ -375,17 +375,17 @@ //- Find the depth of the tree template <class Z> void KDDTree<Z>::recursive_find_max_height - (KDDTreeNode<Z> *root, int depth, int *maxdepth) + (KDDTreeNode<Z> *the_root, int depth, int *maxdepth) { - if (root) + if (the_root) { depth++; if (depth > *maxdepth) { *maxdepth = depth; } - recursive_find_max_height (root->left, depth, maxdepth); - recursive_find_max_height (root->right, depth, maxdepth); + recursive_find_max_height (the_root->left, depth, maxdepth); + recursive_find_max_height (the_root->right, depth, maxdepth); } } @@ -495,7 +495,7 @@ myMarkedNodes++; if (myDeletionTolerance != 0) { - if ( (((double)myMarkedNodes / myNodeList.size()) > myDeletionTolerance) && + if ( (( static_cast<double>(myMarkedNodes) / myNodeList.size()) > myDeletionTolerance) && (myMarkedNodes > 1) ) { Modified: cgm/trunk/util/KDDTree.hpp =================================================================== --- cgm/trunk/util/KDDTree.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/KDDTree.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -49,7 +49,7 @@ double min_dist_sq (CubitVector &q, CubitBox &b_box); //- Find the depth of the tree recursively - void recursive_find_max_height (KDDTreeNode<Z> *root, int depth, int *maxdepth); + void recursive_find_max_height (KDDTreeNode<Z> *the_root, int depth, int *maxdepth); //- Balance the tree recursively KDDTreeNode<Z> *recursive_balance (DIMENSION dim, int left, int right, Modified: cgm/trunk/util/PriorityQueue.cpp =================================================================== --- cgm/trunk/util/PriorityQueue.cpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/PriorityQueue.cpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -35,7 +35,7 @@ { PRINT_ERROR("Empty priority queue had top request.\n"); assert(!empty()); - return (Object)0; + return static_cast<Object>(0); } return theItems[1]; } Modified: cgm/trunk/util/RTreeNode.cpp =================================================================== --- cgm/trunk/util/RTreeNode.cpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/RTreeNode.cpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -35,7 +35,7 @@ myChildrenNodes = new RTreeNode<Y>* [maxChildren]; int ii; for ( ii = 0; ii < maxChildren; ii++ ) - myChildrenNodes[ii] = (RTreeNode<Y>*) NULL; + myChildrenNodes[ii] = static_cast< RTreeNode<Y>* >(NULL); if ( data == NULL ) { PRINT_ERROR("Building RTree with null data is not allowed!\n"); @@ -70,17 +70,17 @@ distIsBox = 1; myDist = CUBIT_DBL_MAX; } -template <class Y> MY_INLINE RTreeNode<Y>::RTreeNode (CubitBox &bounding_box, +template <class Y> MY_INLINE RTreeNode<Y>::RTreeNode (CubitBox &bound_box, int max_children, int min_children) { maxChildren = max_children; minChildren = min_children; - myBoundingBox = new CubitBox(bounding_box); + myBoundingBox = new CubitBox(bound_box); myChildrenNodes = new RTreeNode<Y>* [maxChildren]; int ii; for ( ii = 0; ii < maxChildren; ii++ ) - myChildrenNodes[ii] = (RTreeNode<Y>*) NULL; + myChildrenNodes[ii] = static_cast< RTreeNode<Y>* >(NULL); myData = NULL; myLevel = UNSET_RNODE; myParent = NULL; @@ -199,7 +199,7 @@ } //do error checking... if ( child_index == -1 || child_index >= maxChildren ) - return (RTreeNode<Y>*)NULL; + return static_cast< RTreeNode<Y>* >(NULL); RTreeNode<Y> *f = n->myChildrenNodes[child_index]; //Now continue on... curr_node = choose_leaf(f,e); @@ -420,12 +420,12 @@ myBoundingBox = new CubitBox(new_box); } template <class Y> MY_INLINE void RTreeNode<Y>::add_child(RTreeNode<Y> *child_node, - CubitBoolean recalc_b_box) + CubitBoolean recalc_bound_box) { assert(nextChildIndex < maxChildren && child_node != NULL ); myChildrenNodes[nextChildIndex] = child_node; //update the bounding box. by uniting with child node... - if ( recalc_b_box ) + if ( recalc_bound_box ) { CubitBox *old_box = myBoundingBox; myBoundingBox = new CubitBox( *old_box |= child_node->bounding_box()); @@ -464,8 +464,8 @@ RTreeNode<Y> *e_1, *e_2; CubitBox e_box_1, e_box_2, j; double d, max_d = -CUBIT_DBL_MAX; - seed_1 = (RTreeNode<Y>*)NULL; - seed_2 = (RTreeNode<Y>*)NULL; + seed_1 = static_cast< RTreeNode<Y>* >(NULL); + seed_2 = static_cast< RTreeNode<Y>* >(NULL); for(ii = 0; ii < input_list_size; ii++ ) { @@ -509,7 +509,7 @@ int ii, next_index = 0; double d1, d2, max_diff = -CUBIT_DBL_MAX; add_to_group_1 = CUBIT_TRUE; - RTreeNode<Y> *max_diff_node = (RTreeNode<Y>*)NULL; + RTreeNode<Y> *max_diff_node = static_cast< RTreeNode<Y>* >(NULL); RTreeNode<Y> *curr_node; CubitBox group_1_box = group_1->bounding_box(); CubitBox group_2_box = group_2->bounding_box(); @@ -659,7 +659,7 @@ if ( root->num_children() == 1 ) { new_root = root->get_child(0); - new_root->set_parent((RTreeNode<Y>*)NULL); + new_root->set_parent(static_cast< RTreeNode<Y>* >(NULL)); delete_root = CUBIT_TRUE; } return CUBIT_TRUE; Modified: cgm/trunk/util/RTreeNode.hpp =================================================================== --- cgm/trunk/util/RTreeNode.hpp 2008-06-25 14:31:10 UTC (rev 1925) +++ cgm/trunk/util/RTreeNode.hpp 2008-06-25 17:34:56 UTC (rev 1926) @@ -110,7 +110,7 @@ public: RTreeNode(Y data, double tol, int max_children, int min_children ); - RTreeNode(CubitBox &bounding_box, int max_children, int min_children); + RTreeNode(CubitBox &bound_box, int max_children, int min_children); ~RTreeNode(); //- Constructor/Destructor @@ -140,7 +140,7 @@ {return myData;} //- Determine if the RTreeNode is a leaf node. - void add_child(RTreeNode<Y>* child_node, CubitBoolean recalc_b_box); + void add_child(RTreeNode<Y>* child_node, CubitBoolean recalc_bound_box); //- Add the child to the myChildrenNodes' list. Adds //- it to the next availabel spot. Won't add if overflow will //- occur. @@ -156,7 +156,7 @@ //- Returns the number of children in the myChildrenNode's array. RTreeNode<Y>* get_child(int i) - {return ((i < nextChildIndex) ? myChildrenNodes[i] : (RTreeNode<Y>*)NULL) ;} + {return ( (i < nextChildIndex) ? myChildrenNodes[i] : static_cast< RTreeNode<Y>* >(NULL) );} void flush(CubitBox &new_box);
participants (1)
janehu@mcs.anl.gov
