r5759 - in cgm/trunk: cgm_apps/examples/facetdriver geom/testing test
Author: iulian Date: 2012-09-27 18:28:29 -0500 (Thu, 27 Sep 2012) New Revision: 5759 Modified: cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am cgm/trunk/geom/testing/Makefile.am cgm/trunk/test/Makefile.am Log: ubuntu 12 (gcc 463) is more explicit about linking. This is the so called golden rule, which allows for faster optimizations, because the libraries to be linked with, have to be explicitly defined. Modified: cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am =================================================================== --- cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am 2012-09-27 20:29:19 UTC (rev 5758) +++ cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am 2012-09-27 23:28:29 UTC (rev 5759) @@ -11,4 +11,4 @@ -I$(top_srcdir)/geom/Cholla \ -I$(top_srcdir)/geom/facet -LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) +LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) $(CGM_EXT_LIBS) Modified: cgm/trunk/geom/testing/Makefile.am =================================================================== --- cgm/trunk/geom/testing/Makefile.am 2012-09-27 20:29:19 UTC (rev 5758) +++ cgm/trunk/geom/testing/Makefile.am 2012-09-27 23:28:29 UTC (rev 5759) @@ -14,7 +14,7 @@ endif AM_CPPFLAGS += -I$(top_srcdir)/util -I$(top_srcdir)/geom -I. -LDADD = libcgm_test.la ../../libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) +LDADD = libcgm_test.la ../../libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) $(CGM_EXT_LIBS) check_PROGRAMS = $(BASE_TESTS:.engine=) check_SCRIPT = $(TESTS) Modified: cgm/trunk/test/Makefile.am =================================================================== --- cgm/trunk/test/Makefile.am 2012-09-27 20:29:19 UTC (rev 5758) +++ cgm/trunk/test/Makefile.am 2012-09-27 23:28:29 UTC (rev 5759) @@ -27,7 +27,7 @@ check_PROGRAMS = $(TESTS) -LDADD = ../libcgm.la +LDADD = ../libcgm.la $(CGM_EXT_LIBS) AM_LDFLAGS += $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) webcut_SOURCES = webcut.cpp
participants (1)
iulian@mcs.anl.gov
