OK, done Best regards, Iulian ----- Original Message ----- | It could, but would make inserting new tests just a bit harder. The | right way to do it is to tweak the dependencies to | account for all the other external libs; Iulian has a fix which does | that which he'll commit shortly. | - tim | On 09/27/2012 05:29 PM, Paul Wilson wrote: | > | > On 09/27/2012 04:31 PM, Tim Tautges wrote: | >> Anyway, Paul, cgm.make is for applications built outside the cgm | >> autotools setup, while make check is for things | >> inside that setup. | > But if the cgm.make methodology works for built apps, couldn't a | > similar paradigm - maybe just a different file - be | > invoked for the make check. | > | > Paul | > | -- | ================================================================ | "You will keep in perfect peace him whose mind is | steadfast, because he trusts in you." Isaiah 26:3 | Tim Tautges Argonne National Laboratory | ([email protected]) (telecommuting from UW-Madison) | phone (gvoice): (608) 354-1459 1500 Engineering Dr. | fax: (608) 263-4499 Madison, WI 53706
participants (1)
Iulian Grindeanu
