Author: janehu Date: 2011-04-06 11:34:36 -0500 (Wed, 06 Apr 2011) New Revision: 4717 Removed: cgm/branches/merge-cubit12/geom/OCC/OCCHistory.lo cgm/branches/merge-cubit12/geom/OCC/OCCHistory.o Modified: cgm/branches/merge-cubit12/geom/OCC/OCCShapeAttributeSet.cpp Log: Changes the way CGM attributes are written and read for OCC engine. Passed testcases under cubit 12 trunk test directory. Deleted: cgm/branches/merge-cubit12/geom/OCC/OCCHistory.lo =================================================================== --- cgm/branches/merge-cubit12/geom/OCC/OCCHistory.lo 2011-04-06 16:32:00 UTC (rev 4716) +++ cgm/branches/merge-cubit12/geom/OCC/OCCHistory.lo 2011-04-06 16:34:36 UTC (rev 4717) @@ -1,12 +0,0 @@ -# OCCHistory.lo - a libtool object file -# Generated by ltmain.sh (GNU libtool) 2.2.6b Debian-2.2.6b-2ubuntu1 -# -# Please DO NOT delete this file! -# It is necessary for linking the library. - -# Name of the PIC object. -pic_object=none - -# Name of the non-PIC object -non_pic_object='OCCHistory.o' - Deleted: cgm/branches/merge-cubit12/geom/OCC/OCCHistory.o =================================================================== (Binary files differ) Modified: cgm/branches/merge-cubit12/geom/OCC/OCCShapeAttributeSet.cpp =================================================================== --- cgm/branches/merge-cubit12/geom/OCC/OCCShapeAttributeSet.cpp 2011-04-06 16:32:00 UTC (rev 4716) +++ cgm/branches/merge-cubit12/geom/OCC/OCCShapeAttributeSet.cpp 2011-04-06 16:34:36 UTC (rev 4717) @@ -420,62 +420,69 @@ DLIList<CubitString*> strings; DLIList<double> doubles; DLIList<int> ints; + int c_num, length; + do { + IS >> c_num; //length of name string IS >> buffer; - std::string::size_type i = buffer.find_first_of("*"); - type = buffer.substr( 0, i ); + if(buffer.length() >= c_num) + type = buffer.substr( 0, c_num ); //attribute name string + else + { + c_num -= buffer.length(); + type.append( buffer ); + do{ + IS >> buffer; + type.push_back(' '); + type.append(buffer.substr( 0, c_num )); + c_num -= (buffer.length() + 1); + }while (c_num > 0); + }
participants (1)
jiangtao_ma@yahoo.com
