Author: janehu Date: 2011-04-07 10:35:11 -0500 (Thu, 07 Apr 2011) New Revision: 4722 Modified: cgm/branches/merge-cubit12/test/r_w.cpp cgm/branches/merge-cubit12/test/unite1.occ cgm/branches/merge-cubit12/test/unite4.occ Log: Added some comments on the testcase; Changed for testing on string with space case. Modified: cgm/branches/merge-cubit12/test/r_w.cpp =================================================================== --- cgm/branches/merge-cubit12/test/r_w.cpp 2011-04-06 19:49:20 UTC (rev 4721) +++ cgm/branches/merge-cubit12/test/r_w.cpp 2011-04-07 15:35:11 UTC (rev 4722) @@ -333,6 +333,9 @@ num_ents_exported, cubit_version); assert(num_ents_exported == 1); + //name attributes in unite2.occ is + //CGM_ATTRIB 11 ENTITY_NAME 2 8 volume B 8 volume_B 0 0 + //so it changed to volume_B, and code needs use the second name attrib. bodies.clean_out(); gti->bodies(bodies); //delete all entities @@ -363,6 +366,7 @@ rsl = CubitCompat_export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); assert(num_ents_exported == 1); + //CGM_ATTRIB 11 ENTITY_NAME 2 8 volume A 8 volume_A 0 0 in unite3.occ bodies.clean_out(); gti->bodies(bodies); @@ -391,6 +395,8 @@ num_ents_exported, cubit_version); assert(num_ents_exported == 1); + //CGM_ATTRIB 11 ENTITY_NAME 1 7 volumeA 0 0 in unite5.occ + bodies.clean_out(); gti->bodies(bodies); //delete all entities @@ -421,6 +427,8 @@ num_ents_exported, cubit_version); assert(num_ents_exported == 1); + //CGM_ATTRIB 11 ENTITY_NAME 1 7 volumeB 0 0 in unite6.occ + bodies.clean_out(); gti->bodies(bodies); //delete all entities Modified: cgm/branches/merge-cubit12/test/unite1.occ =================================================================== --- cgm/branches/merge-cubit12/test/unite1.occ 2011-04-06 19:49:20 UTC (rev 4721) +++ cgm/branches/merge-cubit12/test/unite1.occ 2011-04-07 15:35:11 UTC (rev 4722) @@ -594,7 +594,7 @@ * * * -CGM_ATTRIB 11 ENTITY_NAME 1 7 volumeB 0 0 +CGM_ATTRIB 11 ENTITY_NAME 1 8 volume B 0 0
participants (1)
jiangtao_ma@yahoo.com
