Author: kraftche Date: 2007-07-17 16:08:29 -0500 (Tue, 17 Jul 2007) New Revision: 1207 Removed: cgm/trunk/init/Makefile Log: should not have checked this in Deleted: cgm/trunk/init/Makefile =================================================================== --- cgm/trunk/init/Makefile 2007-07-17 21:06:46 UTC (rev 1206) +++ cgm/trunk/init/Makefile 2007-07-17 21:08:29 UTC (rev 1207) @@ -1,543 +0,0 @@ -# Makefile.in generated by automake 1.9.6 from Makefile.am. -# init/Makefile. Generated from Makefile.in by configure. - -# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, -# 2003, 2004, 2005 Free Software Foundation, Inc. -# This Makefile.in is free software; the Free Software Foundation -# gives unlimited permission to copy and/or distribute it, -# with or without modifications, as long as this notice is preserved. - -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY, to the extent permitted by law; without -# even the implied warranty of MERCHANTABILITY or FITNESS FOR A -# PARTICULAR PURPOSE. - - - - -srcdir = . -top_srcdir = .. - -pkgdatadir = $(datadir)/CGMA -pkglibdir = $(libdir)/CGMA -pkgincludedir = $(includedir)/CGMA -top_builddir = .. -am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd -INSTALL = /usr/bin/install -c -install_sh_DATA = $(install_sh) -c -m 644 -install_sh_PROGRAM = $(install_sh) -c -install_sh_SCRIPT = $(install_sh) -c -INSTALL_HEADER = $(INSTALL_DATA) -transform = $(program_transform_name) -NORMAL_INSTALL = : -PRE_INSTALL = : -POST_INSTALL = : -NORMAL_UNINSTALL = : -PRE_UNINSTALL = : -POST_UNINSTALL = : -build_triplet = x86_64-unknown-linux-gnu -host_triplet = x86_64-unknown-linux-gnu -target_triplet = x86_64-unknown-linux-gnu -subdir = init -DIST_COMMON = $(libcgma_init_la_include_HEADERS) $(srcdir)/Makefile.am \ - $(srcdir)/Makefile.in -ACLOCAL_M4 = $(top_srcdir)/aclocal.m4 -am__aclocal_m4_deps = $(top_srcdir)/configure.in -am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \ - $(ACLOCAL_M4) -mkinstalldirs = $(install_sh) -d -CONFIG_HEADER = $(top_builddir)/config.h \ - $(top_builddir)/itaps/iBase_FCDefs.h -CONFIG_CLEAN_FILES = -am__vpath_adj_setup = srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`; -am__vpath_adj = case $$p in \ - $(srcdir)/*) f=`echo "$$p" | sed "s|^$$srcdirstrip/||"`;; \ - *) f=$$p;; \ - esac; -am__strip_dir = `echo $$p | sed -e 's|^.*/||'`; -am__installdirs = "$(DESTDIR)$(libdir)" \ - "$(DESTDIR)$(libcgma_init_la_includedir)" -libLTLIBRARIES_INSTALL = $(INSTALL) -LTLIBRARIES = $(lib_LTLIBRARIES) -libcgma_init_la_LIBADD = -am_libcgma_init_la_OBJECTS = InitCGMA.lo -libcgma_init_la_OBJECTS = $(am_libcgma_init_la_OBJECTS) -DEFAULT_INCLUDES = -I. -I$(srcdir) -I$(top_builddir) -I$(top_builddir)/itaps -depcomp = $(SHELL) $(top_srcdir)/depcomp -am__depfiles_maybe = depfiles -CXXCOMPILE = $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) \ - $(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CXXFLAGS) $(CXXFLAGS) -LTCXXCOMPILE = $(LIBTOOL) --tag=CXX --mode=compile $(CXX) $(DEFS) \ - $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) \ - $(AM_CXXFLAGS) $(CXXFLAGS) -CXXLD = $(CXX) -CXXLINK = $(LIBTOOL) --tag=CXX --mode=link $(CXXLD) $(AM_CXXFLAGS) \ - $(CXXFLAGS) $(AM_LDFLAGS) $(LDFLAGS) -o $@ -SOURCES = $(libcgma_init_la_SOURCES) -DIST_SOURCES = $(libcgma_init_la_SOURCES) -libcgma_init_la_includeHEADERS_INSTALL = $(INSTALL_HEADER) -HEADERS = $(libcgma_init_la_include_HEADERS) -ETAGS = etags -CTAGS = ctags -DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST) -ACIS_DEFS = -ACIS_DIR = no -ACIS_HEALER = -ACIS_IGES_TRANSLATOR = -ACIS_INCLUDES = -ACIS_LIBS = -ACIS_LIB_DIR = . -ACIS_PLATFORM = -ACIS_STEP_TRANSLATOR = -ACIS_VERSION = 0 -ACLOCAL = ${SHELL} /home/jason/CGM/missing --run aclocal-1.9 -AMDEP_FALSE = # -AMDEP_TRUE = -AMTAR = ${SHELL} /home/jason/CGM/missing --run tar -AR = ar -AUTOCONF = ${SHELL} /home/jason/CGM/missing --run autoconf -AUTOHEADER = ${SHELL} /home/jason/CGM/missing --run autoheader -AUTOMAKE = ${SHELL} /home/jason/CGM/missing --run automake-1.9 -AWK = gawk -BABEL_DIR = -BUILD_CGM_FALSE = -BUILD_CGM_TRUE = # -CANT_USE_STD = -CANT_USE_STD_IO = -CC = cc -CCDEPMODE = depmode=gcc3 -CFLAGS = -g -CGM_ACIS_LIBS = -CGM_LIBS_FILES = $(CUBIT_FILE) -CGM_LIBS_LINK = $(CUBIT_LDFLAGS) $(CUBIT_LIBS) -CGM_LIBS_LTFLAGS = $(CUBIT_LTFLAGS) -CGM_PARALLEL_INCLUDE = -CGM_PARALLEL_LIB = -CGM_PARALLEL_LIB_FILE = -CPP = cc -E -CPPFLAGS = -CUBIT_CGM = -DCUBIT_CGM -CUBIT_FILE = /opt/cubit-10.1-amd64//bin/libcubiti19.so -CUBIT_LDFLAGS = -L/opt/cubit-10.1-amd64//bin -L/opt/cubit-10.1-amd64//bin/lib -L/opt/cubit-10.1-amd64//libs -CUBIT_LIBS = -lcubiti19 -CUBIT_LTFLAGS = -R/opt/cubit-10.1-amd64//bin -R/opt/cubit-10.1-amd64//bin/lib -R/opt/cubit-10.1-amd64//libs -CXX = c++ -CXXCPP = c++ -E -CXXDEPMODE = depmode=gcc3 -CXXFLAGS = -Wall -pipe -g -CYGPATH_W = echo - -# Override default defines with the ones we want from the configure script -DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN) $(HAVE_ACIS_DEF) $(CUBIT_CGM) -DEPDIR = .deps -ECHO = echo -ECHO_C = -ECHO_N = -n -ECHO_T = -EGREP = /bin/grep -E -EXEEXT = -F77 = g77 -FC = gfortran -FCFLAGS = -g -O2 -FCLIBS = -L/usr/lib/gcc/x86_64-linux-gnu/4.1.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.1.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -lgfortranbegin -lgfortran -lm -FFLAGS = -g -O2 -GREP = /bin/grep -HAVE_ACIS_DEF = -DHAVE_ACIS -INCLUDE_TEMPLATE_DEFS_FALSE = # -INCLUDE_TEMPLATE_DEFS_TRUE = -INSTALL_DATA = ${INSTALL} -m 644 -INSTALL_PROGRAM = ${INSTALL} -INSTALL_SCRIPT = ${INSTALL} -INSTALL_STRIP_PROGRAM = ${SHELL} $(install_sh) -c -s -LDFLAGS = -LIBOBJS = -LIBS = -lm -LIBTOOL = $(SHELL) $(top_builddir)/libtool -LITTLE_ENDIAN = -DLITTLE_ENDIAN=BYTE_ORDER -LN_S = ln -s -LTLIBOBJS = -MAKEINFO = ${SHELL} /home/jason/CGM/missing --run makeinfo -OBJEXT = o -PACKAGE = CGMA -PACKAGE_BUGREPORT = -PACKAGE_NAME = CGMA -PACKAGE_STRING = CGMA 10.2.2 -PACKAGE_TARNAME = cgma -PACKAGE_VERSION = 10.2.2 -PATH_SEPARATOR = : -RANLIB = ranlib -SET_MAKE = -SHELL = /bin/sh -STRIP = strip -TEMPLATE_DEFS_INCLUDED = -DTEMPLATE_DEFS_INCLUDED -USE_BABEL = no -USE_BABEL_FALSE = -USE_BABEL_TRUE = # -USE_MPI_FALSE = -USE_MPI_TRUE = # -VERSION = 10.2.2 -ac_ct_CC = cc -ac_ct_CXX = c++ -ac_ct_F77 = g77 -ac_ct_FC = gfortran -am__fastdepCC_FALSE = # -am__fastdepCC_TRUE = -am__fastdepCXX_FALSE = # -am__fastdepCXX_TRUE = -am__include = include -am__leading_dot = . -am__quote = -am__tar = ${AMTAR} chof - "$$tardir" -am__untar = ${AMTAR} xf - -bindir = ${exec_prefix}/bin -build = x86_64-unknown-linux-gnu -build_ACIS_FALSE = -build_ACIS_TRUE = # -build_alias = -build_cpu = x86_64 -build_os = linux-gnu -build_parallel_FALSE = -build_parallel_TRUE = # -build_vendor = unknown -datadir = ${datarootdir} -datarootdir = ${prefix}/share -docdir = ${datarootdir}/doc/${PACKAGE_TARNAME} -dvidir = ${docdir} -exec_prefix = ${prefix} -host = x86_64-unknown-linux-gnu -host_alias = -host_cpu = x86_64 -host_os = linux-gnu -host_vendor = unknown -htmldir = ${docdir} -includedir = ${prefix}/include -infodir = ${datarootdir}/info -install_sh = /home/jason/CGM/install-sh -libdir = ${exec_prefix}/lib -libexecdir = ${exec_prefix}/libexec -localedir = ${datarootdir}/locale -localstatedir = ${prefix}/var -mandir = ${datarootdir}/man -mkdir_p = mkdir -p -- -oldincludedir = /usr/include -pdfdir = ${docdir} -prefix = /usr/local -program_transform_name = s,x,x, -psdir = ${docdir} -sbindir = ${exec_prefix}/sbin -sharedstatedir = ${prefix}/com -sysconfdir = ${prefix}/etc -target = x86_64-unknown-linux-gnu -target_alias = -target_cpu = x86_64 -target_os = linux-gnu -target_vendor = unknown - -# Don't require GNU-standard files (Changelog, README, etc.) -AUTOMAKE_OPTIONS = foreign -INCLUDES = -I$(top_srcdir)/geom \ - -I$(top_srcdir)/util \ - -I$(top_srcdir)/geom/ACIS \ - -I$(top_srcdir)/geom/virtual \ - -I$(top_srcdir)/geom/facet \ - -I$(top_srcdir)/geom/cholla \ - -I$(srcdir) - -lib_LTLIBRARIES = libcgma_init.la -libcgma_init_la_includedir = $(includedir) -libcgma_init_la_SOURCES = InitCGMA.cpp -libcgma_init_la_include_HEADERS = InitCGMA.hpp -all: all-am - -.SUFFIXES: -.SUFFIXES: .cpp .lo .o .obj -$(srcdir)/Makefile.in: $(srcdir)/Makefile.am $(am__configure_deps) - @for dep in $?; do \ - case '$(am__configure_deps)' in \ - *$$dep*) \ - cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh \ - && exit 0; \ - exit 1;; \ - esac; \ - done; \ - echo ' cd $(top_srcdir) && $(AUTOMAKE) --foreign init/Makefile'; \ - cd $(top_srcdir) && \ - $(AUTOMAKE) --foreign init/Makefile -.PRECIOUS: Makefile -Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status - @case '$?' in \ - *config.status*) \ - cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh;; \ - *) \ - echo ' cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)'; \ - cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe);; \ - esac; - -$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES) - cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh - -$(top_srcdir)/configure: $(am__configure_deps) - cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh -$(ACLOCAL_M4): $(am__aclocal_m4_deps) - cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh -install-libLTLIBRARIES: $(lib_LTLIBRARIES) - @$(NORMAL_INSTALL) - test -z "$(libdir)" || $(mkdir_p) "$(DESTDIR)$(libdir)" - @list='$(lib_LTLIBRARIES)'; for p in $$list; do \ - if test -f $$p; then \ - f=$(am__strip_dir) \ - echo " $(LIBTOOL) --mode=install $(libLTLIBRARIES_INSTALL) $(INSTALL_STRIP_FLAG) '$$p' '$(DESTDIR)$(libdir)/$$f'"; \ - $(LIBTOOL) --mode=install $(libLTLIBRARIES_INSTALL) $(INSTALL_STRIP_FLAG) "$$p" "$(DESTDIR)$(libdir)/$$f"; \ - else :; fi; \ - done - -uninstall-libLTLIBRARIES: - @$(NORMAL_UNINSTALL) - @set -x; list='$(lib_LTLIBRARIES)'; for p in $$list; do \ - p=$(am__strip_dir) \ - echo " $(LIBTOOL) --mode=uninstall rm -f '$(DESTDIR)$(libdir)/$$p'"; \ - $(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(libdir)/$$p"; \ - done - -clean-libLTLIBRARIES: - -test -z "$(lib_LTLIBRARIES)" || rm -f $(lib_LTLIBRARIES) - @list='$(lib_LTLIBRARIES)'; for p in $$list; do \ - dir="`echo $$p | sed -e 's|/[^/]*$$||'`"; \ - test "$$dir" != "$$p" || dir=.; \ - echo "rm -f \"$${dir}/so_locations\""; \ - rm -f "$${dir}/so_locations"; \ - done -libcgma_init.la: $(libcgma_init_la_OBJECTS) $(libcgma_init_la_DEPENDENCIES) - $(CXXLINK) -rpath $(libdir) $(libcgma_init_la_LDFLAGS) $(libcgma_init_la_OBJECTS) $(libcgma_init_la_LIBADD) $(LIBS) - -mostlyclean-compile: - -rm -f *.$(OBJEXT) - -distclean-compile: - -rm -f *.tab.c - -include ./$(DEPDIR)/InitCGMA.Plo - -.cpp.o: - if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \ - then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Po"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi -# source='$<' object='$@' libtool=no \ -# DEPDIR=$(DEPDIR) $(CXXDEPMODE) $(depcomp) \ -# $(CXXCOMPILE) -c -o $@ $< - -.cpp.obj: - if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ `$(CYGPATH_W) '$<'`; \ - then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Po"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi -# source='$<' object='$@' libtool=no \ -# DEPDIR=$(DEPDIR) $(CXXDEPMODE) $(depcomp) \ -# $(CXXCOMPILE) -c -o $@ `$(CYGPATH_W) '$<'` - -.cpp.lo: - if $(LTCXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \ - then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Plo"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi -# source='$<' object='$@' libtool=yes \ -# DEPDIR=$(DEPDIR) $(CXXDEPMODE) $(depcomp) \ -# $(LTCXXCOMPILE) -c -o $@ $< - -mostlyclean-libtool: - -rm -f *.lo - -clean-libtool: - -rm -rf .libs _libs - -distclean-libtool: - -rm -f libtool -uninstall-info-am: -install-libcgma_init_la_includeHEADERS: $(libcgma_init_la_include_HEADERS) - @$(NORMAL_INSTALL) - test -z "$(libcgma_init_la_includedir)" || $(mkdir_p) "$(DESTDIR)$(libcgma_init_la_includedir)" - @list='$(libcgma_init_la_include_HEADERS)'; for p in $$list; do \ - if test -f "$$p"; then d=; else d="$(srcdir)/"; fi; \ - f=$(am__strip_dir) \ - echo " $(libcgma_init_la_includeHEADERS_INSTALL) '$$d$$p' '$(DESTDIR)$(libcgma_init_la_includedir)/$$f'"; \ - $(libcgma_init_la_includeHEADERS_INSTALL) "$$d$$p" "$(DESTDIR)$(libcgma_init_la_includedir)/$$f"; \ - done - -uninstall-libcgma_init_la_includeHEADERS: - @$(NORMAL_UNINSTALL) - @list='$(libcgma_init_la_include_HEADERS)'; for p in $$list; do \ - f=$(am__strip_dir) \ - echo " rm -f '$(DESTDIR)$(libcgma_init_la_includedir)/$$f'"; \ - rm -f "$(DESTDIR)$(libcgma_init_la_includedir)/$$f"; \ - done - -ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES) - list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \ - unique=`for i in $$list; do \ - if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \ - done | \ - $(AWK) ' { files[$$0] = 1; } \ - END { for (i in files) print i; }'`; \ - mkid -fID $$unique -tags: TAGS - -TAGS: $(HEADERS) $(SOURCES) $(TAGS_DEPENDENCIES) \ - $(TAGS_FILES) $(LISP) - tags=; \ - here=`pwd`; \ - list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \ - unique=`for i in $$list; do \ - if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \ - done | \ - $(AWK) ' { files[$$0] = 1; } \ - END { for (i in files) print i; }'`; \ - if test -z "$(ETAGS_ARGS)$$tags$$unique"; then :; else \ - test -n "$$unique" || unique=$$empty_fix; \ - $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \ - $$tags $$unique; \ - fi -ctags: CTAGS -CTAGS: $(HEADERS) $(SOURCES) $(TAGS_DEPENDENCIES) \ - $(TAGS_FILES) $(LISP) - tags=; \ - here=`pwd`; \ - list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \ - unique=`for i in $$list; do \ - if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \ - done | \ - $(AWK) ' { files[$$0] = 1; } \ - END { for (i in files) print i; }'`; \ - test -z "$(CTAGS_ARGS)$$tags$$unique" \ - || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \ - $$tags $$unique - -GTAGS: - here=`$(am__cd) $(top_builddir) && pwd` \ - && cd $(top_srcdir) \ - && gtags -i $(GTAGS_ARGS) $$here - -distclean-tags: - -rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags - -distdir: $(DISTFILES) - @srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`; \ - topsrcdirstrip=`echo "$(top_srcdir)" | sed 's|.|.|g'`; \ - list='$(DISTFILES)'; for file in $$list; do \ - case $$file in \ - $(srcdir)/*) file=`echo "$$file" | sed "s|^$$srcdirstrip/||"`;; \ - $(top_srcdir)/*) file=`echo "$$file" | sed "s|^$$topsrcdirstrip/|$(top_builddir)/|"`;; \ - esac; \ - if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \ - dir=`echo "$$file" | sed -e 's,/[^/]*$$,,'`; \ - if test "$$dir" != "$$file" && test "$$dir" != "."; then \ - dir="/$$dir"; \ - $(mkdir_p) "$(distdir)$$dir"; \ - else \ - dir=''; \ - fi; \ - if test -d $$d/$$file; then \ - if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \ - cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \ - fi; \ - cp -pR $$d/$$file $(distdir)$$dir || exit 1; \ - else \ - test -f $(distdir)/$$file \ - || cp -p $$d/$$file $(distdir)/$$file \ - || exit 1; \ - fi; \ - done -check-am: all-am -check: check-am -all-am: Makefile $(LTLIBRARIES) $(HEADERS) -installdirs: - for dir in "$(DESTDIR)$(libdir)" "$(DESTDIR)$(libcgma_init_la_includedir)"; do \ - test -z "$$dir" || $(mkdir_p) "$$dir"; \ - done -install: install-am -install-exec: install-exec-am -install-data: install-data-am -uninstall: uninstall-am - -install-am: all-am - @$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am - -installcheck: installcheck-am -install-strip: - $(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \ - install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \ - `test -z '$(STRIP)' || \ - echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install -mostlyclean-generic: - -clean-generic: - -distclean-generic: - -test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES) - -maintainer-clean-generic: - @echo "This command is intended for maintainers to use" - @echo "it deletes files that may require special tools to rebuild." -clean: clean-am - -clean-am: clean-generic clean-libLTLIBRARIES clean-libtool \ - mostlyclean-am - -distclean: distclean-am - -rm -rf ./$(DEPDIR) - -rm -f Makefile -distclean-am: clean-am distclean-compile distclean-generic \ - distclean-libtool distclean-tags - -dvi: dvi-am - -dvi-am: - -html: html-am - -info: info-am - -info-am: - -install-data-am: install-libcgma_init_la_includeHEADERS - -install-exec-am: install-libLTLIBRARIES - -install-info: install-info-am - -install-man: - -installcheck-am: - -maintainer-clean: maintainer-clean-am - -rm -rf ./$(DEPDIR) - -rm -f Makefile -maintainer-clean-am: distclean-am maintainer-clean-generic - -mostlyclean: mostlyclean-am - -mostlyclean-am: mostlyclean-compile mostlyclean-generic \ - mostlyclean-libtool - -pdf: pdf-am - -pdf-am: - -ps: ps-am - -ps-am: - -uninstall-am: uninstall-info-am uninstall-libLTLIBRARIES \ - uninstall-libcgma_init_la_includeHEADERS - -.PHONY: CTAGS GTAGS all all-am check check-am clean clean-generic \ - clean-libLTLIBRARIES clean-libtool ctags distclean \ - distclean-compile distclean-generic distclean-libtool \ - distclean-tags distdir dvi dvi-am html html-am info info-am \ - install install-am install-data install-data-am install-exec \ - install-exec-am install-info install-info-am \ - install-libLTLIBRARIES install-libcgma_init_la_includeHEADERS \ - install-man install-strip installcheck installcheck-am \ - installdirs maintainer-clean maintainer-clean-generic \ - mostlyclean mostlyclean-compile mostlyclean-generic \ - mostlyclean-libtool pdf pdf-am ps ps-am tags uninstall \ - uninstall-am uninstall-info-am uninstall-libLTLIBRARIES \ - uninstall-libcgma_init_la_includeHEADERS - -# Tell versions [3.59,3.63) of GNU make to not export all variables. -# Otherwise a system limit (for SysV at least) may be exceeded. -.NOEXPORT:
participants (1)
kraftche@mcs.anl.gov
