Author: kraftche Date: 2007-07-17 16:06:46 -0500 (Tue, 17 Jul 2007) New Revision: 1206 Added: cgm/trunk/init/ cgm/trunk/init/.libs/ cgm/trunk/init/InitCGMA.cpp cgm/trunk/init/InitCGMA.hpp cgm/trunk/init/Makefile cgm/trunk/init/Makefile.am Removed: cgm/trunk/itaps/CGMA_ACIS.cc cgm/trunk/itaps/CGMA_ACIS.h Modified: cgm/trunk/Makefile.am cgm/trunk/cgm.make.in cgm/trunk/configure.in cgm/trunk/itaps/Makefile.am cgm/trunk/itaps/iGeom_CGMA.cc Log: Add standard mechanism for initializing ACIS and other optional engines - build as separate lib for use with either CGM or CUBIT Change iGeom to use new mechanism for initializing ACIS Modified: cgm/trunk/Makefile.am =================================================================== --- cgm/trunk/Makefile.am 2007-07-17 17:55:11 UTC (rev 1205) +++ cgm/trunk/Makefile.am 2007-07-17 21:06:46 UTC (rev 1206) @@ -1,5 +1,5 @@ AUTOMAKE_OPTIONS = foreign -SUBDIRS = util geom itaps +SUBDIRS = util geom init itaps if build_ACIS ACIS_EXAMPLE_TEST=cd cgm_apps/examples/driverc++; make check-TESTS Modified: cgm/trunk/cgm.make.in =================================================================== --- cgm/trunk/cgm.make.in 2007-07-17 17:55:11 UTC (rev 1205) +++ cgm/trunk/cgm.make.in 2007-07-17 21:06:46 UTC (rev 1206) @@ -41,14 +41,33 @@ CGM_CFLAGS = @CFLAGS@ CGM_LDFLAGS = @LDFLAGS@ -CGM_INCLUDES = -I$(CGM_DIR)/util -I$(CGM_DIR)/geom -I$(CGM_DIR)/geom/ACIS $(CGM_PARALLEL_INCLUDE) -I$(CGM_INCLUDEDIR) ${ACIS_INCLUDES} +CGM_INCLUDES = -I$(CGM_DIR)/util -I$(CGM_DIR)/init -I$(CGM_DIR)/geom -I$(CGM_DIR)/geom/ACIS $(CGM_PARALLEL_INCLUDE) -I$(CGM_INCLUDEDIR) ${ACIS_INCLUDES} CGM_LIBS_LINK_INTERNAL = ${LDFLAGS} \ - -L$(CGM_DIR)/geom/virtual -L$(CGM_DIR)/geom/facetbool -L$(CGM_DIR)/geom/facet \ - -L$(CGM_DIR)/geom/Cholla -L$(CGM_DIR)/geom/ACIS -L$(CGM_DIR)/geom -L$(CGM_DIR)/util \ + -L$(CGM_DIR)/geom/virtual/.libs \ + -L$(CGM_DIR)/geom/facetbool/.libs \ + -L$(CGM_DIR)/geom/facet/.libs \ + -L$(CGM_DIR)/geom/Cholla/.libs \ + -L$(CGM_DIR)/geom/ACIS/.libs \ + -L$(CGM_DIR)/geom/.libs + -L$(CGM_DIR)/util/.libs \ + -L$(CGM_DIR)/geom/virtual \ + -L$(CGM_DIR)/geom/facetbool \ + -L$(CGM_DIR)/geom/facet \ + -L$(CGM_DIR)/geom/Cholla \ + -L$(CGM_DIR)/geom/ACIS \ + -L$(CGM_DIR)/geom + -L$(CGM_DIR)/util \ -L${ACIS_LIB_DIR} \ -L$(CGM_LIBDIR) \ - ${ACIS_LIBS} -lcubit_virtual -lcubit_facet -lcubit_facetbool -lcholla ${ACIS_LIBS} -lcubit_geom -lcubit_util \ + ${ACIS_LIBS} \ + -lcubit_virtual \ + -lcubit_facet \ + -lcubit_facetbool \ + -lcholla \ + ${ACIS_LIBS} \ + -lcubit_geom \ + -lcubit_util \ ${CGM_PARALLEL_LIB} CGM_LIBS_FILES_INTERNAL = \ @@ -65,6 +84,6 @@ CUBIT_LIBS = @CUBIT_LIBS@ CUBIT_FILE = @CUBIT_FILE@ -CGM_LIBS_LINK = @CGM_LIBS_LINK@ -CGM_LIBS_FILES = @CGM_LIBS_FILES@ +CGM_LIBS_LINK = @CGM_LIBS_LINK@ -L$(CGM_DIR)/init -L$(CGM_DIR)/init/.libs -lcubit_init +CGM_LIBS_FILES = @CGM_LIBS_FILES@ $(CGM_LIBDIR)/libcubit_init.a CGM_LIBS_LTFLAGS = @CGM_LIBS_LTFLAGS@ Modified: cgm/trunk/configure.in =================================================================== --- cgm/trunk/configure.in 2007-07-17 17:55:11 UTC (rev 1205) +++ cgm/trunk/configure.in 2007-07-17 21:06:46 UTC (rev 1206) @@ -250,6 +250,7 @@ geom/facetbool/Makefile geom/parallel/Makefile geom/virtual/Makefile + init/Makefile cgm.make itaps/Makefile itaps/iGeom-Defs.inc Added: cgm/trunk/init/InitCGMA.cpp =================================================================== --- cgm/trunk/init/InitCGMA.cpp (rev 0) +++ cgm/trunk/init/InitCGMA.cpp 2007-07-17 21:06:46 UTC (rev 1206) @@ -0,0 +1,84 @@ +#include "InitCGMA.hpp" +#include "CGMApp.hpp" +#include "VirtualQueryEngine.hpp" +#include "FacetQueryEngine.hpp" +#include "FacetModifyEngine.hpp" + +#include <ctype.h> + +#ifdef CUBIT_CGM +#include <new> + +class AcisModifyEngine +{ +public: + AcisModifyEngine(); + static AcisModifyEngine *instance_; +}; + +class AcisQueryEngine +{ +public: + AcisQueryEngine(); + static AcisQueryEngine *instance_; +}; + +class dummym +{ + char dummyvar[4096]; +}; + +#elif defined(HAVE_ACIS) +# include "AcisQueryEngine.hpp" +# include "AcisModifyEngine.hpp" +#endif + + +static bool streq_nocase( const char* s, const char* t ) +{ + for (; *s; ++s, ++t) + if (tolower(*s) != tolower(*t)) + return false; + return !*t; +} + + +CubitStatus InitCGMA::initialize_cgma() +{ + CGMApp::instance()->startup( 0, NULL ); + return CUBIT_SUCCESS; +} + + +CubitStatus InitCGMA::initialize_engine( const char* name ) +{ + if (streq_nocase(name,"ACIS")) { +#ifdef CUBIT_CGM + if (!AcisQueryEngine::instance_) + AcisQueryEngine::instance_ = new (reinterpret_cast<AcisQueryEngine*>(new dummym)) AcisQueryEngine; + if (!AcisModifyEngine::instance_) + AcisModifyEngine::instance_ = new (reinterpret_cast<AcisModifyEngine*>(new dummym)) AcisModifyEngine; +#elif defined (HAVE_ACIS) + AcisQueryEngine::instance(); + AcisModifyEngine::instance(); +#else + return CUBIT_FAILURE; +#endif + } + + else if (streq_nocase(name,"VIRTUAL") || streq_nocase(name,"vg")) { + VirtualQueryEngine::instance(); + } + + else if (streq_nocase(name,"facet")) { + FacetQueryEngine::instance(); + FacetModifyEngine::instance(); + } + + else { + return CUBIT_FAILURE; + } + + return CUBIT_SUCCESS; +} + Added: cgm/trunk/init/InitCGMA.hpp =================================================================== --- cgm/trunk/init/InitCGMA.hpp (rev 0) +++ cgm/trunk/init/InitCGMA.hpp 2007-07-17 21:06:46 UTC (rev 1206) @@ -0,0 +1,15 @@ +#ifndef INIT_CGMA_HPP +#define INIT_CGMA_HPP + +#include "CubitDefines.h" + +class InitCGMA +{ +public: + + static CubitStatus initialize_cgma(); + + static CubitStatus initialize_engine( const char* name ); +}; + +#endif Added: cgm/trunk/init/Makefile =================================================================== --- cgm/trunk/init/Makefile (rev 0) +++ cgm/trunk/init/Makefile 2007-07-17 21:06:46 UTC (rev 1206) @@ -0,0 +1,543 @@ +# Makefile.in generated by automake 1.9.6 from Makefile.am. +# init/Makefile. Generated from Makefile.in by configure. + +# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, +# 2003, 2004, 2005 Free Software Foundation, Inc. +# This Makefile.in is free software; the Free Software Foundation +# gives unlimited permission to copy and/or distribute it, +# with or without modifications, as long as this notice is preserved. + +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY, to the extent permitted by law; without +# even the implied warranty of MERCHANTABILITY or FITNESS FOR A +# PARTICULAR PURPOSE. + + + + +srcdir = . +top_srcdir = .. + +pkgdatadir = $(datadir)/CGMA +pkglibdir = $(libdir)/CGMA +pkgincludedir = $(includedir)/CGMA +top_builddir = .. +am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd +INSTALL = /usr/bin/install -c +install_sh_DATA = $(install_sh) -c -m 644 +install_sh_PROGRAM = $(install_sh) -c +install_sh_SCRIPT = $(install_sh) -c +INSTALL_HEADER = $(INSTALL_DATA) +transform = $(program_transform_name) +NORMAL_INSTALL = : +PRE_INSTALL = : +POST_INSTALL = : +NORMAL_UNINSTALL = : +PRE_UNINSTALL = : +POST_UNINSTALL = : +build_triplet = x86_64-unknown-linux-gnu +host_triplet = x86_64-unknown-linux-gnu +target_triplet = x86_64-unknown-linux-gnu +subdir = init +DIST_COMMON = $(libcgma_init_la_include_HEADERS) $(srcdir)/Makefile.am \ + $(srcdir)/Makefile.in +ACLOCAL_M4 = $(top_srcdir)/aclocal.m4 +am__aclocal_m4_deps = $(top_srcdir)/configure.in +am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \ + $(ACLOCAL_M4) +mkinstalldirs = $(install_sh) -d +CONFIG_HEADER = $(top_builddir)/config.h \ + $(top_builddir)/itaps/iBase_FCDefs.h +CONFIG_CLEAN_FILES = +am__vpath_adj_setup = srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`; +am__vpath_adj = case $$p in \ + $(srcdir)/*) f=`echo "$$p" | sed "s|^$$srcdirstrip/||"`;; \ + *) f=$$p;; \ + esac; +am__strip_dir = `echo $$p | sed -e 's|^.*/||'`; +am__installdirs = "$(DESTDIR)$(libdir)" \ + "$(DESTDIR)$(libcgma_init_la_includedir)" +libLTLIBRARIES_INSTALL = $(INSTALL) +LTLIBRARIES = $(lib_LTLIBRARIES) +libcgma_init_la_LIBADD = +am_libcgma_init_la_OBJECTS = InitCGMA.lo +libcgma_init_la_OBJECTS = $(am_libcgma_init_la_OBJECTS) +DEFAULT_INCLUDES = -I. -I$(srcdir) -I$(top_builddir) -I$(top_builddir)/itaps +depcomp = $(SHELL) $(top_srcdir)/depcomp +am__depfiles_maybe = depfiles +CXXCOMPILE = $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) \ + $(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CXXFLAGS) $(CXXFLAGS) +LTCXXCOMPILE = $(LIBTOOL) --tag=CXX --mode=compile $(CXX) $(DEFS) \ + $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) \ + $(AM_CXXFLAGS) $(CXXFLAGS) +CXXLD = $(CXX) +CXXLINK = $(LIBTOOL) --tag=CXX --mode=link $(CXXLD) $(AM_CXXFLAGS) \ + $(CXXFLAGS) $(AM_LDFLAGS) $(LDFLAGS) -o $@ +SOURCES = $(libcgma_init_la_SOURCES) +DIST_SOURCES = $(libcgma_init_la_SOURCES) +libcgma_init_la_includeHEADERS_INSTALL = $(INSTALL_HEADER) +HEADERS = $(libcgma_init_la_include_HEADERS) +ETAGS = etags +CTAGS = ctags +DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST) +ACIS_DEFS = +ACIS_DIR = no +ACIS_HEALER = +ACIS_IGES_TRANSLATOR = +ACIS_INCLUDES = +ACIS_LIBS = +ACIS_LIB_DIR = . +ACIS_PLATFORM = +ACIS_STEP_TRANSLATOR = +ACIS_VERSION = 0 +ACLOCAL = ${SHELL} /home/jason/CGM/missing --run aclocal-1.9 +AMDEP_FALSE = # +AMDEP_TRUE = +AMTAR = ${SHELL} /home/jason/CGM/missing --run tar +AR = ar +AUTOCONF = ${SHELL} /home/jason/CGM/missing --run autoconf +AUTOHEADER = ${SHELL} /home/jason/CGM/missing --run autoheader +AUTOMAKE = ${SHELL} /home/jason/CGM/missing --run automake-1.9 +AWK = gawk +BABEL_DIR = +BUILD_CGM_FALSE = +BUILD_CGM_TRUE = # +CANT_USE_STD = +CANT_USE_STD_IO = +CC = cc +CCDEPMODE = depmode=gcc3 +CFLAGS = -g +CGM_ACIS_LIBS = +CGM_LIBS_FILES = $(CUBIT_FILE) +CGM_LIBS_LINK = $(CUBIT_LDFLAGS) $(CUBIT_LIBS) +CGM_LIBS_LTFLAGS = $(CUBIT_LTFLAGS) +CGM_PARALLEL_INCLUDE = +CGM_PARALLEL_LIB = +CGM_PARALLEL_LIB_FILE = +CPP = cc -E +CPPFLAGS = +CUBIT_CGM = -DCUBIT_CGM +CUBIT_FILE = /opt/cubit-10.1-amd64//bin/libcubiti19.so +CUBIT_LDFLAGS = -L/opt/cubit-10.1-amd64//bin -L/opt/cubit-10.1-amd64//bin/lib -L/opt/cubit-10.1-amd64//libs +CUBIT_LIBS = -lcubiti19 +CUBIT_LTFLAGS = -R/opt/cubit-10.1-amd64//bin -R/opt/cubit-10.1-amd64//bin/lib -R/opt/cubit-10.1-amd64//libs +CXX = c++ +CXXCPP = c++ -E +CXXDEPMODE = depmode=gcc3 +CXXFLAGS = -Wall -pipe -g +CYGPATH_W = echo + +# Override default defines with the ones we want from the configure script +DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN) $(HAVE_ACIS_DEF) $(CUBIT_CGM) +DEPDIR = .deps +ECHO = echo +ECHO_C = +ECHO_N = -n +ECHO_T = +EGREP = /bin/grep -E +EXEEXT = +F77 = g77 +FC = gfortran +FCFLAGS = -g -O2 +FCLIBS = -L/usr/lib/gcc/x86_64-linux-gnu/4.1.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.1.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -lgfortranbegin -lgfortran -lm +FFLAGS = -g -O2 +GREP = /bin/grep +HAVE_ACIS_DEF = -DHAVE_ACIS +INCLUDE_TEMPLATE_DEFS_FALSE = # +INCLUDE_TEMPLATE_DEFS_TRUE = +INSTALL_DATA = ${INSTALL} -m 644 +INSTALL_PROGRAM = ${INSTALL} +INSTALL_SCRIPT = ${INSTALL} +INSTALL_STRIP_PROGRAM = ${SHELL} $(install_sh) -c -s +LDFLAGS = +LIBOBJS = +LIBS = -lm +LIBTOOL = $(SHELL) $(top_builddir)/libtool +LITTLE_ENDIAN = -DLITTLE_ENDIAN=BYTE_ORDER +LN_S = ln -s +LTLIBOBJS = +MAKEINFO = ${SHELL} /home/jason/CGM/missing --run makeinfo +OBJEXT = o +PACKAGE = CGMA +PACKAGE_BUGREPORT = +PACKAGE_NAME = CGMA +PACKAGE_STRING = CGMA 10.2.2 +PACKAGE_TARNAME = cgma +PACKAGE_VERSION = 10.2.2 +PATH_SEPARATOR = : +RANLIB = ranlib +SET_MAKE = +SHELL = /bin/sh +STRIP = strip +TEMPLATE_DEFS_INCLUDED = -DTEMPLATE_DEFS_INCLUDED +USE_BABEL = no +USE_BABEL_FALSE = +USE_BABEL_TRUE = # +USE_MPI_FALSE = +USE_MPI_TRUE = # +VERSION = 10.2.2 +ac_ct_CC = cc +ac_ct_CXX = c++ +ac_ct_F77 = g77 +ac_ct_FC = gfortran +am__fastdepCC_FALSE = # +am__fastdepCC_TRUE = +am__fastdepCXX_FALSE = # +am__fastdepCXX_TRUE = +am__include = include +am__leading_dot = . +am__quote = +am__tar = ${AMTAR} chof - "$$tardir" +am__untar = ${AMTAR} xf - +bindir = ${exec_prefix}/bin +build = x86_64-unknown-linux-gnu +build_ACIS_FALSE = +build_ACIS_TRUE = # +build_alias = +build_cpu = x86_64 +build_os = linux-gnu +build_parallel_FALSE = +build_parallel_TRUE = # +build_vendor = unknown +datadir = ${datarootdir} +datarootdir = ${prefix}/share +docdir = ${datarootdir}/doc/${PACKAGE_TARNAME} +dvidir = ${docdir} +exec_prefix = ${prefix} +host = x86_64-unknown-linux-gnu +host_alias = +host_cpu = x86_64 +host_os = linux-gnu +host_vendor = unknown +htmldir = ${docdir} +includedir = ${prefix}/include +infodir = ${datarootdir}/info +install_sh = /home/jason/CGM/install-sh +libdir = ${exec_prefix}/lib +libexecdir = ${exec_prefix}/libexec +localedir = ${datarootdir}/locale +localstatedir = ${prefix}/var +mandir = ${datarootdir}/man +mkdir_p = mkdir -p -- +oldincludedir = /usr/include +pdfdir = ${docdir} +prefix = /usr/local +program_transform_name = s,x,x, +psdir = ${docdir} +sbindir = ${exec_prefix}/sbin +sharedstatedir = ${prefix}/com +sysconfdir = ${prefix}/etc +target = x86_64-unknown-linux-gnu +target_alias = +target_cpu = x86_64 +target_os = linux-gnu +target_vendor = unknown + +# Don't require GNU-standard files (Changelog, README, etc.) +AUTOMAKE_OPTIONS = foreign +INCLUDES = -I$(top_srcdir)/geom \ + -I$(top_srcdir)/util \ + -I$(top_srcdir)/geom/ACIS \ + -I$(top_srcdir)/geom/virtual \ + -I$(top_srcdir)/geom/facet \ + -I$(top_srcdir)/geom/cholla \ + -I$(srcdir) + +lib_LTLIBRARIES = libcgma_init.la +libcgma_init_la_includedir = $(includedir) +libcgma_init_la_SOURCES = InitCGMA.cpp +libcgma_init_la_include_HEADERS = InitCGMA.hpp +all: all-am + +.SUFFIXES: +.SUFFIXES: .cpp .lo .o .obj +$(srcdir)/Makefile.in: $(srcdir)/Makefile.am $(am__configure_deps) + @for dep in $?; do \ + case '$(am__configure_deps)' in \ + *$$dep*) \ + cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh \ + && exit 0; \ + exit 1;; \ + esac; \ + done; \ + echo ' cd $(top_srcdir) && $(AUTOMAKE) --foreign init/Makefile'; \ + cd $(top_srcdir) && \ + $(AUTOMAKE) --foreign init/Makefile +.PRECIOUS: Makefile +Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status + @case '$?' in \ + *config.status*) \ + cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh;; \ + *) \ + echo ' cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)'; \ + cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe);; \ + esac; + +$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES) + cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh + +$(top_srcdir)/configure: $(am__configure_deps) + cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh +$(ACLOCAL_M4): $(am__aclocal_m4_deps) + cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh +install-libLTLIBRARIES: $(lib_LTLIBRARIES) + @$(NORMAL_INSTALL) + test -z "$(libdir)" || $(mkdir_p) "$(DESTDIR)$(libdir)" + @list='$(lib_LTLIBRARIES)'; for p in $$list; do \ + if test -f $$p; then \ + f=$(am__strip_dir) \ + echo " $(LIBTOOL) --mode=install $(libLTLIBRARIES_INSTALL) $(INSTALL_STRIP_FLAG) '$$p' '$(DESTDIR)$(libdir)/$$f'"; \ + $(LIBTOOL) --mode=install $(libLTLIBRARIES_INSTALL) $(INSTALL_STRIP_FLAG) "$$p" "$(DESTDIR)$(libdir)/$$f"; \ + else :; fi; \ + done + +uninstall-libLTLIBRARIES: + @$(NORMAL_UNINSTALL) + @set -x; list='$(lib_LTLIBRARIES)'; for p in $$list; do \ + p=$(am__strip_dir) \ + echo " $(LIBTOOL) --mode=uninstall rm -f '$(DESTDIR)$(libdir)/$$p'"; \ + $(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(libdir)/$$p"; \ + done + +clean-libLTLIBRARIES: + -test -z "$(lib_LTLIBRARIES)" || rm -f $(lib_LTLIBRARIES) + @list='$(lib_LTLIBRARIES)'; for p in $$list; do \ + dir="`echo $$p | sed -e 's|/[^/]*$$||'`"; \ + test "$$dir" != "$$p" || dir=.; \ + echo "rm -f \"$${dir}/so_locations\""; \ + rm -f "$${dir}/so_locations"; \ + done +libcgma_init.la: $(libcgma_init_la_OBJECTS) $(libcgma_init_la_DEPENDENCIES) + $(CXXLINK) -rpath $(libdir) $(libcgma_init_la_LDFLAGS) $(libcgma_init_la_OBJECTS) $(libcgma_init_la_LIBADD) $(LIBS) + +mostlyclean-compile: + -rm -f *.$(OBJEXT) + +distclean-compile: + -rm -f *.tab.c + +include ./$(DEPDIR)/InitCGMA.Plo + +.cpp.o: + if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \ + then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Po"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi +# source='$<' object='$@' libtool=no \ +# DEPDIR=$(DEPDIR) $(CXXDEPMODE) $(depcomp) \ +# $(CXXCOMPILE) -c -o $@ $< + +.cpp.obj: + if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ `$(CYGPATH_W) '$<'`; \ + then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Po"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi +# source='$<' object='$@' libtool=no \ +# DEPDIR=$(DEPDIR) $(CXXDEPMODE) $(depcomp) \ +# $(CXXCOMPILE) -c -o $@ `$(CYGPATH_W) '$<'` + +.cpp.lo: + if $(LTCXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \ + then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Plo"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi +# source='$<' object='$@' libtool=yes \ +# DEPDIR=$(DEPDIR) $(CXXDEPMODE) $(depcomp) \ +# $(LTCXXCOMPILE) -c -o $@ $< + +mostlyclean-libtool: + -rm -f *.lo + +clean-libtool: + -rm -rf .libs _libs + +distclean-libtool: + -rm -f libtool +uninstall-info-am: +install-libcgma_init_la_includeHEADERS: $(libcgma_init_la_include_HEADERS) + @$(NORMAL_INSTALL) + test -z "$(libcgma_init_la_includedir)" || $(mkdir_p) "$(DESTDIR)$(libcgma_init_la_includedir)" + @list='$(libcgma_init_la_include_HEADERS)'; for p in $$list; do \ + if test -f "$$p"; then d=; else d="$(srcdir)/"; fi; \ + f=$(am__strip_dir) \ + echo " $(libcgma_init_la_includeHEADERS_INSTALL) '$$d$$p' '$(DESTDIR)$(libcgma_init_la_includedir)/$$f'"; \ + $(libcgma_init_la_includeHEADERS_INSTALL) "$$d$$p" "$(DESTDIR)$(libcgma_init_la_includedir)/$$f"; \ + done + +uninstall-libcgma_init_la_includeHEADERS: + @$(NORMAL_UNINSTALL) + @list='$(libcgma_init_la_include_HEADERS)'; for p in $$list; do \ + f=$(am__strip_dir) \ + echo " rm -f '$(DESTDIR)$(libcgma_init_la_includedir)/$$f'"; \ + rm -f "$(DESTDIR)$(libcgma_init_la_includedir)/$$f"; \ + done + +ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES) + list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \ + unique=`for i in $$list; do \ + if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \ + done | \ + $(AWK) ' { files[$$0] = 1; } \ + END { for (i in files) print i; }'`; \ + mkid -fID $$unique +tags: TAGS + +TAGS: $(HEADERS) $(SOURCES) $(TAGS_DEPENDENCIES) \ + $(TAGS_FILES) $(LISP) + tags=; \ + here=`pwd`; \ + list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \ + unique=`for i in $$list; do \ + if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \ + done | \ + $(AWK) ' { files[$$0] = 1; } \ + END { for (i in files) print i; }'`; \ + if test -z "$(ETAGS_ARGS)$$tags$$unique"; then :; else \ + test -n "$$unique" || unique=$$empty_fix; \ + $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \ + $$tags $$unique; \ + fi +ctags: CTAGS +CTAGS: $(HEADERS) $(SOURCES) $(TAGS_DEPENDENCIES) \ + $(TAGS_FILES) $(LISP) + tags=; \ + here=`pwd`; \ + list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \ + unique=`for i in $$list; do \ + if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \ + done | \ + $(AWK) ' { files[$$0] = 1; } \ + END { for (i in files) print i; }'`; \ + test -z "$(CTAGS_ARGS)$$tags$$unique" \ + || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \ + $$tags $$unique + +GTAGS: + here=`$(am__cd) $(top_builddir) && pwd` \ + && cd $(top_srcdir) \ + && gtags -i $(GTAGS_ARGS) $$here + +distclean-tags: + -rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags + +distdir: $(DISTFILES) + @srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`; \ + topsrcdirstrip=`echo "$(top_srcdir)" | sed 's|.|.|g'`; \ + list='$(DISTFILES)'; for file in $$list; do \ + case $$file in \ + $(srcdir)/*) file=`echo "$$file" | sed "s|^$$srcdirstrip/||"`;; \ + $(top_srcdir)/*) file=`echo "$$file" | sed "s|^$$topsrcdirstrip/|$(top_builddir)/|"`;; \ + esac; \ + if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \ + dir=`echo "$$file" | sed -e 's,/[^/]*$$,,'`; \ + if test "$$dir" != "$$file" && test "$$dir" != "."; then \ + dir="/$$dir"; \ + $(mkdir_p) "$(distdir)$$dir"; \ + else \ + dir=''; \ + fi; \ + if test -d $$d/$$file; then \ + if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \ + cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \ + fi; \ + cp -pR $$d/$$file $(distdir)$$dir || exit 1; \ + else \ + test -f $(distdir)/$$file \ + || cp -p $$d/$$file $(distdir)/$$file \ + || exit 1; \ + fi; \ + done +check-am: all-am +check: check-am +all-am: Makefile $(LTLIBRARIES) $(HEADERS) +installdirs: + for dir in "$(DESTDIR)$(libdir)" "$(DESTDIR)$(libcgma_init_la_includedir)"; do \ + test -z "$$dir" || $(mkdir_p) "$$dir"; \ + done +install: install-am +install-exec: install-exec-am +install-data: install-data-am +uninstall: uninstall-am + +install-am: all-am + @$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am + +installcheck: installcheck-am +install-strip: + $(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \ + install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \ + `test -z '$(STRIP)' || \ + echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install +mostlyclean-generic: + +clean-generic: + +distclean-generic: + -test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES) + +maintainer-clean-generic: + @echo "This command is intended for maintainers to use" + @echo "it deletes files that may require special tools to rebuild." +clean: clean-am + +clean-am: clean-generic clean-libLTLIBRARIES clean-libtool \ + mostlyclean-am + +distclean: distclean-am + -rm -rf ./$(DEPDIR) + -rm -f Makefile +distclean-am: clean-am distclean-compile distclean-generic \ + distclean-libtool distclean-tags + +dvi: dvi-am + +dvi-am: + +html: html-am + +info: info-am + +info-am: + +install-data-am: install-libcgma_init_la_includeHEADERS + +install-exec-am: install-libLTLIBRARIES + +install-info: install-info-am + +install-man: + +installcheck-am: + +maintainer-clean: maintainer-clean-am + -rm -rf ./$(DEPDIR) + -rm -f Makefile +maintainer-clean-am: distclean-am maintainer-clean-generic + +mostlyclean: mostlyclean-am + +mostlyclean-am: mostlyclean-compile mostlyclean-generic \ + mostlyclean-libtool + +pdf: pdf-am + +pdf-am: + +ps: ps-am + +ps-am: + +uninstall-am: uninstall-info-am uninstall-libLTLIBRARIES \ + uninstall-libcgma_init_la_includeHEADERS + +.PHONY: CTAGS GTAGS all all-am check check-am clean clean-generic \ + clean-libLTLIBRARIES clean-libtool ctags distclean \ + distclean-compile distclean-generic distclean-libtool \ + distclean-tags distdir dvi dvi-am html html-am info info-am \ + install install-am install-data install-data-am install-exec \ + install-exec-am install-info install-info-am \ + install-libLTLIBRARIES install-libcgma_init_la_includeHEADERS \ + install-man install-strip installcheck installcheck-am \ + installdirs maintainer-clean maintainer-clean-generic \ + mostlyclean mostlyclean-compile mostlyclean-generic \ + mostlyclean-libtool pdf pdf-am ps ps-am tags uninstall \ + uninstall-am uninstall-info-am uninstall-libLTLIBRARIES \ + uninstall-libcgma_init_la_includeHEADERS + +# Tell versions [3.59,3.63) of GNU make to not export all variables. +# Otherwise a system limit (for SysV at least) may be exceeded. +.NOEXPORT: Added: cgm/trunk/init/Makefile.am =================================================================== --- cgm/trunk/init/Makefile.am (rev 0) +++ cgm/trunk/init/Makefile.am 2007-07-17 21:06:46 UTC (rev 1206) @@ -0,0 +1,20 @@ +# Don't require GNU-standard files (Changelog, README, etc.) +AUTOMAKE_OPTIONS = foreign + + +# Override default defines with the ones we want from the configure script +DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN) $(HAVE_ACIS_DEF) $(CUBIT_CGM) +INCLUDES = -I$(top_srcdir)/geom \ + -I$(top_srcdir)/util \ + -I$(top_srcdir)/geom/ACIS \ + -I$(top_srcdir)/geom/virtual \ + -I$(top_srcdir)/geom/facet \ + -I$(top_srcdir)/geom/cholla \ + -I$(srcdir) + +lib_LTLIBRARIES = libcgma_init.la +libcgma_init_la_includedir = $(includedir) +libcgma_init_la_SOURCES = InitCGMA.cpp +libcgma_init_la_include_HEADERS = InitCGMA.hpp + + Deleted: cgm/trunk/itaps/CGMA_ACIS.cc =================================================================== --- cgm/trunk/itaps/CGMA_ACIS.cc 2007-07-17 17:55:11 UTC (rev 1205) +++ cgm/trunk/itaps/CGMA_ACIS.cc 2007-07-17 21:06:46 UTC (rev 1206) @@ -1,35 +0,0 @@ -#include "CGMA_ACIS.h" -#include <new> - -class AcisModifyEngine -{ -public: - AcisModifyEngine(); - static AcisModifyEngine *instance_; -}; - - -class AcisQueryEngine -{ -public: - AcisQueryEngine(); - static AcisQueryEngine *instance_; -}; - - -class dummym -{ - char dummyvar[4096]; -}; - - -int CGMA_initialize_ACIS() -{ - if (!AcisQueryEngine::instance_) - AcisQueryEngine::instance_ = new (reinterpret_cast<AcisQueryEngine*>(new dummym)) AcisQueryEngine; - if (!AcisModifyEngine::instance_) - AcisModifyEngine::instance_ = new (reinterpret_cast<AcisQueryEngine*>(new dummym)) AcisModifyEngine; - return 0; -} - - Deleted: cgm/trunk/itaps/CGMA_ACIS.h =================================================================== --- cgm/trunk/itaps/CGMA_ACIS.h 2007-07-17 17:55:11 UTC (rev 1205) +++ cgm/trunk/itaps/CGMA_ACIS.h 2007-07-17 21:06:46 UTC (rev 1206) @@ -1,14 +0,0 @@ -#ifndef CGMA_ACIS_H -#define CGMA_ACIS_H - -#ifdef __cplusplus -extern "C" { -#endif - -int CGMA_initialize_ACIS(); - -#ifdef __cplusplus -} // extern "C" -#endif - -#endif Modified: cgm/trunk/itaps/Makefile.am =================================================================== --- cgm/trunk/itaps/Makefile.am 2007-07-17 17:55:11 UTC (rev 1205) +++ cgm/trunk/itaps/Makefile.am 2007-07-17 21:06:46 UTC (rev 1206) @@ -25,27 +25,24 @@ $(top_builddir)/geom/libcubit_geom.la \ $(top_builddir)/util/libcubit_util.la TEST_XLDFLAGS = -R$(ACIS_LIB_DIR) - CGM_ACIS_SRCS = else TEST_XLDFLAGS = $(CUBIT_LDFLAGS) $(CUBIT_LTFLAGS) TEST_XLIBS = $(CUBIT_LIBS) -# If not building CGM, then have Cubit library w/ ACIS support - CGM_ACIS_SRCS = CGMA_ACIS.cc endif if build_ACIS - ACIS_SRCS = CGMA_ACIS.cc ACIS_CGM_INCLUDES = -I$(top_srcdir)/geom/ACIS else - ACIS_SRCS = ACIS_CGM_INCLUDES = endif libiGeom_la_includedir = $(includedir) +libiGeom_la_libadd = $(top_builddir)/init/libcgma_init.la $(TEST_XLIBS) + INCLUDES = -I$(top_srcdir)/util \ -I$(top_srcdir)/geom \ - $(ACIS_CGM_INCLUDES ) \ + -I$(top_srcdir)/init \ -I. libiGeom_la_SOURCES = \ @@ -53,10 +50,7 @@ CATag.cpp \ iGeom_CGMA.cc \ iGeomError.cc \ - iGeomError.h \ - CGMA_ACIS.h \ - $(ACIS_SRCS) \ - $(CGM_ACIS_SRCS) + iGeomError.h libiGeom_la_include_HEADERS = \ iBase.h \ Modified: cgm/trunk/itaps/iGeom_CGMA.cc =================================================================== --- cgm/trunk/itaps/iGeom_CGMA.cc 2007-07-17 17:55:11 UTC (rev 1205) +++ cgm/trunk/itaps/iGeom_CGMA.cc 2007-07-17 21:06:46 UTC (rev 1206) @@ -21,6 +21,7 @@ * 2007-6-15 */ #include "iGeom.h" +#include "InitCGMA.hpp" #include <iostream> #include <math.h> @@ -30,11 +31,6 @@ # include "config.h" #endif -#ifdef HAVE_ACIS -# include "CGMA_ACIS.h" -#endif - - const bool debug = false; #define RETURN(a) do {iGeom_setLastError((*err = a)); return; } while(false) @@ -241,12 +237,8 @@ ERROR(iBase_NOT_SUPPORTED, "No options for iGeom factory have been implemented."); } - CGMApp::instance()->startup( 0, NULL ); - - // assuem for now that we want ACIS -#ifdef HAVE_ACIS - CGMA_initialize_ACIS(); -#endif + InitCGMA::initialize_cgma(); + InitCGMA::initialize_engine("ACIS"); // sometimes can't have following, depending on CGM version // CGMApp::instance()->attrib_manager()->silent_flag(true);
participants (1)
kraftche@mcs.anl.gov
