Author: janehu Date: 2010-08-06 12:57:40 -0500 (Fri, 06 Aug 2010) New Revision: 4073 Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp Log: Fixed test case merge_occ Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2010-08-04 21:05:28 UTC (rev 4072) +++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2010-08-06 17:57:40 UTC (rev 4073) @@ -2099,6 +2099,30 @@ sense = (topo_face.Orientation() == TopAbs_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD); else sense = (topo_face.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED); + + if(sense == CUBIT_REVERSED ) + { + //When the loop has only one curve, the wire and face sense usually + //are the same, so don't need to reverse again. + //have to reverse wire direction and coedge sense for multi-curve situ. + DLIList<OCCLoop*> loops; + DLIList<OCCCoEdge*> coedges; + occ_surface->get_loops(loops); + for (int i = 0; i < loops.size(); i++) + { + OCCLoop* loop = loops.get_and_step(); + coedges = loop->coedges(); + if(coedges.size() == 1) + continue; + coedges.reverse(); + for (int j = 0; j < coedges.size(); j++) + { + OCCCoEdge* coedge = coedges.get_and_step(); + coedge->set_sense(coedge->sense() == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD); + } + loop->coedges(coedges); + } + } for(int i = 0; i < size; i++) { coface = cofaces_old.get_and_step();
participants (1)
jiangtao_ma@yahoo.com
