Author: janehu Date: 2010-08-06 12:59:48 -0500 (Fri, 06 Aug 2010) New Revision: 4074 Modified: cgm/trunk/test/Makefile.am cgm/trunk/test/makept.cpp Log: Changes according to fix for merge_occ. Curve order has changed, makept has some change with change of curves. Modified: cgm/trunk/test/Makefile.am =================================================================== --- cgm/trunk/test/Makefile.am 2010-08-06 17:57:40 UTC (rev 4073) +++ cgm/trunk/test/Makefile.am 2010-08-06 17:59:48 UTC (rev 4074) @@ -23,7 +23,7 @@ endif endif if build_OCC - TESTS += modify makept r_w test_occ operation brick_occ #merge_occ + TESTS += modify makept r_w test_occ operation brick_occ merge_occ endif AM_CPPFLAGS = Modified: cgm/trunk/test/makept.cpp =================================================================== --- cgm/trunk/test/makept.cpp 2010-08-06 17:57:40 UTC (rev 4073) +++ cgm/trunk/test/makept.cpp 2010-08-06 17:59:48 UTC (rev 4074) @@ -523,10 +523,10 @@ int num_loops = ref_face->ref_edge_loops(ref_edge_loops); DLIList<RefEdge*> *ref_edges1; ref_edges1 = ref_edge_loops.get(); - RefEdge* edge1 = ref_edges1->get(); - RefEdge* edge2 = ref_edges1->step_and_get(); - double angle = edge1->angle_between(edge2, ref_face); - assert(fabs(angle - 1.57) < 0.001); + RefEdge* edge1 = ref_edges1->pop(); + RefEdge* edge2 = ref_edges1->pop(); + double angle = edge2->angle_between(edge1, ref_face); + assert(fabs(angle - 4.712) < 0.001); //test for curve CubitVector c_point, tangent, center; @@ -643,17 +643,17 @@ // bounding box d = ref_edge->measure(); - assert(fabs(d - 13.9987) < 0.001); + assert(fabs(d - 11.042) < 0.001); ref_edge->get_param_range(lower,upper); - assert(lower - 19988 <= 0 && fabs(upper-20001.998) < 0.001); + assert(lower - 2.6024 <= 0.0001 && fabs(upper-6.2832) < 0.001); // paremeter range. d = ref_edge->length_from_u(lower,upper); - assert(fabs(d - 13.9987) < 0.001); + assert(fabs(d - 11.042) < 0.001); d = ref_edge->length_from_u(lower/2+upper/2, upper); - assert(fabs(d-6.99939) < 0.0001);
participants (1)
jiangtao_ma@yahoo.com
