Author: wilsonp Date: 2011-06-02 02:34:07 -0500 (Thu, 02 Jun 2011) New Revision: 4920 Modified: cgm/trunk/itaps/testgeom.cc Log: Added rudimentary test for iGeom_getFacets(...) Modified: cgm/trunk/itaps/testgeom.cc =================================================================== --- cgm/trunk/itaps/testgeom.cc 2011-06-02 07:14:03 UTC (rev 4919) +++ cgm/trunk/itaps/testgeom.cc 2011-06-02 07:34:07 UTC (rev 4920) @@ -108,6 +108,7 @@ bool primitives_test(iGeom_Instance geom); bool transforms_test(iGeom_Instance geom); bool booleans_test(iGeom_Instance geom); +bool faceting_test(iGeom_Instance geom); bool shutdown_test(iGeom_Instance geom, std::string &engine_opt); bool save_entset_test(iGeom_Instance geom); bool mesh_size_test(iGeom_Instance geom); @@ -261,6 +262,15 @@ std::cout << "\n"; #endif + // facet tests + std::cout << " faceting: "; + result = faceting_test(geom); + handle_error_code(result, number_tests_failed, + number_tests_not_implemented, + number_tests_successful); + number_tests++; + std::cout << "\n"; + // shutdown test std::cout << " shutdown: "; result = shutdown_test(geom, engine_opt); @@ -283,6 +293,7 @@ return number_tests_failed; } + /*! @test Load Mesh @@ -1241,8 +1252,7 @@ bool mesh_size_test(iGeom_Instance geom) { const char* filename = STRINGIFY(SRCDIR) "/size.sat"; - int err, junk1, junk2; - bool result = true; + int err; iGeom_deleteAll( geom, &err ); CHECK(""); iGeom_load( geom, filename, 0, &err, strlen(filename), 0 ); @@ -1337,6 +1347,71 @@ return true; } +bool faceting_test(iGeom_Instance geom)
participants (1)
wilsonp@engr.wisc.edu
