Author: wilsonp Date: 2011-06-02 02:14:03 -0500 (Thu, 02 Jun 2011) New Revision: 4919 Modified: cgm/trunk/itaps/iGeom.h cgm/trunk/itaps/iGeom_CGMA.cc Log: Backed out changes to usage/behavior of some of the interface variables, based on misunderstanding. Passes make check - though still not getFacets test - one underway. Modified: cgm/trunk/itaps/iGeom.h =================================================================== --- cgm/trunk/itaps/iGeom.h 2011-06-02 06:31:55 UTC (rev 4918) +++ cgm/trunk/itaps/iGeom.h 2011-06-02 07:14:03 UTC (rev 4919) @@ -3927,12 +3927,12 @@ * \param instance iGeom instance handle * \param entity_handle Entity being queried * \param dist_tolerance Tolerance guidance for faceting engine - * \param **points List of vertices in faceting of curve or surface - * \param *points_allocated Number of points in faceting - * \param *points_size Size of points array (should be 3*points_allocated?) - * \param **facets List of facets in faceting of surface - * \param *facets_allocated Number of facets in surface faceting - * \param *facets_size Size of facets array (should be 3*facets_allocated?) + * \param points List of vertices in faceting of curve or surface + * \param points_allocated Allocated size of vertex list array + * \param points_size Occupied size of vertex list array + * \param facets List of facets in faceting of surface + * \param facets_allocated Allocated size of facet list array + * \param facets_size Occupied size of facet list array * \param *err Pointer to error type returned from function */ void iGeom_getFacets(iGeom_Instance instance, Modified: cgm/trunk/itaps/iGeom_CGMA.cc =================================================================== --- cgm/trunk/itaps/iGeom_CGMA.cc 2011-06-02 06:31:55 UTC (rev 4918) +++ cgm/trunk/itaps/iGeom_CGMA.cc 2011-06-02 07:14:03 UTC (rev 4919) @@ -7106,8 +7106,6 @@ y += step; z += step; } - *points_allocated = p_count; - *points_size = p_count * 3; } if(f_count) { @@ -7125,8 +7123,6 @@ *(connectivity + 2) = list[i*4 + 3]; connectivity += 3; } - *facets_allocated = f_count/4; - *facets_size = f_count*3/4; } RETURN(iBase_SUCCESS); }
participants (1)
wilsonp@engr.wisc.edu
