Author: kraftche Date: 2010-08-10 11:20:01 -0500 (Tue, 10 Aug 2010) New Revision: 4075 Modified: cgm/trunk/configure.ac Log: Fix detection of OCC STEP & STL support: It is no longer possible to use the 'main trick' to work around the lack of support for detecting C++ libraries with autoconf because calling 'main' or taking the address of it violates the upcomming C++ standard. Modified: cgm/trunk/configure.ac =================================================================== --- cgm/trunk/configure.ac 2010-08-06 17:59:48 UTC (rev 4074) +++ cgm/trunk/configure.ac 2010-08-10 16:20:01 UTC (rev 4075) @@ -309,6 +309,7 @@ OCC_LCAF_LIBS="-lTKLCAF -lTKBinL" OCC_LIBS="$OCC_LCAF_LIBS $OCC_GEOM_LIBS $OCC_CORE_LIBS" CUBIT_OCC_LIB="-lcubit_OCC" + OCC_STEP_LIBS="-lTKSTEP -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKXSBase" # Set OCC_INC_FLAG and OCC_LIB_FLAG based on --with-occ option if test "x$occ_DIR" = "x"; then @@ -400,15 +401,27 @@ [HAVE_OCC_DEF="$HAVE_OCC_DEF -DHAVE_OCC_IGES" OCC_LIBS="-lTKIGES -lTKXSBase $OCC_LIBS"], [], [$OCC_LIBS] ) - AC_CHECK_LIB( [TKSTEP], [main], - [HAVE_OCC_DEF="$HAVE_OCC_DEF -DHAVE_OCC_STEP" - OCC_LIBS="-lTKSTEP -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKXSBase $OCC_LIBS"], - [], [$OCC_LIBS] ) - AC_CHECK_LIB( [TKSTL], [main], - [HAVE_OCC_DEF="$HAVE_OCC_DEF -DHAVE_OCC_STL" - OCC_LIBS="-lTKSTL $OCC_LIBS"], - [], [$OCC_LIBS] ) - + AC_MSG_CHECKING([for OpenCascade STEP support (libTKSTEP)]) + old_LIBS="$LIBS" + LIBS="$OCC_STEP_LIBS $OCC_LIBS $LIBS" + CPPFLAGS="$CPPFLAGS $OCC_INC_FLAG" + AC_LINK_IFELSE( + [AC_LANG_PROGRAM([#include "STEPControl_Reader.hxx"], + [STEPControl_Reader reader;])], + [HAVE_OCC_DEF="$HAVE_OCC_DEF -DHAVE_OCC_STEP" + OCC_LIBS="$OCC_STEP_LIBS $OCC_LIBS" + AC_MSG_RESULT([yes])], + [AC_MSG_RESULT([no])]) + AC_MSG_CHECKING([for OpenCascade STL support (libTKSTL)]) + LIBS="-lTKSTL $OCC_LIBS $old_LIBS" + AC_LINK_IFELSE( + [AC_LANG_PROGRAM([#include "StlAPI_Reader.hxx"], + [StlAPI_Reader reader;])], + [HAVE_OCC_DEF="$HAVE_OCC_DEF -DHAVE_OCC_STL" + OCC_LIBS="-lTKSTL $OCC_LIBS" + AC_MSG_RESULT([yes])], + [AC_MSG_RESULT([no])]) + LIBS="$old_LIBS" AC_LANG_POP(C++)
participants (1)
kraftche@cae.wisc.edu
