Author: wilsonp Date: 2011-06-02 01:31:55 -0500 (Thu, 02 Jun 2011) New Revision: 4918 Modified: cgm/trunk/itaps/iGeom.h cgm/trunk/itaps/iGeom_CGMA.cc Log: Add documentation to interface for getFacets method. Assign values to return variables that indicate size of allocated space. Passes make check - although there are not yet any tests for this method anyway! Modified: cgm/trunk/itaps/iGeom.h =================================================================== --- cgm/trunk/itaps/iGeom.h 2011-06-02 02:45:44 UTC (rev 4917) +++ cgm/trunk/itaps/iGeom.h 2011-06-02 06:31:55 UTC (rev 4918) @@ -3921,6 +3921,20 @@ iBase_EntitySetHandle* result_entity_set, int *err ); + /**\brief Return facet information from solid modeling engine + * + * Return facet information from solid modeling engine + * \param instance iGeom instance handle + * \param entity_handle Entity being queried + * \param dist_tolerance Tolerance guidance for faceting engine + * \param **points List of vertices in faceting of curve or surface + * \param *points_allocated Number of points in faceting + * \param *points_size Size of points array (should be 3*points_allocated?) + * \param **facets List of facets in faceting of surface + * \param *facets_allocated Number of facets in surface faceting + * \param *facets_size Size of facets array (should be 3*facets_allocated?) + * \param *err Pointer to error type returned from function + */ void iGeom_getFacets(iGeom_Instance instance, iBase_EntityHandle entity, double dist_tolerance, Modified: cgm/trunk/itaps/iGeom_CGMA.cc =================================================================== --- cgm/trunk/itaps/iGeom_CGMA.cc 2011-06-02 02:45:44 UTC (rev 4917) +++ cgm/trunk/itaps/iGeom_CGMA.cc 2011-06-02 06:31:55 UTC (rev 4918) @@ -7106,6 +7106,8 @@ y += step; z += step; } + *points_allocated = p_count; + *points_size = p_count * 3; } if(f_count) { @@ -7123,6 +7125,8 @@ *(connectivity + 2) = list[i*4 + 3]; connectivity += 3; } + *facets_allocated = f_count/4; + *facets_size = f_count*3/4; } RETURN(iBase_SUCCESS); }
participants (1)
wilsonp@engr.wisc.edu
