Profiling arbitrary parts of an application with Darshan
Hello, I am using Darshan to profile my application and I wonder if it is possible to enable/disable Darshan profiling for arbitrary parts of the application. The thing is that my application does a lot of I/O work, but I only want to profile a small part. If I profile the whole application, the reports have a lot of noise from the I/O part that I do not want to profile. Darshan version is 2.3.1 (but I can update it to the latest one if needed) and I am running on a BG/Q system. Thanks in advance, Judit
On 01/28/2016 05:05 AM, Judit Planas wrote:
Hello,
There are two things that might help you: - darshan-summary-per-file.sh might do the trick? you can generate profiles on a per-file basis when you want to, for example, exclude reading in the input deck and focus only on output. This approach works well if there are particular files you want to study, but not so well if there's a particular phase of I/O you are most concerned about: - I don't know if anyone has tried using MPI_PCONTROL with darshan. I don't think Darshan knows what to do with that routine, anyway. ==rob
Thanks in advance, Judit _______________________________________________ Darshan-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
Hi Rob, Thanks for your reply. Unfortunately, I already tried darshan-summary-per-file.sh, but it didn't work for me: some of the charts and tables in the generated PDF are blank or filled with 0's. For example, 'I/O sizes' and 'I/O pattern' charts are completely blank. And the 'Average I/O per process' and 'Data Transfer Per Filesystem' tables are filled with either 0's or 'N/A'. However, I know the file was created by my application and around 16 MB of data were written (that is the size of the file at the end of the execution). When running the darshan-summary-per-file.sh script, I get the following messages for the file I'm interested in (I guess the PDF charts are blank because of the warnings...): ======================================================= Slowest unique file time: 0 Slowest shared file time: 65.503991 Total bytes read and written by app (may be incorrect): 0 Total absolute I/O time: 65.503991 Warning: empty y range [0:0], adjusting to [-1:1] Warning: empty y range [0:0], adjusting to [-1:1] Status: Generating summary for file 81 of 177: allcurrents.bbp ======================================================= Any idea? Thanks in advance, Judit
/ Hello, />>/ />>/ I am using Darshan to profile my application and I wonder if it is />>/ possible to enable/disable Darshan profiling for arbitrary parts of the/ / application. />>/ />>/ The thing is that my application does a lot of I/O work, but I only want />>/ to profile a small part. If I profile the whole application, the reports />>/ have a lot of noise from the I/O part that I do not want to profile. />>/ />>/ Darshan version is 2.3.1 (but I can update it to the latest one if />>/ needed) and I am running on a BG/Q system. /> There are two things that might help you:
==rob
/ />/> Thanks in advance, />/> Judit />/> _______________________________________________ />/> Darshan-users mailing list />/>Darshan-users at lists.mcs.anl.gov <https://lists.mcs.anl.gov/mailman/listinfo/darshan-users> />/>https://lists.mcs.anl.gov/mailman/listinfo/darshan-users /
participants (2)
Judit Planas -
Rob Latham
