test failures on armhf architecture on Debian
Hi, I've built 3.3a2 on Debian on all supported architectures. Failures were seen on the armhf architecture (Arm with hardware float support, 32-bit v7 architecture). Testing integer swap with 4 threads *FAILED* at test_primitives.c:3399 in test_threaded_swap_int()... Value 0 was encountered 0 times. Expected: 1 Testing pointer swap with 4 threads *FAILED* at test_primitives.c:3554 in test_threaded_swap_ptr()... Value 3 was encountered 2 times. Expected: 1 Details: https://buildd.debian.org/status/fetch.php?pkg=mpich&arch=armhf&ver=3.3%7Ea2... Is anyone working on this? If necessary I can do testing on armhf systems Best regards Alastair -- Alastair McKinstry, <[email protected]>, <[email protected]>, https://diaspora.sceal.ie/u/amckinstry Misentropy: doubting that the Universe is becoming more disordered. H _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Alastair McKinstry
