mpi_comm_spawn - process not destroyed
Dear all, I'm just trying some very basic stuff with MPI_COMM_SPAWN in python (i.e. I use mpi4py package), but I see behaviour that I do not understand - the child process gets spawned, does its stuff and then "should" finish. I see though, that the process created for the child stays alive. I see this only with the MPICH, OPENMPI does what I would (naively) expect. In this way I can end up with N "ghost" process, after calling SPAWN N-times. My minimal working example is following: ______________________________________________ parent.py from __future__ import print_function from mpi4py import MPI comm = MPI.COMM_WORLD spawned = MPI.COMM_SELF.Spawn(sys.executable,args=['child.py'],maxprocs=1) print("parent process is waiting for child") spawned.Barrier() ______________________________________________ child.py from __future__ import print_function from mpi4py import MPI parent = MPI.Comm.Get_parent() # just do some stupid stuff that takes a bit of time for i in range(5000000): a = i*i+1-(i*10) + math.sin(math.pow(i,i%8)) parent.Barrier() ______________________________________________ I run with e.g.: mpirun -n 1 python mpi.py Do I miss something with SPAWN method? (I tested on two independent systems, our local cluster with mpich v3.0.4, and my laptop - fedora 26, mpich v3.2.8 from repositories) thank you very much for suggestions. Regards, stanislav. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Stanislav Simko
