Re: [mpich-discuss] Fwd: MPICH fault tolerance and resiliency
Thanks for the info. Regards Sanjeev On Thu, Jun 1, 2017 at 9:52 PM, Guo, Yanfei <[email protected]> wrote:
There is no support for fault tolerance in the current MPI standard. But there will be one in the future.
Yanfei Guo Postdoctoral Researcher MCS Division, ANL
On 6/1/17, 1:28 AM, "sanjeev s" <[email protected]> wrote:
Thanks for the reply and valuable suggestion.
One more Question:
Anyway to avoid bringing down(cleaning up ) all MPI jobs when one job dies.
Regards Sanjeev
On Thu, Jun 1, 2017 at 10:25 AM, Guo, Yanfei <[email protected]> wrote:
On 5/30/17, 10:19 PM, "sanjeev s" <[email protected]> wrote:
I have added the detailed use case..
I did not follow what were you trying to do here. Can you be more specific?
Suppose I have an application which accepts some request from client and do the MPI job on request arrival(lazy load of mpi lib). Now I started this application through mpiexec on 4 machines. mpiexec will start my application on 4 machines not MPI jobs. On request arrival I will distribute MPI jobs to this cluster after doing some processing in my application on master node.(1 of out of 4 I will designate as master node). Now I want to add one more machine( having my application) to this cluster, without stopping my already running applications. My master process should be able to see this 5th machine and distribute the task. Is there any way to achieve this?
Is this "application" an MPI program? If so, there are two options. 1. Starting the MPI process on the 5th machine and have it connect to your existing processes (with MPI_Comm_connect/MPI_Comm_accept). 2. Letting the existing processes spawn new processes on the new machine (with MPI_Comm_spawn). You can check out the book "Using Advanced MPI" for details and examples. If the aforementioned application is not an MPI program, then what you are trying to do is beyond the scope of MPI.
Also, When I took the size(number of instance for that comm), I am not getting the count for client instance. To distribute the task, I need to have additional logic to handle this case in my application.
Can you be more specific about which comm you were referring to?
I am referring to MPI_COMM_WORLD. Is there any resize kind of api which will give me how many jobs are there on this comm after doing one accept connection?
MPI_COMM_WORLD is created during MPI_Init. It does not change when a new process group is connected. The communicator that accepts the connection will give you an intercommunicator which allows the accepting processes to talk to the connecting processes. You can merge this intercommunicator to a intracommunicator that contains all the processes.
Hope this helps in understanding the problem.
Regards Sanjeev
Yanfei Guo
On Mon, May 29, 2017 at 8:48 AM, sanjeev s <[email protected]> wrote:
Thanks for the reply. I have given the detailed use case below.
Regards Sanjeev
On Sat, May 27, 2017 at 2:30 AM, Guo, Yanfei <[email protected]> wrote:
Hi Sanjeev,
Please see the inline comments below.
On 5/26/17, 10:40 AM, "sanjeev s" <[email protected]> wrote:
In dynamic process, I read about two models: Client server and parent child.
Client Server : We need to have dedicated threads each for client and server. Now considering all instances same , we will end up doing lot of thread creation apart from our application worker threads.
I assume you are referring to the connect/accept model by client/server. In that case, you may need one thread on the server side to handle the incoming connection because the `MPI_Comm_accept` call is blocking. A dedicated thread is not necessary in the client. It is your application’s job to decide who is the server.
Yes I am referring to same connect/accept model. I don't want to put this logic in our application. I want some external process manager ( like Hydra) which can handle this form me .Please see below for detail use case.
Moreover when 1 instance (app) goes down, we want that instance to come up without doing much manual work. We don't want to club this logic in our application.
2) Parent child: Suppose we have started 4 instance on 4 different machines. Now we need to add another server. I don't think parent child/ client server is good option in this case.
We don't want to build process management capabilities in our application. We are looking for process management in MPI itself (e.g in Hydra )so that we can leverage on that.
Please correct me if I am missing something in my understanding of Dynamic model.
Regards Sanjeev Sinha
On Fri, May 26, 2017 at 8:46 PM, Halim Amer <[email protected]> wrote:
Sanjeev,
More precisely my requirement is suppose I started 4 instances of my application. Now I want to add one more instance dynamically to this set
From my understanding, dynamic processes would work fine for this case. Could you elaborate on why the dynamic process model is not sufficient for your needs?
Halim
www.mcs.anl.gov/~aamer <http://www.mcs.anl.gov/~aamer> < http://www.mcs.anl.gov/~aamer> <http://www.mcs.anl.gov/~aamer>
On 5/26/17 9:11 AM, sanjeev s wrote:
Hi mpich,
I have a requirement where in we need to add start stop application instances on the fly before starting a job.Is there any mpich service available. I looked through dynamic process model, but its not sufficing our need.
Is there any tool which MPICH supports for fault tolerance behavior?
Thanks Sanjeev
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
sanjeev s
