Re: [mpich-discuss] How to configure MPICH build to create linux x86 cross-compiler for ARM?
Hi Alex, One thing to understand is that MPICH does not actually build compiler tools, so the --target option is not used. mpicc and friends are only wrapper scripts. Here is how I was able to configure/build MPICH on my laptop (Ubuntu 16.10) to cross-compile binaries arm-linux-gnueabi. Fortran is disabled since it requires additional steps. ./configure --build=x86_64-linux-gnu --host=arm-linux-gnueabi CC=/usr/bin/arm-linux-gnueabi-gcc-6 CXX=/usr/bin/arm-linux-gnueabi-g++-6 --disable-fortran Ken On 06/01/2017 10:22 AM, Alexander Rast wrote:
I assume you mean from the build intended for the ARM targets. In any case here they are.
On Thu, Jun 1, 2017 at 4:04 PM, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote:
Hi Alex,
I don't have experience with this type of build, but I can try to replicate it on a system here internally. Can you provide a couple of artifacts first?
1. the config.log file from the top-level build directory 2. the output of 'mpicc -show' from the installed build
Thanks, Ken
On 06/01/2017 10:00 AM, Alexander Rast wrote:
All,
I'm trying to build MPICH so that I can cross-compile MPI applications on my x86_64-linux system to run on an arm-linux machine. I want to emphasise that this is different from building a native ARM MPICH install that runs on ARM itself; the intent is that an x86-linux 'root' process compiles ARM MPI application binaries and distributes them to the ARM cores. I have a separate build for compiling the MPI binaries that lie on the root x86 system. I tried running configure with --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=arm-linux-gnueabi, but that didn't give me what I need. If, meanwhile, I try to run mpicc off the native x86 build (the MPICH installation used for running MPI applications on the root x86 system) it complains that the target type specified in the makefile (CFLAGS = -march=armv8-a -mtune=cortex-a53) isn't supported. It's not clear how one creates this sort of 'hybrid' build, running on one platform, compiling MPI applications for another.
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
