Communication issue with simple test?
Dear MPICH users, I'm having an issue with, apparently, communication between nodes of the local cluster we're using. To fix ideas, the cluster is made of 8 different nodes and it was set-up with now outdated versions of the Intel compilers and MPI libraries. I did an mpbboot/mpdringtest and it seems to work fine. Now, I would like to use my application code with MPICH 3.3 installed from PETSc and with gcc-8 installed from linuxbrew on the different nodes. I tested a simple Fortran program: program test use mpi use ISO_fortran_env, only: output_unit implicit none integer :: irank, nproc, ierr character(len=80) :: hostname call MPI_INIT(ierr) call MPI_COMM_SIZE(MPI_COMM_WORLD,nproc,ierr) call MPI_COMM_RANK(MPI_COMM_WORLD,irank,ierr) if (irank == 0) THEN WRITE(output_unit,'(1X,A,I3,A)') 'Started test program with', nproc, ' MPI processes' end if call MPI_BARRIER(MPI_COMM_WORLD,ierr) call HOSTNM(hostname,ierr) WRITE(output_unit,'(1X,A,I3,A)') 'I am processor #', irank, ' running on '//hostname call MPI_FINALIZE(ierr) end program test It works fine on the local host. But when I try to launch it on all the nodes with "mpiexec -f path_to_hostfile -n 8 path_to_my_program" I get: Started test program with 8 MPI processes Fatal error in PMPI_Barrier: Unknown error class, error stack: PMPI_Barrier(287)...........................: MPI_Barrier(MPI_COMM_WORLD) failed PMPI_Barrier(273)...........................: MPIR_Barrier_impl(173)......................: MPIR_Barrier_intra_auto(108)................: MPIR_Barrier_intra_recursive_doubling(47)...: MPIC_Sendrecv(347)..........................: MPIC_Wait(73)...............................: MPIDI_CH3i_Progress_wait(242)...............: an error occurred while handling an event returned by MPIDI_CH3I_Sock_Wait() MPIDI_CH3I_Progress_handle_sock_event(698)..: MPIDI_CH3_Sockconn_handle_connect_event(597): [ch3:sock] failed to connnect to remote process MPIDI_CH3I_Sock_post_connect_ifaddr(1774)...: unexpected operating system error (set=0,sock=5,errno=101:Network is unreachable) Note that when I comment the call to MPI_BARRIER, it works fine as well. Therefore, communication between nodes seems to be an issue. All the nodes see and have access to the same mpiexec/mpifort executables: I checked $PATH and 'which mpiexec'/'which mpifort'. Could you give me ways for an efficient diagnostic of what's possibly wrong? mpiexec --version gives HYDRA build details: Version: 3.3b1 Release Date: Mon Feb 5 10:16:15 CST 2018 CC: gcc-8 -fPIC -fstack-protector -O3 -march=native CXX: g++-8 -fstack-protector -O3 -march=native -fPIC F77: gfortran-8 -fPIC -ffree-line-length-0 -O3 -march=native F90: gfortran-8 -fPIC -ffree-line-length-0 -O3 -march=native Configure options: '--disable-option-checking' '--prefix=/home/petsc/icm_cplx' 'MAKE=/usr/bin/make' '--libdir=/home/petsc/icm_cplx/lib' 'CC=gcc-8' 'CFLAGS=-fPIC -fstack-protector -O3 -march=native -O2' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++-8' 'CXXFLAGS=-fstack-protector -O3 -march=native -fPIC -O2' 'F77=gfortran-8' 'FFLAGS=-fPIC -ffree-line-length-0 -O3 -march=native -O2' 'FC=gfortran-8' 'FCFLAGS=-fPIC -ffree-line-length-0 -O3 -march=native -O2' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-g=meminit' '--cache-file=/dev/null' '--srcdir=.' 'LDFLAGS=' 'LIBS=' 'CPPFLAGS= -I/home/petsc/icm_cplx/externalpackages/mpich-3.3b1/src/mpl/include -I/home/petsc/icm_cplx/externalpackages/mpich-3.3b1/src/mpl/include -I/home/petsc/icm_cplx/externalpackages/mpich-3.3b1/src/openpa/src -I/home/petsc/icm_cplx/externalpackages/mpich-3.3b1/src/openpa/src -D_REENTRANT -I/home/petsc/icm_cplx/externalpackages/mpich-3.3b1/src/mpi/romio/include' 'MPLLIBNAME=mpl' Process Manager: pmi Launchers available: ssh rsh fork slurm ll lsf sge manual persist Topology libraries available: hwloc Resource management kernels available: user slurm ll lsf sge pbs cobalt Checkpointing libraries available: Demux engines available: poll select Thank you, Thibaut
participants (1)
Appel, Thibaut
