Re: [mpich-discuss] Problem met when installing mpich on a linux server
Hi Balaji, The problem is still there after passing -disable-maintainer-model. I attched c.txt and m.txt below. On Sat, Apr 19, 2014 at 10:49 PM, Balaji, Pavan <[email protected]> wrote:
Which version of mpich are you using? This typically happens when you have a timestamp mismatch and make thinks it needs to rerun autotools. You can try passing --disable-maintainer-mode to configure to help with that.
— Pavan
On Apr 19, 2014, at 10:47 PM, Fenglei Qi <[email protected]> wrote:
Hi all,
I tried to install mpich on a server with redhat system. I can configure mpich successfully but I met problems when I tried to build mpich. It threw out a warning: 'aclocal-1.14' is missing on your system. I checked the system and I found out that my system only has aclocal-1.11. Since I don't have privilege to install software so I can't update it. Any suggestion for further installation? I attached m.txt and c.txt below. Thanks.
-- Fenglei Qi
Research Assistant Mechanical Engineering Iowa State University _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- *Fenglei Qi* Research Assistant Mechanical Engineering Iowa State University
participants (1)
Fenglei Qi
