Re: [mpich-discuss] BLCR kernel module not present
I can't speak for mvapich, of course. I'm only speaking about mpich. However, most of our derivatives don't destroy the features that are in stock mpich. So I'd think it'll work fine with mvapich as well. -- Pavan On 04/26/2013 03:20 PM US Central Time, michael wrote:
Thanks Pavan
Just to be clear, you're saying if I use mvapich with blcr then a running multi-node MPI job when killed (eg out of time) by a batch scheduler can be restarted (from which checkpoint?) presuming it doesn't have open files?
Many thanks, M
On Fri, 2013-04-26 at 15:12 -0500, Pavan Balaji wrote:
Michael,
BLCR support for mpich should work fine; if something is broken, please let us know.
However, the core BLCR group itself hadn't released updates in a while, primarily because they didn't have direct funding for it. I believe that's fixed now and they are working on newer releases.
-- Pavan
On 04/26/2013 03:07 PM US Central Time, michael wrote:
Hi folks I was wondering what the state of BLCR for mpich/mvapich is? eg how reliably can one presume it to be? Thanks, Michael
On Fri, 2013-04-26 at 14:33 -0500, Wesley Bland wrote:
It looks like you might have missed installing the kernel module for BLCR. What is the output of `lsmod`?
Alternatively, if you installed BLCR by using apt-get in Ubuntu, you should be able to use dkms to manage your kernel modules automatically. Make sure you have the package 'blcr-dkms' installed (you should be able to check this by typing `dims status`.
Do either of those solutions solve your issue?
Wesley
On Apr 26, 2013, at 1:55 PM, basma a.azeem <[email protected] <mailto:[email protected]> <mailto:[email protected]>> wrote:
Thank you for your help
i installed BLCR 0.8.5 on my ubuntu 12.10 to be used for MPICH -3.0.3 this version of blcr should support to kernels through 3.7.1
when i run the command : basma@basma-Satellite-A500:~$ mpiexec --info
results:
HYDRA build details: Version: 3.0.3 Release Date: Thu Mar 28 16:01:21 CDT 2013 CC: gcc CXX: c++ F77: no F90: no Configure options: '--disable-option-checking' '--prefix=/home/basma/mpich2-install' '--disable-f77' '--disable-fc' '--enable-checkpointing' '--with-hydra-ckpointlib=blcr' '--cache-file=/dev/null' '--srcdir=.' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS= ' 'LIBS=-lrt -lcr -lpthread ' 'CPPFLAGS= -I/home/basma/libraries/mpich-3.0.3/src/mpl/include -I/home/basma/libraries/mpich-3.0.3/src/mpl/include -I/home/basma/libraries/mpich-3.0.3/src/openpa/src -I/home/basma/libraries/mpich-3.0.3/src/openpa/src -I/home/basma/libraries/mpich-3.0.3/src/mpi/romio/include' Process Manager: pmi Launchers available: ssh rsh fork slurm ll lsf sge manual persist Topology libraries available: hwloc Resource management kernels available: user slurm ll lsf sge pbs cobalt Checkpointing libraries available: blcr Demux engines available: poll select
so i thought that every thing is ok but when i try to rum mpiexec it failed:
basma@basma-Satellite-A500:~$ mpiexec -ckpointlib blcr -ckpoint-prefix /home/business/ckpts/app.ckpoint -ckpoint-interval 3600 -n 4 /home/basma/libraries/mpich-3.0.3/examples/cpi
results:
Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(433)...: MPID_Init(151)..........: channel initialization failed MPIDI_CH3_Init(70)......: MPID_nem_init(379)......: MPIDI_nem_ckpt_init(153): BLCR kernel module not present Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(433)...: MPID_Init(151)..........: channel initialization failed MPIDI_CH3_Init(70)......: MPID_nem_init(379)......: MPIDI_nem_ckpt_init(153): BLCR kernel module not present Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(433)...: MPID_Init(151)..........: channel initialization failed MPIDI_CH3_Init(70)......: MPID_nem_init(379)......: MPIDI_nem_ckpt_init(153): BLCR kernel module not present Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(433)...: MPID_Init(151)..........: channel initialization failed MPIDI_CH3_Init(70)......: MPID_nem_init(379)......: MPIDI_nem_ckpt_init(153): BLCR kernel module not present
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
i am a Linux and parallel programming beginner
Thank you
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
